82-92 F-body 1/4 mile times list
Old 04-23-2018, 06:49 AM
UR50SLO's Avatar
Car: 86 Turbo Camaro
Engine: 427LSX
Transmission: 4L80E
Axle/Gears: 9" 3:25
Re: 82-92 F-body 1/4 mile times list
Old 04-23-2018, 09:03 PM
I think I saw the front tires come off the ground half way down the track!
Old 04-28-2018, 10:54 AM
TurboedTPI's Avatar
Car: 92 Formula 350
Engine: L98 with a T-76
Transmission: ArtCarr 700-R4
Axle/Gears: Bone stock 10bolt and 3.23's
*92 Formula 350
*Factory 5.7l L98
*700R4
*255/50r16 M/T drag radial
*unknown weight, (3450-3500 guess)
Aluminum L98 heads, forged pistons, PM rods, TPIS large tube runners, 58mm throttle body, TPIS ZZ9 cam, 1.6 roller rocker, 3200 stall converter, stock rear axle and gears (3.23), 42lb injectors, 255 pump, 76mm turbo, large front mount intercooler, 749 ecm from GMC Typhoon.
10.72@129mph. I cant find the slip.
(pass was with 62mm turbo)
SuperRamFormula (12-10-2019)
Old 04-28-2018, 09:51 PM
Sounds like a neat car but you know I can't add it to the list, right?
Originally Posted by QwkTrip
Post a picture of the time slip, or a video showing the displayed time. If you don’t have either then don’t post.
Old 04-30-2018, 05:54 AM
fasteddi's Avatar
Axle/Gears: Strange S60 4:10s
Vehicle
* 1991 Camaro RS
* Gen1 SBC 385
* Th350
* MT Pro Bracket Radials 28x9x15
* 3200lbs without driver 3380lbs race
* Xr288hr Cam, Howard's hydro roller lifters, 1.6 comp gold rockers, Victor jr intake(2999) Doug's long tube 1 3/4 headers, 11:1 compression, AFR 195 heads, eagle forged rotating assembly, PTC 5000rpm 8 inch stall, Strange s60 4.10 race rear end. Hughes Th350 with a Tbrake, walk to 255lph in tank pump, 6pt cage, Lakewood struts and shocks, all kinds of tubular suspension goodies out back, drag bar, stock front suspension minus struts.
Category
* Internal engine modifications (heads, cam, stroker, etc…)
Time Slip
Milan Dragway Milan,MI
60'............. 1.482
330'........... 4.391
660'........... 6.813
660’ mph.... 100.73
1000'......... 8.941
1320'......... 10.730
1320’ mph… 125.36
Old 04-30-2018, 11:20 AM
VAGOGTA's Avatar
Car: 1987 IROC Z
Engine: OLD SCHOOL SB 383 stroker
Transmission: TH 350
Axle/Gears: F9 3.90 gears 35 spline
Last update with the sbc 383 NA
and on the next race after an aborted launch the car came crashing down too hard and broke the oil pump and #3 and # 4 main caps still we made it to finals but on the semifinal round engine lost oil pressure and we had to shut it off and we saved everthing except the block .
new engine is ready now is a SBC 408 N/A
but I think we need to rework the suspension and maybe add two more wheels
new time and info on set up coming soon and a single digit ticket
Old 04-30-2018, 01:04 PM
antman89iroc's Avatar
Car: 89 IROC
Engine: 6.8 HSR N2O
Transmission: TKO 600
What Block are you running. Chevy? Dart? BTW if you add two more wheel might want to put them in the back to keep that nose down.
Old 05-03-2018, 11:24 AM
TurboedTPI's Avatar
Car: 92 Formula 350
I will look for the time slips when I get time
Old 05-03-2018, 11:47 AM
Car: 89 IROC
Engine: 6.8 HSR N2O
Originally Posted by fasteddi
Vehicle
* 1991 Camaro RS
* Gen1 SBC 385
* Th350
Category
Time Slip
660’ mph.... 100.73
1320’ mph… 125.36
Ok maybe I'm trippin but doesn't that time slip say ET 1254 feet? I've never heard of a drag strip that length. 1/8th, 1000', 1320' sure. Maybe it's a typo or maybe that's at the MPH beams?
Old 05-03-2018, 11:54 AM
Was it in the mag story??
Old 05-03-2018, 12:03 PM
fasteddi's Avatar
There is a 1254 foot sensor on the track. Also a 594 foot sensor.....I think it is the sensor to calculate trap speed.. last 60 foot of track roughly. Remember your end mph on the slip is a average not a speed at 1320foot. It's been there since they changed over the timing system. This is milan dragway in michigian. But all I care about is the 60 330 660 and 1320(hoping to constantly hit those 10.70s or faster once I dial in the new set up better) I also like the 1000 ft for run completion on my DA app.
