It's time to paint!!!!! (Advice, tips, tricks, HELP)
Ok fellas, it's time to do something I have been shying away from for a long time. Please know that I am truly a complete NEWB. I am limited in experience but I am also a sponge. My name is BUDGET BUILDER for a reason. I have more time than $$$ and I don't have the $6k the local shop told me it would cost to align panel perfect, sand ,prime , paint, and buff this thing. I can't afford at thus time a showroom paint job and besides I DRIVE THIS CAR. Pictures are here: https://www.dropbox.com/sc/xk4ca2bmgew010e/AACg-XpHa9ZrsxxP15ymSaupa
Hopefully the pics will come thru I'm just learning to use "dropbox". Any and all suggestions and advice is welcome. I will be using RUSTOLEUM TURBO CAN and going back white. I have a 5in orbital sander. Let me know. Fir real fellas and ladies let me know!
Extrafitkid (07-09-2024)
Car: 1983 Z28
Engine: 385 Fastburn
Re: It's time to paint!!!!! (Advice, tips, tricks, HELP)
Honestly, for $1,000 you can get a 30 gallon compressor, LVLP gun (important, LVLP, no HVLP due to cfm requirements), a decent BC/CC and knock it out in your garage with some tarps hanging up for dust control (or don't worry about dust control). I'd recommend that vs $500 on a bunch of cans.
bottledpower (07-16-2024)
dmccain (09-09-2024)
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
This! the spray can will dissapoint you in more ways than you can count.
Also, whatever you do,.....practive on some junkyard fender / panel....... youll regret messing up on then having to redo / learn as you go on your actual panels.... ask me how I know... You should get it within a few minutes, but messing up the panel will take hours of extra work!
The following 2 users liked this post by 1989karr:
dmccain (09-09-2024), RedLeader289 (07-09-2024)
This is why I asked for advice. For the next 6mo-9mo I just wanted it a single solid color. Next year a real body shop with a real painter. I don't know if anyone seen the pics but the gaps between the panels really bother me. But $6k is something I don't have right now. I only owe $26k on my house so that takes priority. Keep it coming. Thx fellas
https://www.thirdgen.org/forums/body...o-i-paint.html
Imma read this also
https://www.thirdgen.org/forums/body/598772-my-diy-paint-project.html
Imma read this also
Engine: 3.4 / 5.0
If you plan to paint it pro next year. you might want to wait?
its gonan cost you more in the long run to have them redo / strip paint etc.. etc.. especially if you use rattle can.
budget builder (07-13-2024), ughmas (07-10-2024)
Car: 1986 TRANS AM
Engine: LB9
Boss just pay $800.00 on a Macco Special OR Dip Your Car its last a few years and you peel it off. Colors Flat Gloss Satin Hyper-shift etc
Click Link ----> Carbon Blue Car Kit - Browse Our Selection Of Plasti Dip® Colors For Cars! | DipYourCar – DipYourCar.com
The following 2 users liked this post by Extrafitkid:
budget builder (07-13-2024), dmccain (07-10-2024)
Car: 1983 Z28
Getting panels to line up just takes time (and also acceptance that you probably, most likely, in 99/100 cases, aren't going to get perfect lines on a car built in the 80's). Fenders, nose, doors, all are held on with bolts that can be loosened and then you just manhandle the panel and see how much "wiggle" room you have. Get it as close as you can and call it a day. If there is damage or significant rust then get some body hammers and practice fixing the dents, treating the rust, etc.
The following 3 users liked this post by RedLeader289:
I'd just take it to Maaco, but beforehand go ahead and remove any trim, ground effects, etc that you can while still keeping it driveable to the shop. You could even remove the taillights, fender liners, and stuff like that in the parking lot.
Hi ho hi ho off to maaco I go!!!!!
$1826 sand down smooth, to bare metal in some places especially. Hood and fender. Then primer, sealer, then just white..... then I can do the split vette 9.5/10.5 wheels, flush door handles, new window sweeps, black grille w/ red bowtie, smoked marker lights, smoked turn signals, smoked headlight lenses, and smoked taillight lenses. Tint windows, 245f/305r tires.......
then at Xmas 350sbc (out) - ls376/480 w/4l80 (in), Dakota digital dash terminator x ls3 intake headers and 3.90 gear and 3k stall. And retro ac
I'm going to have a ball....... this is not a show/race car
The following 2 users liked this post by budget builder:
1989karr (07-16-2024), Extrafitkid (07-29-2024)
RedLeader289 (09-06-2024)
budget builder (09-12-2024)
budget builder (09-10-2024)
Car: 1988 Pontiac GTA
Engine: 5.7 l98
Axle/Gears: BW 9bolt with torsen carrier
Ok fellas, it's time to do something I have been shying away from for a long time. Please know that I am truly a complete NEWB. I am limited in experience but I am also a sponge. My name is BUDGET BUILDER for a reason. I have more time than $$$ and I don't have the $6k the local shop told me it would cost to align panel perfect, sand ,prime , paint, and buff this thing. I can't afford at thus time a showroom paint job and besides I DRIVE THIS CAR. Pictures are here: https://www.dropbox.com/sc/xk4ca2bmg...rsxxP15ymSaupa
I've learned everybody's idea of a "good" paint job is different. I had mine painted about 10 years ago or so, by a body shop instructor nonetheless. Other people say it looks good, but I think it looks awful. It has urethane wave that no amount of wetsanding can remove, I've tried. And in just the right light, up close, I can see little orbital sanding swirls in the primer underneath the paint. I want to have it painted again, but having a hard time finding anyone I can trust.
All in: $1800
rust sanded down to metal, everything else sanded smooth, prime, urethane sealer, and base coat. 🤷♀️🤷♂️🤷
Imma go with it. Thx fellas
1989karr (09-09-2024)
My Xmas present to myself. 🤞
-Put my 6.2 in ( but take out the hotcam and get a TITAN 4 or ws6 high lift ASA)
-Ls3 intake
-4l80 tranny
-3500 stall
-subfram connectors
-3:90 gear (LS)
Hopefully!!!!!
Xmas or at least before next summer
-Ls3 intake
-4l80 tranny
-3500 stall
-subfram connectors
-3:90 gear (LS)
Hopefully!!!!!
QATransAm
09-17-2002 04:06 PM
