WTB - 350 L98 LongBlock - 91/92 Block
Car: 85 Iroc
Engine: 305 LB9
I will be at the Thirdgen Gathering on June 26. Been looking for a block to build a 383 out of. Whatchya got?
Car: '70 Bronco, '91 Firebird, '03 Chevy
Engine: roller 302, 350 TB, stock 6.0
Transmission: NP435 Granny 4 spd, 700R4, 4L80E
Axle/Gears: 4.56 spool, 2.73 open, 4.10 broken
Re: WTB - 350 L98 LongBlock - 91/92 Block
How about a 96-00 Vortec block? I also have the rotating assembly, oil pan & all the roller cam goodies minus the cam. It toasted some rod bearings & the journals on the crank from that but the rods should be usable.
For anyone else reading: I also have one Vortec head that should be good & one cracked bigger than California & also the truck's accessory brackets.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
I have a 87 L98 block, not sure if i wanna sell r not yet... It is the same as the 91/92.
Car: 85 Iroc
Engine: 305 LB9
I will do some research on the Vortec. Really wanted an L98. Which heads are on that Vortec setup?
Car: '70 LeMans
Engine: 383 Stroker Small Block
Transmission: Turbo 350
I also have an entire l98 setup out of my old 87. Ran and drove great before the wreck. The whole thing, block, heads entire top end and bottom end.
Just no wiring harness. 300$obo for all of it if your interested.
The Vortec is typically a 4-bolt main block used in 1995 or later Chevrolet/GMC trucks and larger SUV's like the Tahoe and Suburban. Its still an SBC just like the L98. In fact its a 1 piece rear main seal block just the same as the L98. They have provisions for both roller and flat tappet cams. The Vortec blocks are good to go. Strong and plentiful. Both my extra 350 block and my "new" 383 blocks are both "Vortec" blocks. Oh, the 4-bolt main block is essentially the same as the ZZ4 block. They'll take traditional SBC heads, cams, knock sensors and anything the L98 can.
Car: '70 LeMans
I do not know. I think all SBC's can do flat tappet cams but not all blocks can do roller cams. Though I do know there is a retrofit kit that allows you to install roller cams in blocks that only have provisions for flat tappet cams.
Car: 85 Iroc
Engine: 305 LB9
Shoot me some pics of what all is there to scott.j.zimmerman@gmail.com
Where was the car hit? Did it run after the wreck? Very interested.
Car: '70 LeMans
I have some pics. I'll have to find them.
No it didnt run cause the MAF got torn apart in the wreck therefore the car wouldnt start.
Car: 85 Iroc
Engine: 305 LB9
Shoot the pics over to scott.j.zimmerman@gmail.com
I will see about getting some arrangements made to have it picked up from you.
Eric-86sc
08-24-2015 09:01 PM
TA8487
08-16-2015 12:21 PM
Mister_Johnny99
Interior Parts Wanted
08-14-2015 12:59 PM
