Volusia County Florida!
#451
Car: 1991 Z28 - 2000 Z28
Engine: L98 - LS4
Transmission: 700R4 - 4L60E
Axle/Gears: 3.23's - 3.73's
Re: Volusia County Florida!
Cool, a full tank of gas is your friend if you're worried about traction there. I top mine off at the station by publix every time. (in the 2000 that is, traction isn't as much of an issue with the 91' because it doesn't make very much power)
#452
Car: IROC-Z
Engine: L98 350
Transmission: THM 700R4
Axle/Gears: 2.77 Posi
I got a box with a nice and heavy sub in there to help. Im going to put some new spark plugs in there before I go. Going to try out those new E3's. Might do plugs too, not sure.
#453
Engine: L98 - LS4
Well, I already made arrangements with work so I can be there... let's hope the weather is decent that day. I just wish I could find some better tires in the meantime.
#454
Car: IROC-Z
Engine: L98 350
Kool, you bringing the 2000 or the '91? If I could afford tires I would but I have enough tread to do with.
#455
Engine: L98 - LS4
Does your car spin bad on the street? With your gearing, it should leave pretty good.
#456
Car: IROC-Z
Engine: L98 350
It can spin pretty bad. I kinda have to roll a bit before I get on it. When its wet I dont even have to try to spin. They do it without me knowing, Ill sit there wondering why Im not moving lol.
#457
Engine: L98 - LS4
You might want to try playing with air pressure then. On radials, the best I seem to do at Orlando is 2.2's - I swap to old worn out BFG drags and I go low 1.90's instantly. .3 is a helluva difference from just tires as stock as my car is.
#458
Car: IROC-Z
Engine: L98 350
Yea mine are at 30 psi where they are supposed to be. Ill see what happens when I get there. First couple runs Ill see how hard I can launch.
#459
Car: 86 T/A & 88 GTA
Engine: 305 LB9 TPI & 350 LO5 TPI
Transmission: Jasper 4L60 x2
Axle/Gears: 2.77/posi LSD & 2.73/posi LSD
i will be getting the new air cond. comp. in the mail tomorrow already got the o-ring set in. i cant wait to get the ac working like new again.
#461
Car: IROC-Z
Engine: L98 350
Me and a few other guys are heading to OSW tomorrow night, weather permitting. If anyone wants to head over and check it out run a few. Its 10 dollars to get in and 5 dollars a run. Hopefully if the weathers good people wont show up thinking the weather will be bad and we get a good amount of runs in.
#462
$129 for the compressor and $21.69 for a complete o-ring set. i got them form summit. they were on back order for a while though. but always shows up when you order from summit. mine came in excellent condition. i am going to try for the install this weekend and take the smog pump out at the same time. now i got to get r-134a to charge the thing. you can't win.
#463
Engine: L98 - LS4
#465
Car: IROC-Z
Engine: L98 350
Yea weather.com says for Orlando thunderstorms from noon and on into the night. If it looks like its going to be bad at 3:30 I wont go. No need to burn gas and do nothing there.
#466
Engine: L98 - LS4
I get off work at 3:30 tomorrow... I work in WP, about 20 minutes from the track. So I'll pretty much know if I'm going or not by then. Just the same, I'll come home, wait until about 6, call the track and see what the status is. I've left my house here in a dowpour - and gotten within 10 miles of the rack & it was perfectly clear and sunny.
But, typically this is a bad time of yewar to try and go because it rains nearly every afternoon.
I just made a deal for some better tires today, so if I'm unable to go tomorrow - it just gives me more time to mount these tires up and recalibrate the speedo/shift points. The car should leave really hard on a 28" tire.
#467
Car: 92 Lo3 RS
Engine: 305 roller tbi
Transmission: t-5
Axle/Gears: 3.08 open
rain sux. it looks to be coming in tonight just b4 6:00.
