Post Your Carb'd Motor Pics
#1301
Car: 87 Trans Am
Engine: 355 Carb. Nitrous 100 shot
Transmission: TCI Performance Trans. 350 Turbo
Axle/Gears: Borg & Warner 9 bolt 3.70 gears
Re: Post Your Carb'd Motor Pics
1st place in best conservative hard top 80 to 89. 2018 Piston power show.
dmccain (03-24-2021)
#1302
Axle/Gears: Strange S60 4:10s
Here is my 509 bbc. I made the headers on a frantic rush after a sbc to bbc swap and needing to get the car back out racing asap. Qfp 950 brawler on top
#1303
Think you'll make the move to a more conventional header arrangement in the future?
While I appreciate all of the aspects of the forward facing header something in my old traditional bones looks for the old school approach.
I didn't much care for the Super Comp version of the big block swap headers (as installed on the 86 TA/502 BBC swap) as they swoop out to the rocker panel area however seeing as that you can build your own....
Hooker Super Comp 2226HKR
The following 2 users liked this post by johnny090881:
1986BANDIT (12-27-2019), NoEmissions84TA (07-31-2021)
#1306
Heres mine. 377 SBC with 850 Holley Quick Fuel.
The following 2 users liked this post by Barent:
1986BANDIT (12-27-2019), FJA1791 (09-12-2019)
Scott's 83' Z (09-16-2021)
NoEmissions84TA (09-13-2019)
1986BANDIT (11-18-2019)
#1312
Car: 82 Turbo (301T) Trans Am
Engine: 301 Turbo V8
Transmission: TH350
Its fun to tweak and tune.. with good gas I can push 15 lbs.. I've reworked the orig design enough to allow for the extra boost.. Did you also fit a Pontiac block into your 3rd gen?.. I used the RH battery box and stock 1980 wiring harness, all my stock gauges work.
The following 2 users liked this post by skinny z:
#1317
454 cubic inch Small Block Chevy........................
#1321
dmccain (03-06-2021)
The following 5 users liked this post by FJA1791:
dmccain (03-15-2021), NoEmissions84TA (07-31-2021), Saxondale (03-15-2021), Scott's 83' Z (09-16-2021), T.L. (03-15-2021)
#1325
Car: '83 Firebird (T/A Clone)
Engine: 350 carbed with L-69 components
Transmission: 700R-4 w/2000 RPM stall converter
Axle/Gears: 10-bolt/3.73 ..
Getting there...
The following 2 users liked this post by T.L.:
#1328
Car: 87 Camaro Z/28
Engine: 327 SBC, 495/481 lift, Dem 625cfm
Transmission: B&M TH350 Stage 2
Axle/Gears: 3.90
327 SBC New Demon 625 cfm. A lot like the old quadrajet, smaller primaries with larger secondaries.
dmccain (08-06-2021)
#1331
Export LG4 305. Edelbrock Performer 2101 intake, Accel distributor, M4ME Quadrajet, Lunati 420/443 cam, 1.5” headers. The air cleaner “just” clears the hood liner with the intake and fresh engine mounts.
skinny z (03-29-2022)
#1335
@mw66nova Beautiful!!!
Which Cylinder-Heads do you have, moving all the Fuel and Air that your Dual Pro-Systems 4150s provide?
Truly Beautiful! ...the Engine is; no arguments will be had here.
I love it!
I love it!
#1337
Car: 1984 Pontiac Trans Am
Engine: 406 Stroker
Transmission: Powerglide
Quick shot of mine, new to the forum! 84 T/A with a built glide, and a 406 SBC with a Barry Grant 1050cfm 4150 four-barrel.
RU-QWIK
12-21-2002 03:22 PM
