Best T-Top Sunsahdes
Old 05-30-2017, 01:02 PM
Dartht33bagger's Avatar
Car: 1991 Z28
Engine: L31-R 350 w/ EBL P4
I'm tired of having to wear a hat when I drive my car in the summer and I'm tired of all of the heat the T-Tops let in. I'm going to purchase some sunshades and I can across these two online:
http://www.hawksmotorsports.com/cama...top-sunshades/
http://www.yofab.com/third-3rd-gen-c...des-1982-1992/
The Hawks ones look nice but I'm not sure how much they reflect the sunlight to keep the heat down. Also at $105 after shipping is included that seems pretty steep. Another possibility is to find a local interior shop that would make some for me when I get my headliner redone this summer. What would you guys recommend?
Old 05-30-2017, 02:47 PM
Vinscully50's Avatar
Car: 1986 Camaro IROC Z
Engine: LB9 305 TPI
Re: Best T-Top Sunsahdes
I brought the ones from Hawks and they work great for me and I am in Florida.
They seem to help keep the heat down.
Old 05-30-2017, 04:02 PM
LS2Swapped92's Avatar
I have the hawks ones, they helped keep sun/heat out about 80% better than what it was before. It's actually enjoyable to drive now with the sun out in full force. Before my scalp used to be on fire lol.
Word of caution, they are flimsy as hell. You will need to add longer strips of velcro to support the center and sides better. I haven't done this yet, and they like to sag in the middle and fall out sometimes.
Old 05-30-2017, 04:30 PM
The OE shades are so simple they'd be easy to replicate. They're just ~3/32" thick black paperboard covered in headliner fur on one side. Then they finished the edges with a strip of cloth wrapped over the edges, and stitched. Local upholstery shop should have no problem. The edge is the only part that's remotely difficult, since the ol' lady's Kenmore sewing machine isn't up to sewing through cardboard. But for that matter, a person could probably get away with gluing the trim.
Old 05-30-2017, 09:37 PM
Davidgou's Avatar
Car: '88 Black GTA, T-tops, digital dash
Engine: 5.7 TPI w/custom chip
Axle/Gears: 9 bolt 327 posi
that's what I'm planning on doing since my original shades were destroyed over time.
Old 05-30-2017, 09:55 PM
Car: 1991 Z28
That basic huh? It seems like the black would absorb a lot of heat vs a white paper board. I was even playing with the idea of buying one of those reflective car window shades and cutting out two squares to fit the T-Tops then putting fabric on the bottom of them. That way they would reflect the sun out. It may look terrible through the T-Top glass though.
Old 05-30-2017, 10:53 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
I made mine from pieces of cardboard & they're pretty old now, still work fine.Mine are black & C&C t-tops as well.
Old 06-02-2017, 12:43 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
I got mine from 1A Perfect match.
https://www.1aauto.com/1982-92-chevy...=948077&y=1986
Old 06-02-2017, 03:19 PM
GASPEDDLER's Avatar
I have a set from IA Auto, they are a must in south Texas where summer is year round. Love them!
Old 06-02-2017, 04:14 PM
Davidgou's Avatar
Those look nice. How long have you guys had them?
Old 06-02-2017, 04:36 PM
Hal87's Avatar
Car: '84 Firebird TA & '87 Camaro LT
Engine: 350 V-8 & V-6
Axle/Gears: 3.23 & 3.42
Originally Posted by mantaguy
Old 06-04-2017, 08:52 AM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
I purchased originals from CoverCraft years ago that were already "dead". What I mean by that is the headliner material on the backer board is dead, so they are worthless, but the board makes a perfect template for a shop to make new ones. When I got my headliner replaced, I had the shop make me the shades with the same material and lot number. CoverCraft was the original manufacturer of the OEM shades.
If anybody wants an original as a template, let me know. I paid $60 for 6 of the originals. Some of the boxes are still sealed, so not sure what condition they are in.
Old 06-04-2017, 10:14 AM
Davidgou's Avatar
I'm interested in a pair. How much shipped to 33024?
Old 06-04-2017, 12:56 PM
scottmoyer's Avatar
Sorry. I forgot to mention that they are all one side. For the template, if you remove the failed headliner, you can recreate new ones using the same shade backing. That's what I did. I removed the headliner material and used the same board for both sides, just flipped it over. I did like Drew said and used the heavy black cardboard for my new ones.
Let me know if you're still interested in one or more than one
Old 06-04-2017, 02:22 PM
Davidgou's Avatar
Yes. I'm still interested in two of them.
Old 06-07-2017, 08:03 AM
Galaxie500XL's Avatar
Car: 1988 IROC-Z
Transmission: T56 swap ongoing
Axle/Gears: 2.77 9-bolt Posi
I got lucky a few weeks ago, and found a set of the factory shades in an '88 IROC, in the t-top bag. I only paid $10.00 for them. They're a nice addition, especially on hot sunny days.
Factory T-top shades.
Old 06-08-2017, 09:06 PM
$10 and in good shape. That's a rare deal.
Old 06-09-2017, 12:49 AM
Car: 1988 IROC-Z
It was a good day. The same car also had a vinyl cargo cover, which cost me $35.00.
Old 06-13-2017, 08:41 AM
gtoger's Avatar
I got the YoFab ones for my 1986 with factory T-tops. Wouldn't recommend them. They fit... OK. They look pretty cheap. It's just black plastic, and they intend for you to put adhesive on the glass to help support the plastic from sagging. Meh. There was zero reduction in heat, which you could just feel radiate from the black plastic which then gets soft and melty. I cut up an old reflective foil windshield screen to put between the top and the black plastic. That helped a lot.
