How to PROPERLY WIRE UP A FAN???
Old 10-17-2017, 07:52 PM
Jonnie305's Avatar
Okay my 89 RS 305 TBI Overheats The Fan Dont Work So I Want to Know How Can I Wire It To Automatically Turn On when it Reaches Anywhere from 180°to195°? Supplies i have are a 1.Fan 2.Connectors Power & Ground ...3.Fan Relays And 4.Fuses... 5.195° Thermostat Installed 6.New Radiator My Hoses & Water Pump & Heater Core are Also New Help Please Thanks...
Old 10-17-2017, 08:28 PM
eseibel67's Avatar
Car: 1988 GTA
Axle/Gears: 3.45
Re: How to PROPERLY WIRE UP A FAN???
Get a fan switch for a Buick GN and stick it in the passenger side head. Use it as a ground trigger to energize the relay which will turn on the fan.
Old 10-17-2017, 08:44 PM
Old 10-18-2017, 07:02 AM
Jonnie305's Avatar
Thanks for the Replies Guys
Old 10-18-2017, 03:20 PM
A list of switches
https://www.thirdgen.org/forums/cool...ilability.html
Old 10-18-2017, 03:26 PM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
Just get this ($16):
1. Thermostat Switch
2. Install that thermo switch properly and connect the triggered contacts to ground on one side and to the green/white wire on your factory fan relay on the other. (Red doodle)
If you have the dual fan, connect it to the green/white wire of the relay that triggers the passenger side fan (this is the Heavy Duty Fan). When this triggers, the ECM should also trigger the primary fan. (Blue Doodle)
If it doesn't trigger the other fan, then simple connect both of the green/white wires of the two fan relays together.
That should do it. You adjust the thermo switch to where you want it. I run this on my car and it works great.
Tips:
Insert the thermo switch temp probe through the radiator fins (not alongside it).
Old 10-18-2017, 03:39 PM
Jonnie305's Avatar
Thanks Alot Guys It Really Helps Out
Old 10-18-2017, 03:50 PM
Engine: 350 TPI L98
Transmission: WC T5
Good luck!
Old 10-23-2017, 08:32 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Here do this, don't use a radiator sensor version take the fan switch temp off the head
Old 10-23-2017, 12:18 PM
Engine: 350 TPI L98
Transmission: WC T5
Isn't that location used by the temp gauge?
Old 10-23-2017, 12:19 PM
midias's Avatar
There is another port on the other head on the other side of the engine
Old 10-23-2017, 12:47 PM
Not bad... Replace the fuse with a fusible link, and make sure the relay is a weather proof design. Pick up the battery voltage at an existing junction block, most commonly the starter on thirdgens...
