Help Identifying Holley Throttle Body Year
I bought this Holley aftermarket Throttle Body many years ago and I was asked if it would bolt onto a '89 car.
I don't see where the typical Holley112-xxx part number is stamped on here. The only numbers appear to be "11323 1 161 5"
Does anyone know if this will work for all years TPI? Or what should I look for to distinguish the years?
I plan on calling holley on Tuesday when they open, hopefully they're not shutdown for the holiday.
Thanks!
Thanks!
Re: Help Identifying Holley Throttle Body Year
Thanks for the reply, I'm not entirely clear about where the drilling would need to occur.
I do see a coolant passage between the two bores in the plenum, is this good?
Would someone be able to use PAINT or something to sketch where the drilling would be needed?
truckguy
10-24-2016 02:23 PM
camarofan411
06-04-2015 01:53 PM
dredre08
04-01-2011 09:48 AM
