SBC Intake 14101076 Question
Re: SBC Intake 14101076 Question
Probably a 87-up carb intake then. The last few such engines in cars were in things like MC SS. Although, I think I recall those intakes being aluminum. In the US anyway; not sure what went on in exports, or stuff like boats, or over-the-counter motors.
Car: 87 Monte Carlo SS
Engine: 89 350TPI Transplant
Transmission: 2004r
Fred
Car: '89 GTA
Engine: ZZ6TPI
I did a Google search on that part number and found a post on a G-Body forum talking about a motor that was pulled from a 1987 Caprice 9C1 (Police Package) that had this intake on it. That would make sense since GM probably wanted the additional durability of the cast iron over the aluminum for police car duty.
Car: 89 Firebird
Engine: 355 TBI
I would say maybe a truck intake but the trucks had TBI in 87 with the introduction to the centerbolt heads. Dont think they had a carbed engine in 87. Bet Fast355 could tell you what it comes from.
Car: '89 GTA
Engine: ZZ6TPI
Correct the trucks were TBI in '87, but the F-bodies, G-Bodies and Caprices had carbed SBC engines 1987. F-bodies and G-bodies used aluminum 4bbl intakes, but it seems that at least the Police Package Caprices may have had a cast iron 4bbl intake. The standard Caprices may have been aluminum intakes, but not sure.
dmccain (10-25-2024)
Engine: LT1, L98
Transmission: ZF6, ZF6
Axle/Gears: 3.45, 3.31
Trucks were carb in '87. Last year of the sq body. Trucks got TBI in '88 with the new GMT400.
Car: 1992 Pontiac Firebird
Engine: 5.0L L03 TBI
Last year of the 1/2 ton C/K series square body trucks was 1987 and it was the first year of the RPO L03 5.0L TBI engine in the trucks.
Engine: LT1, L98
Weird. We had '87 truck in our fleet at work. They all had Q-Jets. None had TBI.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Engine: LT1, L98
I wonder if TBI was a 1/2 ton only thing? All our fleet trucks were 3/4 ton and 1 ton.
I think it was a 1/2 ton only thing. I didn't know you also could get the L05 5.7L TBI too. Mine was a short bed C10 with L03.
The 1/2 ton went to GMT400 in 1988 while I think they still kept making the 3/4 and 1 ton in Square Body style until 1991. I think R/V was the 1988 to 1991 naming instead of C/K.
Car: 1983 G20 Chevy
Car: 1983 G20 Chevy
OK I was thinking that might be why.
Does it just have to be a factory GM cast iron intake manifold? Are any factory GM cast iron intake manifold disallowed in your class?
Reason I ask is because there is a guy on here with the best factory GM cast iron manifold ever made.
Engine: LT1, L98
Airwolfe (Today)
This Bow Tie part is the best stock cast iron (casting #14096242) 4 barrel manifold available. You can get it in 1955 to 1986 bolt pattern or 1987 to 1995 bolt pattern. IDK which one @Tom 400 CFI has.
This is also known as the "marine" intake. It went on boats engines after doing its duty as a Bow Tie intake. If you can get away with running it it will rock and roll.
Ha I wish I could! Them are very nice but better not push my luck! I'm going to try to locate one of these oem intakes sounds like the perfect fit if anyone is interested in getting rid of one!
