Flowmaster exhaust, headers, cowl hood, stock hood
Car: 91' camaro rs
Engine: Sbc 327
Axle/Gears: Stock 10 bolt w/posi 3.90 gears
For sale is a full exhaust system off my 91 rs that had the 305 single cat. It's the flowmaster 3" American thunder. 1 5/8" shorty headman headers with the headman y pipe. I had it set up with no cat. Couple small dents on side muffler, not a big deal at all. $300 pickup only.
I also have a 4" cowl hood fiberglass, I think it's a harwood. I decided to go with a steel 2" cowl hood. It has 4 pin holes 1 in each corner. It is a bolt on hood. It needs the gel coat fixed at the bottom of the hood. $250 pickup only.
Stock rs hood no hinges or latch. Good shape. $80 pickup only.
Car: 91' camaro rs
Engine: Sbc 327
Re: Flowmaster exhaust, headers, cowl hood, stock hood
Hi, I'm up on the iron range by Nashwauk.
Car: 91' camaro rs
Engine: Sbc 327
I'd also consider trading for suspension upgrades such as lowering springs, koni yellows, Kyb agx, adjustable panhard bar, tubular control arms, relocate control arm bracket, subframe connectors, ls style t56, tko 600, steel sfi bell, brembo brakes, pro 5.0 shifter, long tube 1 3/4 headers, basically anything that improves the car I'd be interested in.
Car: 1988 Irocz
Engine: 350 sbc
Axle/Gears: 3.42s i think??? never checked
I have some used lca's if youre interested. One end is poly. The other end is heim joint. The heim joints either need some lubrication or replacing because they are a little stiff
Car: 91' camaro rs
Engine: Sbc 327
Are you looking to trade or sell? What brand are they and are the poly bushings in good shape? Thanks.
Car: 1988 Irocz
Engine: 350 sbc
Poly bushings are great. Just the heim joints are a little stiff. Honestly im not sure of the brand. They look almost identical to the founders performance ones i have. Id potentially be interested in the hood but would be fine just selling these too
Car: 91' camaro rs
Engine: Sbc 327
Ok. Where are you located and how much were you wanting for them? Thanks
Car: 1988 Irocz
Engine: 350 sbc
Located in aberdeen, sd
id take 50 shipped
id take 50 shipped
Car: 91' camaro rs
Engine: Sbc 327
Ok that sounds like a fair price. Where do you find new joints?
Car: 1988 Irocz
Engine: 350 sbc
Just call direct into founders 805-541-2254
theyll be able to get you some new ones. I had to get new bushings for mine. Fast and friendly.
Pm for paypal if you want to buy. I can get them sent out tomorrow
Car: 91' camaro rs
Engine: Sbc 327
let me know if you're interested in the hood I'll hold it for ya.
Car: 91' camaro rs
Engine: Sbc 327
Still available
Car: 91' camaro rs
Engine: Sbc 327
I think I'll just make these work in my new setup since nobody has interest. Not available!
