transmission repair time!!!!!!!
Car: SOLD!!!!!
she would do ok as long as i was driving her easy but when you tried to accelerate she would give up. 20 years on a tranny is good imo. ordered and recieved all my parts the other day. got her pulled out yesterday. these are the parts i am using.
1. monster in a box--http://www.monstertrans.com/store/pr...87%252d93.html
2. torque converter--IT IS LIME GREEN!-http://www.monstertrans.com/store/pr...30-Spline.html
3. reverse input drum-http://www.monstertrans.com/store/pr...87%252d92.html
i also have a sonnax billet 4th apply servo kit i am going to try. (free). and a new tv cable from gm to put in. i believe my buddy also has a hardened shaft as well. also found that i need to do some welding on my ypipe. it has some pinholes in it.going to go with a smaller catalytic converter instead of the 3 inch high flow. and possibly lift the engine up and reseal the oil pan, front and rear seals.
Car: 1986 IROC-Z28 & 1987 GTA
Engine: 305 TPI & 350 TPI
Re: transmission repair time!!!!!!!
That does not sound like much fun....I'm surprised my tranny has held up as long as it has. 174k!
Not looking forward to this project. Keep us posted & let me know if you need a hand. I'll be available tomorrow & thursday.....
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
A Trans going out was the excuse for my last LS swap. Lol
Car: SOLD!!!!!
it was great till i found this and had to order more parts.
rear sprag assembly that drives the over run clutches and sprag inner race has some wear as well. when we removed the assembly we found the springs twisted some. ordering the steel piston and return spring upgrade kit, good rear sprag assembly to put in my 29 element. things completed
1. disassembled and cleaned all parts and case
2. superior shift improvement kit installed
3. corvette servo and transgo washer mod complete with springs
4. reverse input drum came complete
5. front pump rebuilt
6. governor weights installed
what we found interesting.
1. my front pump was thicker than the other 700r's we had seen and already had hardened pump rings in it. vanes had no wear notches.
2. sunshell had the large windows same as beast sunshell and the splined part that usually breaks was a little thicker
3. rear planetary had an oil slinger already installed like the corvette's had
so so far im good except the extra parts.
Car: SOLD!!!!!
trust me it crossed my mind. but i am going to keep her auto. and a lot has to do with being able to build it with some instruction from a friend. and to know it wont ever have to come out. and since i am not going 4l60e i need to save for ebl flash.
Car: SOLD!!!!!
all the inner parts are in. modifications are complete.front pump and mods are complete and bolted in. 2-4 servo mods are complete.tomorrow we will bolt on the modded control valve and the pan. i will then bring her home. i still need to reseal the oil pan, timing cover, rear seal, and install a new oil pump. then i will stab the tranny and put that in. then i need to weld up the pinholes in my ypipe and then she will be back on the road.
Car: 02 SS
Engine: 408 TT (1108rw-93/m1)6700rpm
Transmission: TH400(slipping)
Axle/Gears: 12bolt/3.42(whines😠)
im the guy that will pull motor/trans cuz there is ALWAYS something else that needs fixing.
clutch job, usually ends up being h/c/i etc.
"since im alredy here"
Car: SOLD!!!!!
front cover, rear seal, oil pan and oil pump installed. transmission installed and she is up and running. got to put the wiper motor back in and check fluids again tomorrow.
IROCZDAVE (88-L98)
10-06-2016 09:08 AM
BlackphantomZ28
04-24-2016 08:14 AM
