Jeep cherokee and Astro van steering shafts
#154
Re: Jeep cherokee and Astro van steering shafts
Mine just arrived today, 2 combos...
#156
Car: 92 RS Hardtop
Engine: soon to be LS
Transmission: soon to be T56
I'm interested in an astro combo. I may have missed it, is it a new column bearing or used?
#158
Car: 92 RS Hardtop
#159
Car: 92 RS Hardtop
Got the package in Saturday. Looks good! Added to the parts stash for when assembly starts next month.
Thank you!
Thank you!
#166
Got mine a week ago. Haven't had a chance to install it but everything definitely looks good2go
#169
I want an Astro van version if you have anymore left. I just finished watching Lsxmatt's video now I gotta have one! if you dont mine sending me the paypal info.
#173
Car: 92 RS Hardtop
#180
Car: 1983 Chevrolet Camaro Z28
Engine: LS3
Transmission: Tick TR6060 w/ Mantic 9000 clutch
Axle/Gears: Strange S60 w/ 3.73 True Trac
I PM'd you Robert Frank, really looking forward to getting one of these!
#183
Ok anyone who put out orders last week, everything is going in the mail today. I do have two more shafts ready to go. I also have one Astro bearing left. $75 shipped to the lower 48. PayPal is rfrank1980@yahoo.com
#188
Car: 1989 Firebird KITT Replica
Engine: 305 TBI L03
Finally had a chance to install this mod today (shaft and bearing). Everyone makes it look easy in the videos, and yes, in theory, it should be easy, but MAN, what a PAIN THE THE ****!!
Unbolting near the power steering pump was easy, as was near the firewall. Sliding off near the PS pump, relatively easy. Sliding it off at the other end, ARGH!!! took me maybe an hour to wiggle it off, beat it with a hammer at weird angles etc. Finally got the idea to turn the wheel a half turn to expose the thru-bolt hole and use a screwdriver as leverage. Voila!
Then the dreaded bearing. The old bushing is rubber, so it doesnt just slide off. Again, more wiggling and turning to get it off.
Finally got that off, and low and behold, my Astro bearing does NOT fit at all. It does not fit on my steering column. I cant even get it started. Seems like the bearing is too small, although it looks the same size as my old bushing. Very weird. If anything, it would have to be pressed on, but at this funny angle and clearance, good luck with that.
Trying now to wrestle the old bushing back into place....ugh. Hopefully the steering shaft itself will be easy to install.
#190
#191
Engine: 305 TBI L03
Nope, bought one from the seller here, the OP of this thread. Looks like a used astro bearing to me.
Just cleaned up the shaft, lubed it, but I cannot even get the bearing on at all, not even straight enough to hammer it on. Oh well
#192
Have you seen this vid on you tube? It was quite helpful when I was installing mine which I got from the wrecking yard. Where in L.A. are you?
https://www.thirdgen.org/forums/susp...g-bearing.html
#195
Ok everyone who ordered a shaft last week they will all be shipped out first thing tomorrow morning. I got into an accident at work and it put me a little behind but all is good now. I do have three more Astro shafts available.
#197
Car: 1986
Transmission: t56
Axle/Gears: Auburn 3.73 posi moser axles
I sent you a pm i would like one of your shafts and bearings
#198
Car: 1988 GTA Black on Black Hardtop
Engine: 383 miniram/ Ebl
Transmission: 700r4/Performabuilt/3000 Stall
Axle/Gears: 9 bolt / 3.27
pm sent
#200
you still have both shafts and what prices are they running with shipping?
