Accel DFI for 86-89 TPI
Car: 89 Fromula
This is for one CALMAP Power Processor ver 6.32. It can be used on any vehicles running a 1986 -1989 TPI 5.7L (350 cid) engine. This engine management system allows you to: Convert your restrictive mass air flow injection system to speed/density system for increased airflow. Install performance camshafts, headers, cylinder heads, etc in your computer equipped vehicle
CALMAP software and serial interface cable included for complete recalibration capability of fuel mixture and ignition timing
Adjust fuel and ignition settings for your engine.
Will allow full control of 1 stage of nitrous
This is basically a "piggyback" processor that plugs inline with the car's computer. No wire splicing because the kit contains everything needed. The kit contains the following:
PowerProcessor Module
Manifold Pressure(MAP) Sensor
Module to Factory Computer Harness
Module to Map Sensor Harness
CALMAP Calibration Software
The Accel Part number is: 74350-C
This kit is new in the box and has never been installed. It was purchased to run on my 1988 Formula 350 but never installed it. Was $750 asking $425. Or will trade for GTA wheels w/ tires or 17" wheels
[Sold] Accel 30# injectors
hydrolic144
08-29-2015 04:14 PM
355tpipickup
Alternative Port EFI Intakes
08-26-2015 04:08 PM
Sanjay
08-12-2015 03:41 PM
