What Hardware for airbox???
Guys, what hardware/fasteners go here in these holes? I've got the filters in the lower box, and the upper box sealed to the lower via the spring loaded twist clips, but I haven't had the whole assembly fastened to the nose and radiator support in 15 years!!!!!!! ....finally getting around to fixing all the little stuff. Anyhow, I know that along the radiator support it uses push pins/clips which I have, but it looks like the front 5 along the front edge, and 1 each on the left and right use screws. Anyone have a pic? I did dig out one the female body clips attached to the nose, so I can figure out the thread, but what does the actual fastener look like?
Received 1,863 Likes
Re: What Hardware for airbox???
Yup; just yerbasic #8 screw, about ¾" long, 7mm hex head, large floating washer. There's A BUNCH of them all around there you can look at to match against.
W.E.G.
04-28-2018 07:24 AM
