91 formula build up
Car: 1989 GTA
Engine: pending install 383 tpi
91 formula build up
Well I havent really documented my entire build up on my car so I thought I would finally share my pros and cons thru out my build. I bought my bird from the original owner with 76k on the clock and it was in excellent condition just a small rip in the drivers seat, needed new catback system, 305 tpi. So here is my parts list:
Rebuilt .40 350 block with 350HP rebuild kit-trashed during breakin due to bad seal on intake gasket- sold motor for $75 just for parts
425hp crate motor from proformanceunlimited.com- get this only cost me $2500 pulled from my buddies 72 chevelle he had to sell
stock t-5 transmission resealed and inspected $100
Hurst short throw shifter $189
Zoom stage 3 clutch $300
magnaflow catback system $289(brand new)
Hooker headers $170
Hooker y-pipe $225 (piece of sht, their jig is off by at least 1/4inch on both pipe flanges
Energy suspension bushing kit $100(pain in the A$$ to put in a-arm bushings)
new fuel line $40
fuel line clips $9
pulled bbk fuel pump from tank modified pick up to run new carbed setup
BMR panhard bar with 3 point strut tower brace $169(excellent products)
rear end seals $100 installed
Rebuilt 4 disk brake system $25
New brake pads $99
New brake lines $100
KYB shocks and struts $100
new wheels and tires from custom wheel market $1000- fit perfect does not rub 275/40/17
new custom interior $800-had original seats reupholstered redone in black vinyl and red suede inserts with the phoenix embroidered on headrests, new front carpet, redone t-top headliner, redone door panels
new kenwood cd player with install kit $39-my mom works for bestbuy so i got it cheap
new 6x9 speakers $40
new front 4x6 $50
new headlight motors $79 each-pain in the A$$
new paint(after xmas) factory flame red with the phoenix and formula ghosted in black
used washer reservoir $15 with new pump
Motor install $300- guy pulled old one out and installed new motor wired it in and fired it up(great work finished in a day)
PARTS STILL NEEDED
BMR trac pack
BMR subframe connectors
new temp sensor
overflow bottle
6 speed manual
new weather stripping
wire in speed sensor on trans
Hooker headers $170
new fuel line $40
fuel line clips $9
New brake pads $99
new front 4x6 $50
PARTS STILL NEEDED
BMR trac pack
new temp sensor
overflow bottle
6 speed manual
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Re: 91 formula build up
LT1 6 speeds are great man, you will love it. Otherwise, i hate the edelbrock carbs like the one in your pic, Holley is the way i roll.
Nice ride.
Nice ride.
Car: 1989 GTA
Ya i agree on the edelbrock. It was on the motor when I picked it up. It likes to run a little rich on startup but one it warms up she cruises out nice. I only tach 2200 rpms in 5th gear at 70 mph. I also bought a spectre air intake system for it just waiting on it to show up.
Car: 1989 GTA
march pulley system the whole package with msd and carb cost my buddy 7500 it was installed but only had around 50 miles on the motor when i pulled it from the chevelle