#468
Car: IROC-Z
Engine: L98 350
That makes me not want to go when you say that Will. Ill watch the weather and see what they say around 3 to 3:30.
#469
Engine: L98 - LS4
It's a no go, I just left that area... monsoon-like rain, thunder, lightning - the whole nine yards. I guess I'll try again in about a month.
#471
Engine: L98 - LS4
It's nice & sunny now, kind of wish I had tried to go out there.
#472
Car: 92 Lo3 RS
Transmission: t-5
buy the time i got there they ran 1/8ths for 30 min then 1/4s. i ran twice, had some cooling problem. 16.4 80? mph r/t .4?? what i expected for lo3.
#473
Engine: L98 - LS4
Oh man, you went? Crap! Now I wish I would have headed that way around 6 pm. Was it crowded?
#474
Car: 92 Lo3 RS
Transmission: t-5
not at first. i should ran right away, waited and it got crowded.
#475
Yea, the time I went with mrr23's new motor and ran the Avalanche, we were out front about 15 minutes before they opened the gates, and I ran the Av 4 times within like an hour before I parked it.
Get there early and run a couple times, and then decide if you want to fight the crowds...
#476
Engine: L98 - LS4
I even left work early to go yesterday... damnit. Oh well, I'll have real tires when I go next time.
#479
Car: IROC-Z
Engine: L98 350
We usually meet up whenever we can. Mostly busy so see when a good time is for most of us to get together.
#480
i am still alittle too busy. i have been working almost 60 hours a week! i am beat. got the compressor in though. blew the cut off switch right off the back of it. ordered a new one with harness. we shall see.
#481
Engine: L98 - LS4
Hey guys, I submitted my info for registration to the SCFBA. Still waiting for my confirmation/activation email.
#486
i got a code 54 being thrown on the 86. ecm most likely problem?
#487
Car: IROC-Z
Engine: L98 350
Code 54 is Fuel pump circuit. So check your relay first and wiring. Could also be oil pressure switch too. I wouldnt rule ecm just yet if the car is running the same.
#488
hard to start car. have to turn key and hold a couple of times. i saw where it said relay and pump and oil pressure switch. i know the oil switch is fine though. it also said ecm. i was just thinking since i had the other problem before. need to check on relay. really hope the fuel pump isnt shot. so where is the fuel relay at?
#489
Car: IROC-Z
Engine: L98 350
Its with the three relays by the master cylinder on the firewall. I believe its the one that doesnt look the same as the other 2. I could be wrong. My 2 that looked alike were for MAF and MAF burnoff. Not sure if they changed them up by year or model but Ive seen different with other peoples cars.
#490
broken wire between the ecm and the fuel pump. working like a champ now.
#491
tensioner pully makes racket when a/c is on. so now i need tensioner pulley. plus turn signal switch (not lever). this is all on the 88. one thing after another
#492
Car: IROC-Z
Engine: L98 350
Thats how mine was, just one thing after another. Hopefully it has stopped....
#493
well everything that becomes old and fragile just needs alittle attention to stay young and spry at heart. lol.
#494
Me and other members on FuelSlut.net are trying to get some meets happening in the Daytona Beach Area.All Domestics Welcome.So far the place is set for Circuit City Parking Lot in Daytona Beach right off International at 8:00.Would like if you guys can attend.We are just waiting for a ok by Circuit City Store.If we cant get one,we can still meet there until they close at 10.If we then have to leave we can find another location.Rules are simple.No Burnouts,Loud Music,or BS.Will give more info out once we find out for sure place and time,But so far we are shooting for Circuit City Parking Lot,Saturday the 9th @ 8:00
#498
#499
Engine: L98 - LS4
I wanted to go, but it was a childhood friend's birthday. By midnight, there wasn't much point of heading out there.
#500
No prob.trying to get another one setup next week.Suppose to lots of guys from ls1tech going to the car show in ormond at destation daytona then hopefully theyll come to the Daytona meet.
