Post your firebird pics
#2203
Car: 92 Firebird Formula
Engine: 5.0 tbi
Transmission: 700r4/shift-kit
Axle/Gears: 4.11/posi
#2209
Engine: 5.0 tbi
Re: Post your firebird pics
Nice 89 Nathan! Keep updating picts. Got mine cleaned up and drove to work today. Like the power buldge hood little more than the cowl scoop .
#2210
Something about a white Formula. They just look soooo clean. Nevery actually seen one in person.
#2219
Car: 1990 Trans Am
Axle/Gears: 3.08 posi
Haven’t posted in a while been too lazy to take any pics lol. No updates still cruising and tuning. May eventually buy some mini latches for hood and paint or wrap it, still unsure. Also some pics of my buddy at track.
And a random bird I saw not too long ago
#2220
Car: 1986 trans am
Engine: 305/350
Transmission: 5 speed
were the four hood pins necessary to pull the bow out of the hood and make
it fit better?i actually think it looks really good on that car but have seen the
RA11 hood on some cars and i dislike it.it would look amazing lowered a bit,mine has the same issue but the crappy roads around my area make me rethink doing it.
that definitely is a beautiful gta
#2221
Car: 1990 Trans Am
yep other than that it fits great....I mocked some studs to work for now and eventually I’ll buy some 30 dollar mini latches....yours looks like it fits great...lowering would look great but some backroads I have to go on needs that extra inch lol atleast in wv...mines not a gta, trans am with gta badges but thanks for the nice words!
#2222
Car: 1986 trans am
Engine: 305/350
i had to mess around with my hood to get it to look this good and im still not happy.it has more of a curve on the opposite side,i just made up some of my own hoodpins too but haven't installed them yet.the gta emblems look great on your car,i was thinking of doing that as well and if i can find some i might just do that.were did you get them?
#2223
Car: 1990 Trans Am
^ebay, yea I think the cleanest look would be to buy mini latches unless you are skilled at body work or pay a shop. I’ll look forward to your final results. However yours looks close enough if you use standard hood pins in front it may bring down the whole hood enough to minimize curve.
#2224
Car: 1986 trans am
Engine: 305/350
i really like the look of the locking latches that hide the pin under a small cover but they arent small and require a far bit of cutting and fabrication.with mine im thinking just the hood pins and a little more adjustment will be enough,did you make your ram air functional?also ,have you considered a wrap,i wanted to get white carbon fiber(or even black but white would be different) but it will cost as much as painting the hood body color at a shop.
#2225
Car: 1990 Trans Am
^agreed with the hideaway latches too much cutting for me but look great. I’m in the process of making ram air functional... as of now I have one nostril cut feeding air to a cone filter but eventually want to find a ram air box.
and haven’t decided on wraps or paint or leave as is....it’s honestly nice to not have to worry about chipped paint ....like the wrap ideas you mention though!
#2226
Car: 1986 trans am
Engine: 305/350
i was thinking of sealing my 14"x4" open element air cleaner to my cowl hood so it draws only cool air in as well,i wish it wasn't 100 degrees out but its better than 2 feet of snow,lol(too dang hot to wrench on the car)
#2227
Car: 1984 T/A
Engine: LQ4
Other than the radio its bone stock down to the original cat and exhaust. Its all coming out. LS with new interior
#2230
Car: '84 Firebird TA & '87 Camaro LT
Engine: 350 V-8 & V-6
Axle/Gears: 3.23 & 3.42
Thanks. Taken in Sunlight Basin just east of Yellowstone Park. Went over the Beartooth Hiway (lots of switch backs, 10,000'+ elevation) from Red Lodge Mt and through Yellowstone Park with the Tee tops off! Only way to see it!
#2231
Car: 1990 Trans Am
^absolutely gorgeous I hope to see Yellowstone one day .... roads sound fun! In wv have similar roads extremely fun cruising or spirited driving, and tops off!!! Very cool pic !!!
#2232
Car: 1990 Trans Am
Just glad to be driving.... beautiful weather in the mountains!!!
#2233
Car: 1986 Trans Am
Engine: V8 305 LB9 5.0 T.P.I
Transmission: THM 700 R4 Auto
This is my first time back on this site in about 12-13 years. Heres a shot of my 1986 Recaro Trans Am back then before the motor blew and how it looks now after finally pulling it out of the garage where it sat untouched or all that time. Rebuild starts this weekend!
-Adam
-Adam
#2234
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
-Adam
-Adam
#2236
Car: 1990 Trans Am
^nice!!! Had to research the ignition setup on your sbc...very cool btw!
#2245
Car: 1986 trans am
Engine: 305/350
yes i did and i completely winged the color match and it came out (just about)perfect,i also painted my spoiler at the same time but i haven't put it on yet(rs high rise).
the issue with it is it doesn't have studs but has the holes for 1/4 20 studs/bolts(stripped maybe?)do you think i could use a slightly larger self tapping bolt to mount it
or should i epoxy studs back into the holes?
now i have an opportunity to trade my new wheels for these wheels,what do you think,whats your preference between the two?
1986BANDIT (08-22-2019)
#2249
Car: 1990 Trans Am
@1986bandit, not sure on spoiler studs maybe someone can chime in...I like the wheels on now but really both should look good.