Old 05-03-2018, 02:49 PM
Car: 89 IROC
Engine: 6.8 HSR N2O
Now I see it, I was confused by the times. 10.37 vs 10.73. Didn't notice they were different. Maybe that's an old school distance they used to run. Let's see, two blocks and past the gas station!
Old 05-03-2018, 03:03 PM
fasteddi's Avatar
haha yea. Well I sure wish I ran 10.20s but 10.70s will have to do for now
Old 05-06-2018, 10:28 PM
izcain's Avatar
Car: 1983 Camaro Z28
Engine: 584
Transmission: TSI Glide
Axle/Gears: Quick performance 9 inch
Let's get this updated. Down to 2890lbs still mild tuneup. Slowly working the bugs out. Yay! 9.28 @ 149.47
Old 05-06-2018, 11:56 PM
VAGOGTA's Avatar
Car: 1987 IROC Z
new combo update and new 1/4 mile ET
1987 Camaro iroc
408 sbc
th350 transmission
9" w/spool 4.30 gears
3050 lbs w/out driver
28x10.5 M/T pro bracket radial
1050 dominator
mxp custom lcas and torque arm
60' 1.343
330 3.995
1/8 6.174
mph 110.46
1000' 8.109
1/4 9.753
mph 137.3
DA 4800 ft
next pic is from a week ago when we got the first runs on the new engine , since then we already fix the "little problem" with the bumper dragging issue
next pic is from a summit series race and we bump up the tune in the new engine
check the 60 fts they are within a thou or two
Old 06-18-2018, 05:06 PM
izcain's Avatar
Engine: 584
Another update.
Old 06-19-2018, 10:12 AM
Car: 89 IROC
Engine: 6.8 HSR N2O
VAGOGTA, those 4' wheel stands are impressive and I'm sure it makes a hell of a show but do you intend to launch that way? Weight transfer is about as much as you could get but it seems it may be faster if it kept the wheels down lower.
Old 06-19-2018, 02:36 PM
izcain's Avatar
Engine: 584
Definitely a crowd pleaser. But you will be quicker once you tie the front end down man!
Old 06-20-2018, 07:29 AM
mw66nova's Avatar
Car: camaro sportcoupe
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
hard to argue with only .003 movement in the 60 over 6 passes though. he goes rounds everytime he goes out. i'm gonna say to leave it alone, lol
Old 06-20-2018, 09:54 AM
Car: 89 IROC
Engine: 6.8 HSR N2O
Hard to argue with those points. Plus it's great to see a "stock bodied" 3rd gen scraping the rear bumper with what appears to be 10.5 rears. Gives me hope.
Old 06-20-2018, 01:33 PM
izcain's Avatar
Engine: 584
Never said he wasn't consistent lol
He will be faster though.
Some guys like doing the same thing every single time though I get that.
Old 06-21-2018, 08:01 AM
mw66nova's Avatar
yeah he's a pretty competitive bracket racer out there, i'd say leave it alone, lol
Old 06-21-2018, 10:49 AM
VAGOGTA's Avatar
Car: 1987 IROC Z
we got the big wheelie under control, it happened the first time out with the new motor we left the same set up that we used with the old 383 engine and we made some changes to the set up and detuned the motor just a little and we went faster on the 60fts and ET.
this ticket is from the event with the big wheelies check the 60 fts 1.336 1/8 6.168 and 1/4 9.797.
the next weekend after we made some changes we went to get the nhra lic, required to run 9.99 o quicker .
we ran 1.359 60ft, 6.203 1/8 @110.32 mph 9.787 1/4 @ 136.79 mph on first full pass
second full pass 1.343 60fts 1/8 6.174 @ 110.46 9.753 @ 137.09 1/4 @ 137.09
the next day we ran the summit series in Irwindale is a 1/8 mile track
here are the tickets :
and we ran quicker in the 60 fts and 1/8 ET
and here is a pic of the car leaving :
Old 06-21-2018, 11:01 AM
VAGOGTA's Avatar
Car: 1987 IROC Z
here is the ticket from the last summit race in Irwindale
we ran a little be quicker in the 60fts 1.222 and ET 6.034 @ 112.24mph
looks like 5's and 1.1's 60fts are around the corner , all this is on all motor and on 10.5 tire and stock type suspension and launching around 3600 rpm.
