DFI and ECM Discuss all aspects of DFI (Digital Fuel Injection), ECMs (Electronic Control Module), scanners, and diagnostic equipment. Fine tune your Third Gen computer system for top performance.
Ebl p4 flash cable
Old 09-28-2024, 03:48 PM
TGO - 10 Year Member
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Ebl p4 flash cable
Does anyone know exactly what kind of cable it is that you connect from your laptop to the communication cable from the ecm on the ebl p4. I misplaced my old one and I'm currently trying to find a replacement. Thanks
Old 09-28-2024, 04:44 PM
Airwolfe's Avatar
Location: Franklin, KY near Beech Bend Raceway, Corvette Plant and Museum.
Car: 1992 Pontiac Firebird
Engine: 5.0L L03 TBI
Re: Ebl p4 flash cable
I don't know what the cable is. @RBob the creator of the EBL system recently passed away. So if you need to download any software or updates or technical data and schematics you might want to get it while you can because who knows how much longer his site will be up for.
Dynamic EFI
RBob - Dynamic EFI - Passed Away
Old 09-29-2024, 08:01 AM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Wow, what a shame to hear the news. Thank you for the advice, I'll try and track one down somehow
Old 09-30-2024, 08:01 AM
dabomb6608's Avatar
Car: 86 Trans Am/85 K5 Jimmy
Engine: 406 FIRST/350 TPI
Transmission: TKO 600/700R4
Axle/Gears: 9Bolt/10Bolt front & back
Pretty sure it is a RJ12 cable (6 internal wires). Make sure it isn't a RJ11 cable (4 internal wires), in the past I tried that and even though it plugged in, data wasn't transmitted.
Then you need the serial port adapter that the RJ12 plugs into and then a serial to usb adapter. The serial to usb needs to have the FTDI chipset.
You can probably find a cable with one end having the RJ12 and the other end having the serial connector. Then you would just need the serial to USB.
Old 09-30-2024, 06:14 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Here is a picture if what the cable looks like. And below is a picture from my car of the port that it plugs into
Old 10-01-2024, 07:21 AM
dabomb6608's Avatar
If that is the P4 then I definitely stand corrected. It is not the RJ11/12 style connector.
I thought the EBL Flash and EBL P4 used the same cable.
Old 10-01-2024, 08:17 AM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
It almost looks like a 3.5 mm jack. I will try one and see if it works.
Old 10-01-2024, 09:00 AM
Street Lethal's Avatar
TTL-232R-5V-AJ
https://ftdichip.com/products/ttl-232r-5v-aj/
- Rob
dabomb6608 (10-01-2024)
Old 10-01-2024, 09:01 AM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Awesome. Thanks so much
Old Today, 08:06 AM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
I found this one locally. Would it work just as well as the one you sent?
https://www.amazon.com/EZSync-RS232-cable-TTL-232R-3V3-AJ-EZSync021/dp/B078K5M3KQ/ref=mp_s_a_1_1_sspa?adgrpid=158299563526&dib=eyJ2IjoiMSJ9.2vvnk6VzpjkE_pcv3N8pZs7pg4MjxLht3gFcB6Ha7HiANi9_uShf58an7EZaD4bysHjYIY7Su3E7yGdh3EKe9orO9IGGADEo98_wDbtiF1jPlFPE1zqdEvlGTDReKTIlIxrH3kaHeZFCBfQkfwqBnlUnKsdNlqAODqUiBF84bOTSFdkf615t2ppYxg1-b438bkW3qEWP8cUAC9Qber2wyw.vCcqI8kjhF4xTgLhLmWmLR7bSYfvOeQZNl4maQEK6rE&dib_tag=se&hvadid=692951196137&hvdev=m&hvexpln=68&hvlocphy=9007136&hvnetw=g&hvocijid=9684423851745895278--&hvqmt=e&hvrand=9684423851745895278&hvtargid=kwd-296510191800&hydadcr=20134_13445625&keywords=ttl-232r-5v-aj&qid=1727960614&sr=8-1-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9waG9uZV9zZWFyY2hfYXRm&psc=1
Old Today, 08:33 AM
The transistor to transistor logic (TTL) with the one you linked appears to be 3.3v...
You need 5v. Try this one here,
Click Here Click Here
- Rob
Old Today, 09:31 AM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Thank you
923.4v6
DIY PROM
08-16-2008 09:09 AM
90c350
DIY PROM
11-12-2007 07:53 AM
Ukraine Train
DIY PROM
05-06-2007 04:19 PM
Arawn
05-04-2002 08:07 PM
craiger
DIY PROM
03-15-2002 06:28 PM
Quick Reply: Ebl p4 flash cable
