WTB: 350 1 piece rear main roller block, Corpus Christi area.
Car: 87 Z28
Engine: TPI 350
Axle/Gears: 2:73
I need a one piece rear main, roller cam, 350 short block with low miles, or in really good condtion. I can use one that will bore to .030, but that is the max I'll settle for. I would also prefer a 4 bolt block, but that may be hard to find here.
Let me know what you have.
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
Re: WTB: 350 1 piece rear main roller block, Corpus Christi area.
hey Powerslave, if no one has motor here, you can check around at your local wrecking yards & maybe turn up a good one.
Fast355 has put together some interesting motors.
here is a budget build he did that i think may have some useful info for you,
https://www.thirdgen.org/forums/tbi/...i-buildup.html
its pretty close to what i have planned for my SS.