Old 06-21-2018, 11:57 AM
Car: 89 IROC
Engine: 6.8 HSR N2O
Yes, I would say it's leaving well. While the "looking at the stars" wheelie is cool, this image is my favorite. That is about the most awesome picture of a third gen around. The stock looking body makes it even more impressive. Take the decals off and this could be any car on cruise night that would hurt your feelings if you messed with it!
Old 07-18-2018, 08:40 PM
SloshyBird88's Avatar
Car: 1988 Firebird
Engine: 4.3L
Vehicle
*1988 Firebird
*4.3L
*700r4
*stock 10 bolt 3.42 open
*Mickey Thompson Street ET SS 275/60/15
*3375 at track with me in it
Mods
*Bored .040 over
*Flat top pistons
*232/236 cam
*FI Tech
Category
V6 N/A
Track
* US113 Dragway Delmar DE
Car 7080
*Flat top pistons
Old 07-24-2018, 03:37 PM
Car: 1988 Firebird
Engine: 4.3L
Update : car is back on street tires (215/60/15) starfire rc-2.0. I am car 7080, my brother is car 9621 in his Iroc. Will try to get him to post details for his. Track is US13 Delmar DE.
Attached Thumbnails 82-92 F-body 1/4 mile times list-firebird-vs-iroc-round
Old 07-24-2018, 10:12 PM
Do you want the street tire time posted or the drag radial time?
Old 07-25-2018, 04:48 AM
Car: 1988 Firebird
Engine: 4.3L
Street tire time. Figure since I'm a V6, and that category is next to non existent anyway, I'll just keep updating whenever I go faster and what's changed. Don't think the 3.42 gear was enough with the 28 inch drag radials and that's why I was 3 tenths faster on street tires
Old 07-25-2018, 05:45 AM
mw66nova's Avatar
in for pics of 4.3L in engine bay
Old 07-25-2018, 07:41 AM
fasteddi's Avatar
Yea sadly me Mars and a few others are the only v6s that took it to the next level and raced them for years. Hopefully Mars post his times eventually. Right now my 11.59@119mph is the quickest but he ran many many 10s with his 3900 turbo v6
Old 07-25-2018, 07:00 PM
Car: 1988 Firebird
Engine: 4.3L
Trying to stay NA, its a street car. Believe with a little more gear, a better trans, and a converter, the car can be quicker. Couple pics of when it went in, can take more. Dont want to get the thread off topic
Old 07-25-2018, 10:43 PM
dmccain's Avatar
Saw a 4.3 turbo Cyclone tearing up some Mustangs 25 years or so ago at the track. That lil truck would stroll!
Old 07-26-2018, 08:34 AM
mw66nova's Avatar
i remember seeing a thirdgen comp eliminator competitor 15 or so years ago that ran an n/a 4.3. obviously it had a ton of trickery done to it, but the car ran 8.60's. not a streetcar of course.
point being, it's a neat combo and it looks like you're headed in the right direction. there's a ton to be had in gearing and converter technology as well of course. i bet with some attention to details. that thing will go 12.90's.
Old 07-26-2018, 07:16 PM
Mitch Losh's Avatar
1988 camaro iroc
305 with l98 topend and cam
700r4
245/45/r16 khumo ecsta pa31
3200lbs with out driver and with a full tank of fuel
3.42 10 bolt posi, headers, slp exaust, and tune.
time was run on 87 octane fuel
car 9621 US13 dragway Delmar Delaware
Old 08-11-2018, 07:04 AM
91RS5speed's Avatar
Car: 91 RS
Axle/Gears: Auburn Pro / 3.42
Vehicle
* Year and type of car 1991 Camaro RS
* Engine 305 TPI with TBI heads and cam 161k
* Transmission T-5
* Tire used during the pass (size, brand, model) 245 50 16 BFG Sport Comp2
* Weight without driver (if known) 3200-3300
* Performance modifications (if any)
SLP 1 3/4 headers
SLP Runners
Hawks TPI Ram air boxes
3 inch Magnaflow cat
3 inch Random Technology cat back
3 part March under drive pulleys
Auburn Pro w/3.42
Aluminum drive shaft and drums
Crosslace Wheels
Which category?
** External engine modifications (bolt-ons only)
Attached Thumbnails 82-92 F-body 1/4 mile times list-0810182121.jpg
Old 08-11-2018, 01:01 PM
I need a little guidance what to do with you and Mitch. You both swapped head and cam from one stock part to a different stock part. Did you simply create a "stock" combo that was available from the factory, or did you create a new combo that GM never offered using stock parts?
I'm pretty sure in MItch's case he created a non-stock combo so I landed him in the Internal Engine Mods. Not sure what the answer is for you, 91RS5speed. In cases like this my default answer will be Internal Engine Mods.
