Looking for the right BIN, XDF, and ADX or ADS File - 87 Camaro 350
Good Afternoon Everyone. I am just getting started with this programming PROM thing. I can't seem to get off the right foot and find the correct files for Tuner Pro RT. I was reading the how to stickies and I need the BIN file, XDF, and ADX (or ADS) file to get going. But I cannot find this for the 1987 Camaro 350 5.7 TPI. I looked on all the linked websites, this is most likely due to my experience in what work with what. Any help is appreciated. Thank you very much in advance for the help.
Re: Looking for the right BIN, XDF, and ADX or ADS File - 87 Camaro 350
Download the ARAP.bin and 32B xdf from TunerPro.net. There is a corresponding ads file that you can save and use tunerpro to convert to adx. I'm guessing you have the 165 ecm? Are you running a MAF set up or SD?
Car: check
Engine: check
Transmission: check
If you go with the suggested ARAP BIN, need to use mask $6E stuff. It is a different calibration layout.
RBob.
Looks like I’ll need to make some changes. Thanks!
$6e adx and bins
http://www.gearhead-efi.com/Fuel-Inj...Information-6E
A $32b ads you can try
http://www.gearhead-efi.com/Fuel-Inj...nformation-32B
$6e adx and bins
Thank you !
