Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Corvette suspension continued
Old 05-21-2016, 05:58 PM
soloc4's Avatar
Car: 84 Z28, 92 C4 suspension F&R, ABS
Engine: 408 LS2, CNC LS3 heads, Comp Cam
Transmission: Magnum F, RTX clutch, Tick shifter
Axle/Gears: DANA 44, Tru Trac, 3:73 gears
Rear suspension complete
Front suspension complete
Overall engine bay, smoothed firewall
Vintage Air installed
Old 05-21-2016, 06:25 PM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
Re: Corvette suspension continued
Very nice installation!
Here is a link to the construction pictures.
Old 05-21-2016, 07:39 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Very nice job!
Old 05-23-2016, 07:16 PM
Mirror Image's Avatar
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
Looking good
Old 05-27-2016, 12:36 PM
There is a lot of time and effort and money in that, what are the plans for it? Your car, customer's car? Show car, track?
Old 05-27-2016, 01:23 PM
scholtmj's Avatar
Car: 88 Trans Am Hardtop
Engine: 350 L98
Transmission: Stock 700R4
Axle/Gears: 3.27 Aussie 9
That looks great!
Old 05-28-2016, 04:12 AM
robertfrank's Avatar
Is this from a C4?
Old 05-28-2016, 07:47 AM
scooter's Avatar
Originally Posted by robertfrank
Is this from a C4?
The rear is definitely, I think the front is, but I am not positive
Old 05-29-2016, 08:52 PM
I have to say, this is a total game changer if successfully
Completed
Old 05-30-2016, 12:27 AM
Twin_Turbo's Avatar
beautiful execution. So the crossmember is custom built?
Old 05-31-2016, 06:28 AM
soloc4's Avatar
This is my personal project for street and an Open Track day on occasion. The entire suspension is from a '92 Corvette, including the ABS. The K-member is custom built because nothing else would work short of setting the engine back 6" (I didn't want that). The rear seat area is still intact and as usable as is was originally. All of thr geometry was either retained or improved upon with a CAD program. Getting ready to install the engine, so we'll know soon if I'm right.
Old 05-31-2016, 07:12 AM
Very well done!
I find the lack of a black spray bombed engine compartment very refreshing.
Old 06-01-2016, 06:24 AM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
Top notch work! I love it.
Old 06-01-2016, 10:36 AM
BADNBLK's Avatar
Looks amazing!
Old 06-01-2016, 07:39 PM
gsmarcano's Avatar
Car: Camaro
Engine: 350-Vortec-carbed
Transmission: 700-r4
Axle/Gears: stockola, right now anyhow
that stuffs so pretty it makes me jealous, gear head jones'n.
Old 06-01-2016, 07:51 PM
J. Chris Davis's Avatar
That is some excellent work! I so want that!
Old 06-02-2016, 07:20 AM
I'm telling you now, if you mass produced that K member setup you'd be a millionaire overnight. In my opinion that trumps a coil over setup all day everyday.
Old 06-02-2016, 09:33 AM
RamIt's Avatar
Car: 1984 z28
Engine: 93 LT1 350
Axle/Gears: 7.625" 28 spline 3.23
I would love to have a sorted SLA suspension setup with the rack.
Nice work
Old 06-02-2016, 10:52 AM
tylercamaro's Avatar
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
excellent work cant wait to see more of the project as it advances
Old 06-02-2016, 12:16 PM
soloc4's Avatar
I had to section the framerails in order for this to work, so the k-member really isn't a normal bolt in. This is the 4th version that I made, the first 2 I was still trying to use the mono leaf. This is so much better in many ways.
Old 06-02-2016, 02:24 PM
I'm serious man, even with the cutting and welding that would need to be done this is insane. When you're all done you HAVE to do either a write up or try to market this. It's amazing.
Old 06-03-2016, 12:36 AM
Zach/90\irocZ's Avatar
Engine: 305 to 350
Axle/Gears: 10 Bolt
Should handle and stop pretty well with abs now in any condition
Old 06-03-2016, 11:39 AM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
This is really remarkable.
Old 10-06-2017, 06:31 PM
soloc4's Avatar
Cold air inlet
Engine in it's final resting place
View from the right side
Old 10-06-2017, 06:40 PM
soloc4's Avatar
Stock fan shroud and GTO fans assembly become one piece
Engine oil cooler and power steering cooler bracket mounted ahead of radiator
Engine from the left side
Old 10-06-2017, 06:44 PM
soloc4's Avatar
Let me know if anyone is interested in more detailed pictures, I'll remove some of the components photograph them. I'm really bad at documenting my work.
Old 10-07-2017, 05:03 AM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
Impressive work!
Old 10-07-2017, 05:29 AM
85TransAm406's Avatar
Car: 1985 Trans Am
I'd like a few more details on the vintage air you used, as I have the same plan.
