Anyone is Central florida wanna run?
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Any street cars out here decent?
i wanna clame dominancy in the street car class of thirdgens here in Central Florida. lemme know
Car: '87 IROC Z-28
Engine: Horse **** 305 for now
Transmission: 700-R4
Axle/Gears: 3.73 posi
Re: Anyone is Central florida wanna run?
That is brash to say the least (nothing wrong with confidence however) you might want to check the site for other members in C Fl that are running big blocks and/or turbo/superchargers before going too far into the "I tripple dog dare you" phase. Good luck defending the onslought, hope you do as good as you think you will.
Car: 1991 Z28 - 2000 Z28
Engine: L98 - LS4
Transmission: 700R4 - 4L60E
Axle/Gears: 3.23's - 3.73's
You're faster than my thirdgen, but I would put my 2000 up against you any day of the week. I'll be at BMP on the 14th for a private track rental. After that, I can make to OSW whenever.
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
your 4th gen would be a great run. I will let you know when my spray is working properly as I am getting my motor runs down right now. I will be at OSW this friday if anyone wants to show
I honestly think I have potentially one of the faster street driven thirdgens around CF. just because it isnt a bbc or s/c or some turbo doesnt mean jack. very strong running motor and lots of spray with how my car is setup is a good setup.
let me know man. I really jus wanna get some runs in and enjoy my car.
Engine: L98 - LS4
I'm getting set for BMP next weekend currently, but after that I can go up to OSW for a few runs before Randy yells at me and gives me the boot.
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Axle/Gears: 9'' 4.10 gear
I will run you motor for motor at Orlando speed way next month my car has a small block with 93 oct gas.
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I am new in Central Florida, and I claim to have the fastest small block TPI-type 3rd gen F-body. Who wants to race me? How about Wednesday evening Jan. 21st at Orlando Speedway? (and I am talking about NA and streetable)
Car: 1988 Camaro
Engine: LR4
Axle/Gears: 3.23posi/disc
Um, is the spot for fastest TBI 305 still open? lmao (just kidding)
I wouldn't mind coming up there to hang around and maybe make a pass or two on a run-what-you-brung test day to see what numbers I could actually get. but thats out of the question for me right now.
Car: '87 IROCZ
Engine: 395 ZZ4
Well, lets do it. My claim has one intension, get some of the 3rd gen cars out at Orlando.
Car: '84 Z 28
Engine: has 8 cylinders
Transmission: has a stick coming out of it
Axle/Gears: a grenade, makes wheels turn
Jan 11th at orlando speed world is a funday runday, for those interested...
I'll be there with a few club members from http://scfba.info/ , a central fla all f-body club.
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
didnt get a clean nitrous pass but best was 11.1 letting off somewhere round the 1000.
freaking fuel solenoid came off but im just glad i didnt blow the motor lol
also i will be there the 21st. see you then
Engine: L98 - LS4
I'll be there the 11th, can't swing the 21st with work. I should be there the 23rd with the 91' if everything works out. I expect it to go 13.30's... maybe a little quicker. Can't ask for too much out of a stock L98 with a stall and bolt ons.
Car: '87 IROCZ
Engine: 395 ZZ4
I have a issue with the engine stumbling while cruising. However, I expect to make it to Orlando Speedway on the 11th and the 21st. For Sunday, they said the gates open at 10:00am.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
that car should move out man. your setup is sorta like mine and i went 10.6 with 150whp shot. How much you spraying?
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
lol 150. i want 10.60's as i sit. yours and my build have been really close. lol
im getting a rear end son so ill be spraying out the hole.
also i will be getting a turbo 350. who knows.
Car: 89 Iroc-z
Transmission: TH400
jeez 10.60's on motor is a tough job with a 383 unless you run a solid roller i'd say. You'll want to turn some rpm, but with a TH350, good gear, good converter and lighter weight and crazy good air conditions you may beable to do it, atleast high 10's. I went 11.47 on motor with a so so 60 foot and hot air with nitrous gearing. Probly 11.30's for sure with proper launch and cooler air with proper on motor gearing. who knows i'll never find out
Car: 89 Iroc-z
Transmission: TH400
oh you should easily have that or darn near close to it
Zachattack0925
08-12-2015 10:54 PM
Zachattack0925
08-12-2015 10:52 PM