Old 06-13-2017, 05:12 PM
scottmoyer's Avatar
Davidgou, I apologize for not responding to your request. I've been busy and the shades are in storage. If you're not in a hurry, I'll try to get them out this week and get you a quote. Otherwise, if you get up to Orlando, I can get them to you without shipping costs.
Old 06-09-2018, 08:04 AM
SirReveller's Avatar
Car: '89 'ROC
Engine: 5.7L
Good thread. Killing the sauna effect when parked somewhere in the sun for a long time was on my list for this summer. Do the 1aauto ones also require the little velcro stickers or do they sit just clumped right on?
Old 06-09-2018, 01:30 PM
mantaguy's Avatar
Engine: 5.0 EFI
Yes,they have the Velcro Tabs
Old 06-09-2018, 05:10 PM
On Probation
sonjaab's Avatar
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
My 84 Z came with a set of hard plastic shades that look exactly like
these GM units:
(on-line pic)
The ***** on the exposed side are connected to a suction cup that stick to the
t-top. The shades are a bit larger than the t-top opening and the top fits over
them and hold them in place.
Old 06-09-2018, 05:30 PM
these GM units:
Interesting. I've never seen those before. So do they extend between the weatherstrip and the glass?
Old 06-09-2018, 05:48 PM
On Probation
sonjaab's Avatar
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
YES,
They are a bit larger than the top opening so the top itself is pinched in place.
I did have pics of my set around here somewhere or i will take new shots and post.
Mine have no printing or part #s on them IIRC.
There is a metal sticker/plate on them but the printing on it is about worn off.
YES,
Old 06-09-2018, 07:53 PM
Car: '89 'ROC
Engine: 5.7L
Well that’s interesting. No drooping fabric problems there. The other oddity that came up
https://www.thirdgen.org/forums/exte...ogic-soft.html
Searched around a bit and while board not plastic these seem pretty cost effective vs all the $80/100 versions.
https://www.camarocentral.com/1982_1...p/dwn-1013.htm
Old 06-09-2018, 08:04 PM
$39.95 is certainly cheap enough.
Old 06-09-2018, 08:37 PM
dmccain's Avatar
Friend of mine got mine and his wife is going to make us a few sets. They help when the temps reach 100 down here. You can't beat that $39.95 set though that's a good deal well worth it i m sure.
Old 06-09-2018, 09:52 PM
GASPEDDLER's Avatar
They come with Velcro pieces for the corners but aren’t necessary as they tuck into and are held by the headliner and ttop side bar.
Old 06-09-2018, 11:59 PM
Car: '89 'ROC
Engine: 5.7L
Ahh gotchya. Thanks peddler.
I’ll report back on just how “cheap” the camaro central shades are...
Old 06-11-2018, 06:35 PM
Car: 1988 IROC-Z
I’m definitely interested. I have some originals with severely droopy fabric.
Old 06-11-2018, 06:54 PM
mantaguy's Avatar
Engine: 5.0 EFI
The ones from Camarocentral are shaped different then the stock version That 1a offers.are Camaros different then the Firebirds?
Old 06-11-2018, 07:15 PM
Car: '89 'ROC
Engine: 5.7L
Are they? I didn’t notice that.
Old 06-11-2018, 07:47 PM
mantaguy's Avatar
Engine: 5.0 EFI
https://redirect.viglink.com/?format...6amp%3By%3D198
https://redirect.viglink.com/?format...2Fdwn-1013.htm
Old 06-11-2018, 08:02 PM
Car: '89 'ROC
Engine: 5.7L
Camaro and Firebird t-tops should be identical to my knowledge.
Camarocentral:
Snaps into place without the use of tools or clips.
So I suspect the shape may mean it clumps in so ya don’t have to use the Velcro stickies.
...or it could be cheap ill-fitting ****.
Old 06-11-2018, 10:11 PM
Abubaca's Avatar
Car: 2016 Camaro SS + ???
I've been considering these too. Hot hot hot. ....obviously these are removable. Anyone ever consider a high UV blocking tint? Obviously not for the "stock" crowd. -I've considered looking for an extra set of tops on CL and tinting one set.
Old 06-11-2018, 10:23 PM
Technically, you don't need to use the velcro dots with the factory shades. Mine still have the peel off backings on them, never been peeled and stuck to the glass, er... Plastic... The outer edge slips under the plastic trim, and the inner edge will sit on top of the T-bar. The Velcro just helps keep them from falling out when you remove the tops.
Old 06-11-2018, 10:25 PM
How about paint? Solid coat of aluminum paint, then a solid coat of black or paint to match the headliner.
Old 06-12-2018, 10:08 AM
I'd like to have some of this in clear for all the glass, t-tops included.
Old 06-14-2018, 07:28 PM
Car: '89 'ROC
Engine: 5.7L
Well the 40 buckers arrived from camarocentral. Nice medium gray fabric as ordered, solid stitching..no velcro I wouldn’t use..pretty sturdy...great!
...until I flip them over:
Bare cardboard! Lol. I think you could definitely see this through normal t-top tint.
Well ya get what ya pay for. I’ll save my final verdict since fit is pending (my shop is dragging *** on a slew of mods) but a can of black spray paint and hopefully these should do fine.
Old 06-15-2018, 12:27 AM
The original sun shades are just flat black cardboard on the top side. NBD.
Aside from the vinyl piping and the ferules covering the seam, those look pretty close to the real deal.
