Body Side Molding
Car: 1987 Iroc Conv/90 Iroc Conv
Engine: LB9/LB9
Transmission: MM5/Auto
Body Side Molding
Looking for a set of body side door moldings. If anyone out there would have a set, color does not matter as I will be painting them to match the car. PM me if you have anything available. Thank you in advance.
Car: 1984 Trans AM
Transmission: 700-4r
Re: Body Side Molding
My 1984 Trans AM has the factory mounted body sire mouldings which are colour keyed. U hardly know they are present as they blend right in.
Decades ago, I installed the aftermarket body side mouldings on my 1970 Chevelle. Real door ding savers.
U could purchase aftermarket set & have them installed. I would do that.
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
You can buy the 87-92 style that comes in two rolls (82-86 are different). They do have to be cut. I've still got a set, but I'll be using them eventually when I have my car repainted.
IROCIN (09-07-2024)
IROCIN (09-07-2024)
Engine: LB9/LB9
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
Are you looking for a full 6pc set, or just the long ones for the doors? I believe I still have a couple sets of good used ones. But I'm currently out of town and can't double check.
IROCIN (10-12-2024)
Engine: LB9/LB9
Thank you for the offer. I was able to get the full 6 piece set (used) from a guy up in Michigan, so I should be set.
The following 3 users liked this post by IROCIN:
86blackiroc (10-13-2024), chazman (10-12-2024)
Car: 1984 Trans AM
IROCIN (10-13-2024)
Car: 1984 Trans AM
LAFireboyd (Yesterday)
Car: 1984 Trans AM
Nothing better than 3M tapes. Check it out. Good luck. There are companies that actually install the aftermarket bodyside mouldings. They had a jig. Saw this at autorama many years ago in Detroit. Impressive.
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Find the guy who puts all the add-on stuff on new cars.
He prob has a roll of the stuff that closely matches your color.
Prob. install them too for a cash in hand price!
My 84 is red and has factory black bang strips on it.
