Cooling fan switch problem
I replaced my cooling fan switch but my fan still isn't turning on when the car get hot 240+. As a test I connected a ground to the switch's wire and the fan turns on, so I believe the wire and fan are OK. Anyone have any ideas how to figure this out? Could the new switch be bad too? Could the block not be grounded or something like that?
Re: Cooling fan switch problem
What kind of car?
What's the ACTUAL temp of the motor? Not what the sporty-wavy-pointer-trim-package thing in the dash says, butt, the ACTUAL temp of the casting near the switch, as measured with your IR temp gun?
