Need help with Hedman headers and y-pipe kit
Car: 1986 iroc z
Engine: 305 tpi 5.0L v8 F Vin
Axle/Gears: Stock?
Hey all, I don't know if im just stupid or if these aren't going to work I bought a pair of Hedman headers and y-pipe off of Facebook marketplace. Dude said they were for a 3rd gen camaro/firebird, of course I took the chance and bought them because it was a good deal. However, the y-pipe doesn't look like it'll fit....my exhaust comes out on the passenger side, cat has been deleted by previous owner. The y-pipe I was given looks like it'll come out on the driver's side. Pictures given. Anyone else who installed these have any tips??
Hedman y-pipe
Stock exhaust, minus cat
Hedman y-pipe
Car: 1992 Pontiac Firebird
Engine: 5.0L L03 TBI
Re: Need help with Hedman headers and y-pipe kit
I've not owned or installed the Hedman Hedders or Y pipe for our cars but it looks like the correct Y pipe assembly for our 3rd gen F-body.
Hedman Hedders Y-Pipe Ball and Socket Type Flange Part Number: 500-17478
Image rotated
Image rotated
The following 2 users liked this post by Airwolfe:
LAFireboyd (10-08-2024), ughmas (10-02-2024)
Car: 1986 iroc z
Axle/Gears: Stock?
do you have pictures of your install on a 3rd gen? The pipe thats supposed to tun under the oil pan comes out on the drivers side and the passenger inlet looks way to long to work....
Car: '90 Formula '88 GTA
Engine: 305 TPI 350 TPI
Transmission: T5 700R4
Axle/Gears: 3.42 10 Bolt 3.27 9 bolt
I'm not really following, your image in the first post looks correct, the outlet comes out on the passenger side, the "long" inlet (top in your photo) is the drivers side not passenger.
I believe they are specifically made to fit the Mid Length hedman headers.
Car: 1986 iroc z
Axle/Gears: Stock?
so, if im getting this right. The short inlet is the passenger side, and the long one is for the drivers side. So the pipe is installed sideways right? I think in getting it now
ughmas (10-02-2024)
yep that should be right- its oriented like the first picture in Airwolfe's post, if you were looking down from the drivers seat
I don't have Hedman exhaust. I have SLP. But it's the same style setup on most all of these shorty/mid length headers and Y pipe.
The short pipe with 90 degree upturn is for the passenger side header and the other pipe and piece with the upturn slid into it is for the driver side header. The Y merge is close to the passenger side front wheel well it makes a turn then runs down parallel to the pinch weld on the car then turns inward and the cat goes there.
ughmas (10-02-2024)
Car: 1986 iroc z
Axle/Gears: Stock?
