Need a mechanic in fort worth 4 brakes
Car: 1991 Z28 Convertible
Axle/Gears: 3.23 with Eaton posi
Greetings and salutations!
I have 91 Z28. I live in fort worth. Need a local mechanic who can rebuild front brakes, install my rear disc kit, and install an adjustable prop valve.
There is a good mechanic ive heard of in mid cities called "Second Opinion" but they are only open m-f. Cant get off work to bring it in. Lookin for a shop open saturdays.
Any recommendations?
Car: 1992 Z28
Engine: Forged LS3
Transmission: T56 stage 2 clutch
Axle/Gears: 35 spline with 3.55 gears
Re: Need a mechanic in fort worth 4 brakes
Hey man ...
Post some pics of your camaro , PLEASE.....
And I can help with your brakes.......
Here are a couple pics from last summer.
Normally I wouldn't hesitate to install the brakes. But I've never messed with an adjustable prop valve. Not sure if lines need re-flaring. Thanks for the offer! Any experience with replacing prop valve?
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
Robbie would be a great person to help, but if you can't make it out there, try Hays Auto in south Ft worth. Keith is a friend of mine, and he does great work, and he's very honest.
Car: 1992 Z28
Engine: Forged LS3
I have installed a rear drum to disk rear end And added a 1le stock Valve From another car and it works fine . I haven't installed a aftermarket adjustable proportioning valve though ...
I have most of the kit to upgrade my 92 to the front ls1 brakes and I plan on adding 1le brakes to my 91 vert . I have the entire 1le brake set up for the 91 already ....
Thanks for the compliment.....been working on the camaro for 10 yrs. Little here, little there. My weekends are mostly booked. Fiancee in Austin- so I'm usually there on weekends. Sucks workin 8-5 m-f; never any time off during weekdays to get stuff done. I've been meaning to come to a nttga meeting but just havent been able to make it. Thanks for the offer Robbie. As I said most of my weekends booked. As soon as something comes up I'll let you know.
