Some Build Pics
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Axle/Gears: 3.55 Wavetrac
Some Build Pics
Some pics of my project. 383 stroker,Eagle 4130 crank,Eagle H-beam rods,SRP pistons,Clevite bearings,Speed-Pro rings,CompXFI cam and 2-piece cover,ATI Super damper.
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Re: Some Build Pics
If anyone replied,I knew it would be you.LOL Link to specs:http://www.compcams.com/Cam_Specs/Ca...?csid=176&sb=2
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Re: Some Build Pics
Because TPI is not easy to tune i would guess.
CARB FTW!
Not a bad cam, not as big as i woulda gone, but then again, i would be looking for the most power possible!.
CARB FTW!
Car: Faster
Engine: Than
Transmission: You!
Re: Some Build Pics
I couldn't remember what ECM/harness you are going with and I cant remember about how the factory ALDL is gonna act if you swap the harness/ECM for SD (when I try to hook my laptop upto it). It's been awhile since I did an SD swap. Cam is still a little on the large side for the factory ECM (even with a tuned PROM), but the bigger cubes might help compensate for that....
Like I said, it's gonna be interesting, not impossible....
Car: SOLD!!!!!
Re: Some Build Pics
darn it i got my vortec 350 sitting in the garage that needs to be rebuilt. this only makes it harder for me to leave it alone till i save some money. nice pics and the best of luck.
Re: Some Build Pics
Very nice build. It's similar to my setup except your cam is a little bigger than mine(that's what she said) and I'm using a SuperRam intake. After several months and hundreds of burned chips I finally got mine tuned. If you don't have a WBO2 invest in one. It will make tuning ALOT easier.
Car: Faster
Engine: Than
Transmission: You!
Re: Some Build Pics
If I can get the laptop to connect to the ALDL after the harness swap, I can datalog and use VE master to straighten out part throttle/cruise tuning. As far as WOT tuning, I should be able to get it close, but doing an A/F ratio scan with a wide-band when he dyno's it will tell me what final tweaks to make on the WOT tables.
Or he could invest in a innovate motorsports LM-1 .......
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Re: Some Build Pics
Re: Some Build Pics
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Re: Some Build Pics
And what will that cost me???
1 Post
Car: 1991 Z28
Engine: 355 TPI
Axle/Gears: 9 bolt disc / 3:27
Re: Some Build Pics
all this hard work going down for the show??? I'll show you a taste of what I've been up to yet I'm not done yet... check out my profile for the project pics if your interested... I didn't go all out like you guys did though... BTW.. the 1st shot is the before... and the after of course the second... but like I said I'm not done
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Re: Some Build Pics
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Re: Some Build Pics
Got the heads installed and valvetrain done.Heads cut to 69cc's for 10.5:1 compression.Crane Gold roller rockers,Manley pushrods,Comp retro roller lifters. Some more pics.
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Re: Some Build Pics
Thanks for the compliment.Going for the contrast of black and grey,like my interior. Using black oxide ARP bolts throughout with the natural alum.finish. If I only had more time to work on it,have been working seven days a week. Maybe this winter things will slow down.
Car: 89 camaro
Engine: 383
Transmission: 350 tci 3000 stall
Re: Some Build Pics
What kinda of paint did you use on those vavle covers??
It looks awesome man!!
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Re: Some Build Pics
http://www.summitracing.com/parts/PRO-141-921/
86CamaroDan
09-29-2015 10:08 PM
