Double Din Radio Bezel
#101
Car: 91 Camaro RS
Engine: TBI 305
Re: Double Din Radio Bezel
This is what I ordered:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
The plate with the oversized opening will be up before the end of the day.
Make sure you measure the radio before you order a bezel.
Although you can always file the bottom edge of the opening down to fit the oversized radios.
Thanks for your hard work...also I am so copying you and getting one of those radios hell I may by one for me and one for my wife's trailblazer since she needs a new radio as well. Before I was looking at getting an Android auto radio but those are all kinda costly.
#105
I had another one printed with treat stock this time wow there is a big difference in what people charge got one coming to me with shipping and everything for $16 this time Beats the 57$ from last time
#110
Reverse plate files have been updated to put the tab on the correct side.
Also finish the paint on the bike parts. More time for car stuff. For those interested pic attached.
#112
Car: 91 Firebird
Thank you for your work, I updated my first post to include the information on the files you contributed, and the ones from Cehbra as well. That way everyone doesn't have to dig through three pages to see what worked or didn't work.
#121
The standard double DIN opening is 180x100 mm, so any HU that is slightly smaller than that will fit. If you don't like the gap on each side you could fabricate a frame of some black material that fits flush on your radio and covers that gap from underneath the bezel.
Tanderson0318 (01-17-2020)
#122
Got the double din bezel filed and fitted to the car. I got the spacers on the climate control. Everything is fitting very well. I'm very happy with this piece and those spacers are not something I would have thought about till after the fact. Those put that climate control right where it needed to be. I still need to texture coat and paint the bezel. Here are some pictures. I'll post more when I get finished.
#124
Car: 91 Firebird
#125
Car: '89 Iroc
Engine: 383 TPI
Transmission: Built 700R4
Axle/Gears: 9 Bolt - 3.45
Interested in ordering the double din bezel for Camaro. Can anyone direct me to the latest link or proper file to use when ordering from somewhere? Thank you!
#126
The links are on the 1st post. Where those file are is up to date. It just comes down to what you what/need.
#127
Car: '89 Iroc
Engine: 383 TPI
https://www.thingiverse.com/thing:2194376
So then tried to "Order this printed" through 3Dhubs and it shows a bulbasaur file that i'm ordering not the bezel.
Maybe I'm looking at something wrong, which wouldn't doubt
#128
Car: '89 Iroc
Engine: 383 TPI
Yep, I followed the first link in the post and it took me here...
#129
Car: '89 Iroc
Engine: 383 TPI
#130
That does look great. I found pictures of other double din radio bezels and it looks like the openings on these are not as wide as your plate design. The heights on these and yours look the same, but the opening looks wider than what a double din would require. What was the test radio you used for the opening size. I have a Pioneer AVH-4100NEX and it looks more like the radio in third picture.
#132
Car: 92 RS
I was wondering how you liked your radio darkangel. I have been thinking about doing a double din for some time now and that HU looks nice. Also never having anything printed or even looked at the files are the hvac spacers in that file for the reversed print?
#133
I really like the head unit. its currently in my truck. The reversed plate does have the spacer files available to download/print.
#134
Car: 92 RS
Cool. I went ahead and ordered one to give it a try. Any printer service people are using in particular? One that has good prices and quality.
#135
Car: camaro84.87iroc,91vert
Engine: Lt1, 383tpi,350tbi
Transmission: t56,T5,T5
Axle/Gears: 4thgenunknown,373,323?
I’m not a fan of the flip, I’ve been doing car audio over 20 years and might just be stuck in old ways, but I do appreciate what it takes to put something somewhere it wasn’t designated to be. Congrats on the hard work.
#136
$22.62 plus shipping.
I wasn't satisfied with the one he sent. He's remaking and sending. The first one was set up and has a wavy texture on the front. He says he change the setup so front is flat.
IROCullan (08-18-2020)
#139
This is really cool, especially the option of putting the HVAC controls on the bottom! I only see that option for the Camaros though. What about firebirds? Would love to have the controls lowered and be able to put in a nice double DIN.
Great work guys!
Great work guys!
#140
It's a lot harder to pull an inverted hvac mount off in the firebird since it uses a pod rather than a solid console like the camaro does. You'd have to cut away a lot of the rear structure in the pod and rebuild it to support the higher weight centre of the new stereo location. Not saying it can't be done, just that it's a lot more involved.
#141
Maptechenterprises has some nice single din hu mounts for both our camaro and firebird/ta for a easy custom look.
#143
If i have a Firebird laying around, I'm sure i can come up with a printable kit to do this. At this time i just don't have access to a Firebird to do so.
#145
Car: 91 Z28
Transmission: 5 Speed
Axle/Gears: G92 (3.42)
I recently got a 3d printer as I really wanted to get into making parts for my camaro. This is one of the mods I really wanted to do but I was wondering and sorry if this is a stupid question; since I printed out the radio Bezel itself and painted it with texture paint I also printed the spacers for the reverses Bezel and was looking for more insight on how 7thdarkangel used the spacers? Again sorry if this is stupid question but any insight is appreciated!
The following 2 users liked this post by G92-Z28:
IROCullan (08-18-2020), TWON_3rdGEN (11-23-2019)
#146
Check out post 67 and 69. If those pictures aren't clear enough ill dig the parts out and snap some better pictures. My car is currently living in a bunch of boxes.
Finished bezel looks good. Nice work. What material did you end up using?
#147
Car: 91 Z28
Thank you I must’ve missed the picture before with the spacers I can see them better now. I was going to print it in abs but being new to 3d printing I felt the pla was pretty durable and just went with that. I’m very happy with it and thanks for your work designing the Bezel it’s very nice!
#148
Car: 91 Z28
I received my radio yesterday after a little filing and touching up the paint fits perfect and looks good!
#149
That looks really good. What specific texture paint did you use?
#150
Car: 91 Z28
I used SEM Texture Coating 39853. I test mounted it in the car and it matched really well and looked almost stock. Here’s another pic...
There is a little modification neeed to move the heater controls down but anything custom needs a little work. Overall if I could just get more time to finish things up it’s going to turn out well.