Old 08-11-2018, 01:16 PM
Car: 1988 Firebird
Engine: 4.3L
QwkTrip, you are correct on Mitch. We accidentally (didn't verify our purchase) made a 305 with l98 heads and cam. So the cam puts him internally modded.
Old 08-11-2018, 01:28 PM
Thanks.
Hasn't happened yet, but eventually the never ending debate will come up as to whether heads are an internal engine mod or just a bolt on. It's clear from watching this occur at other sites that consensus will never be achieved so I'm going to handle that by just making an executive decision. We'll keep it a mystery which way I'll lean until then...
Old 08-11-2018, 04:09 PM
91RS5speed's Avatar
Car: 91 RS
I just replaced the TBI stuff with TPI. Still has the same heads and cam the car came with. I will go with your judgement on where it should be.
Old 08-11-2018, 04:45 PM
I'm confused... Those are opposite if I'm reading right?
Old 08-11-2018, 04:49 PM
Oh, I think i get it now. You just swapped out the intake from TBI to TPI. I'll move you to bolt ons.
Old 08-17-2018, 04:16 PM
GreggymacZ28's Avatar
Car: 1984 camaro z28
Engine: sbc 383
Transmission: Th400
Axle/Gears: Moser 9", 4.11 gear
Vehicle
* 1984 Camaro Z/28
* 383 sbc
* TH400 w/brake
* Hoosier 28x10.5 Slick
* 3150
* Moser 9", 6 point roll bar, suspension work, etc.
Time Slip
Right Lane (Has my name above the pass):
Cool front photo taken from a recent event:
Car is consistent too!
**Whomped a little on this pass to not take too much thats why mph is down**
Left Lane:
Left Lane:
I dont post on here that often anymore, but last year this car was running 11.0's or so and I ended up winning the Track championship and Driver of the Year at Milan Dragway. This year had some engine troubles so replaced the 355 with the 383 and car picked up a bunch. I try to make around 200-250 passes on this car a year, this year that is really down since I was broke most of the year but luckily borrowed my dads car. Last year went a little harder than most and I think I had around 325 runs on the car that I can collect from the timeslips all over the car lol.
Let me know if you need more info.
-Greg
Old 08-17-2018, 08:56 PM
Great photos
Old 09-26-2018, 12:47 PM
firebrdo88's Avatar
Car: 1988 Pontiac Firebird
Engine: 400 sbc
Axle/Gears: Ford 9" 3.50 35 Spline
Updated:
1988 Firebird
400 sbc
th400 transmission
9" 3.50 gears
305/45R17 M/T ET Street SS radials
Converted Lt1 Intake fuel Injected
Full BMR suspension
175 shot single Nitrous outlet nozzle
best time 9.594 @ 139.39
at Indy
NMCA 2018
Attached Thumbnails 82-92 F-body 1/4 mile times list-img_3102.jpeg
Old 09-28-2018, 03:16 PM
irocdanne's Avatar
Car: 87 Iroc
Engine: Ls 428 F2
Transmission: Th400
Axle/Gears: 3.70
Stockstyle suspension, 3500pounds, Ls428 with procharger F2, E85, trickflow heads, holley Hi Ram intake, custom cam, holley efi, full exhaust. Th400 tranny with brake, protorque converter, 12-bolt rear 33spline 3,73. A lot of streetmiles on it and I drove it in the swedish version of Dragweek called Streetweek.
60ft = 1,35(best is 1.32)
1/8 = 5,63
1/8 speed = 127mph
1/4 = 8,64
1/4 speed = 164mph
200=1/8
Sluttid=1/4
Hastighet=speed km/h
Old 09-28-2018, 03:17 PM
irocdanne's Avatar
Car: 87 Iroc
Engine: Ls 428 F2
Transmission: Th400
Axle/Gears: 3.70
8,80 on this run
Old 09-28-2018, 07:29 PM
Looking for input here....
I'm looking at how the list is maturing and thinking of changing the category definitions to better fit how things are developing. I made a lot of different categories for basically stock cars with different levels of modification, and then an engine swap list to acknowledge that some people do engine swaps. But it turns out that most people posting have custom built engines or swaps. I am thinking I need to do the opposite of what I did earlier and lump the mostly stock cars together (because they are so similar) and do more category break-outs for the custom engines and swaps.
Old 09-29-2018, 07:31 AM
mw66nova's Avatar
i would do 2 categories.
stock (or bolt on only)
modified (everything else)
Old 09-29-2018, 09:29 AM
skinny z's Avatar
Where do you draw the line regarding bolt-on? How about bolt-in like a cam? Or torque converter? Rear gears?
Quick Reply: 82-92 F-body 1/4 mile times list
