STRUT BAR
STRUT BAR
well long story short Im in the middle of switching from a TPI set up to a HSR an my BMR 3 point bar doesn't fit anymore so
I want to see pic of anyone that has a STB with a carb set up.
trying to figure out if it will work or am I gonna have to make one..
Re: STRUT BAR
Not sure you'll find one that'll work. I know edelbrock used to make a carb/TBI brace, but I think even if you go in front the HSR, you're going to run into issues with the intake tubing.
Anything is possible though, so I'll keep and eye out to see what you come up with, or find that works. I know a lot of the HSR guys would be interested.
Re: STRUT BAR
If you decide to start with the old Edelbrock design, QA1 bought that from Edelbrock, and still makes them.
https://www.qa1.net/suspension/stree...t-tower-braces
Re: STRUT BAR
Tibo, do you have a pic from the side? Do you think it'd clear the throttle body on a TPI or HSR? Some pics of that brace make it look like it's possible, others look nowhere close. In your pic, it looks like it would ever so slightly tuck in right under the cast oval-inlet part of the TB, just in front of the IAC housing. (HSR) ....but again....so hard to really see.
....of course, if it WERE possible, I'm sure Eddy/QA1 would be quick to point that out!
Steven6282
03-23-2012 02:19 AM
mbarland
03-28-2001 05:36 PM
