Any difference between 89 700r4 in a V6 and 87 in a trans am
Car: 1987 Trans Am
Just want to make sure the bell housing is the same before I drop the trans from my 2.8 and start beefing it up for the 350 Im going to build
Car: 1992 Pontiac Firebird
Engine: 5.0L L03 TBI
Re: Any difference between 89 700r4 in a V6 and 87 in a trans am
The 2.8/3.1 V6 700R4 trans has the GM Corporate 60 degree V6 bolt pattern bellhousing and the other has the Chevy 4.3 90 degree V6 & SBC/BBC 90 degree V8 bolt pattern bellhousing.
Car: 1987 Trans Am
Car: 1984 Trans AM
Transmission: 700-4r
Yes it means it won't work with a Chevy 350. A Chevy 350 is a 90 degree V8. You will need a 700R4 for a SBC that has a tail housing to mount the torque arm used in a 3rd gen Camaro or Firebird. I guess the tail housing off your 2.8 V6 trans would work. It can't be a 700R4 from a Corvette though as I think the case is different where the tail housing mounts to it. Also don't need the TA mount tail housing if using an aftermarket crossmember that has a TA mount and a aftermarket TA setup that doesn't mount to the transmission tail housing.
Rebuildable cores for a 700R4 transmissions are a dime a dozen. You wouldn't adapt a 60 degree V6 transmission to a 90 degree V8 application when GM made millions of them to fit a 90 degree V8.
Last edited by Airwolfe; Today at 02:35 PM. Reason: Grammar and to make better sense.
The 6-cyl transmission is inferior to a V8 one in several ways (valve body calibration, servo, clutch packs, etc.) as well as not bolting up.
Get a V8 one to use for your core and throw the 6-cyl trash in the trash. Or, put it on craigslist or something, there's sure to be somebody who needs one, maybe not right away, but sooner or later.
T.L. (Today)
