Can someone in Houston Tune my Camaro??
Car: '76 LT, '87 IROC
Whats up thirdgen guys, so I've put in a couple of parts on my Camaro an I really really new a good tune now lol.
I've installed
- longtube headers (no 02 sensor)
- shaved MAF fins
- k&n air filters
- egr delete
- coolant bypass
- timing curve
There's more I'm sure but my car is running rich now and I really need it tuned to straighten it out.
PM me if you can do it for me thanks!
I've installed
- shaved MAF fins
- k&n air filters
- egr delete
- coolant bypass
- timing curve
Re: Can someone in Houston Tune my Camaro??
I've installed
- shaved MAF fins
- k&n air filters
- egr delete
- coolant bypass
- timing curve
I've installed
- shaved MAF fins
- k&n air filters
- egr delete
- coolant bypass
- timing curve
But the thing is is that even before I've had my headers and what no it was already running rich, I don't think it was even in a closed loop before.
you can use a acdelco afs-74 if your needing a heated 02, you can get the pigtail at jimsperformance.com . If you dont have a cable you can build one cheap for a older laptop and use winaldl or buy a usb to aldl and use tuner pro. There is always the cheap route of jumping the aldl a to b for field service mode and watch the check engine light for closed loop. You will want to fix the 02 before you do anything else.
Thanks for all the info man and hey I was actually thinking about buying the 1 wire cable that has the all in one. I forgot who made it but its like $80. Will that work too??
xbmx89
South Central Region
10-31-2015 10:59 AM
Zachattack0925
08-12-2015 09:54 PM
Zachattack0925
08-12-2015 09:52 PM