Old 10-07-2017, 01:06 PM
soloc4's Avatar
I'll take some detailed pictures and post tomorrow (10/8/17). I used a universal kit modified the brackets and the firewall to fit. I also had to modify the stock ducting which I'll explain with pictures.
Old 10-08-2017, 12:47 PM
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
goes without saying, amazing build.
also very interested in more detailed pics of the vhac.
mine is all gutted, don't need AC, want to see what units others have used and how it is mounted.
Old 10-08-2017, 08:53 PM
soloc4's Avatar
Vintage air with the dash in position
The original ducting with extensive modifcations
These are the center vent inlets, 2" ABS plumbing fittings.
Close-up of the defrost duct inlet. this is the supplied Vintage air duct cut and bonded into place.
Unit installed, dash removed.
PCM mounted to the cover of the original blower fan box.
A/C and Heater plumbing in the original blower fan box.
An attempt to show the hole that was cut into the left side of the blower box for the plumbing.
Front mount bracket, it's in the shape of the Vintage piece, but with a 45 degree joggle to mate up to the dash. The stand offs are 1" .120 wall tube with rubber expansion nuts installed. There are 6 of these, 4 on the back plate and 2 on the front.
Case drain attached to a fitting installed in the firewall. The fitting is just under the starter cable seen in the previous engine compartment pictures.
A better shot of the plumbing in the blower box.
Old 10-08-2017, 09:35 PM
“Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius — and a lot of courage to move in the opposite direction.”
― Ernst F. Schumacher
You sir, are on a whole different level.
jus1975 (01-21-2022)
Old 10-08-2017, 09:46 PM
Engine: LS3
This all looks amazing, and i want to copy as much as i can! I hope to build my car at least 20% as nice as yours.
first of many questions. Wont water get into the cabin via the hose hole by the cover? I just painted that inner area on my car. I also have my firewall blocked off. So i am in a similar situation.
Old 10-08-2017, 10:04 PM
soloc4's Avatar
The blower box where the plumbing resides has a large drain hole from the factory because the original blower draws air from the cowl at the base of the windshield. the hole I cut is on the opposite side of and higher than the drain hole. Hope this answers your question.
Old 10-09-2017, 06:37 AM
Engine: LS3
I am sure you are correct, I just don't understand.
seems like water can still run down the windshield, into the cowl area, head towards the passenger side main drain and potentially thru the hole one of your tubes needed.
again, I am sure you have it sorted out, I just ask because I want to use that area as a bulkhead for coolant too, but can't understand how to get the lines into the cabin without it being a mess and creating a path for leaks.
any chance you could take a pic from the cowl area looking towards the main drain? Like this:
water can rush down the bottom face and splash aground on its way out
Old 10-09-2017, 12:11 PM
soloc4's Avatar
The bulkhead for the hoses are centered where the blower motor once was on the firewall. If the blower motor did not ingest water at negative pressure (sucking air into the cabin) from the cowl, the access for the hoses I made will not. I'll post some pictures tonight in order to clarify what I'm saying.
Old 10-09-2017, 01:44 PM
Engine: LS3
The hole in the left side of the blower box is what I think would be an issue.
Looking forward to your pictures.
Can't stress enough how amazing your build is. Do you have images of it further back in the build?
Old 10-09-2017, 05:11 PM
soloc4's Avatar
Good call Dennis, that will definitely fill the car up with water first time I wash it. I really appreciate you bringing this to my attention. Fortunately it should be an easy fix, I'll tape around the hole on the outside and use some injection foam to seal the area. As far as pre fab pictures, no I didn't document the build. There are some pictures of the tear out for the rear suspension and wheelwell tubs, but not much for the front. Again, thank you for the heads up, it's times like this is why we come on here for feedback.
Old 10-10-2017, 07:38 AM
Engine: LS3
Glad I could help.
No worries on the prefab pics. I am happy to have the images I have for inspiration.
Great idea on sealing off the tubes. I will have to think of something similar when I get to that step. Good luck and keep up the AMAZING work.
Old 10-11-2017, 06:56 AM
406TPI's Avatar
Car: 1985 IROC-Z
Impressive fitting that HVAC in there. Is that the Magnum unit?
Old 10-11-2017, 09:29 AM
whitedevilTA's Avatar
Car: 1986 Trans am
Engine: 5.3 LM7
Transmission: T56 6 speed
Axle/Gears: Dana 44 w/ 3.55's
Bet it feel good seeing the engine in there finally, and not to mention, having it all fit! It's coming along great. Can't wait to see more progress!
I'm actually trying to muster up the motivation to go out and chop off my passenger frame rail now and do the whole process all over again haha. And right when I was just starting to feel accomplished being done with the drivers side!
Old 10-11-2017, 12:07 PM
soloc4's Avatar
Thanks for the kind words. Yes it is the Magnum IV. Honestly, the HVAC has been one of the easier projects on this build. The most time consuming has been the wiring.
Old 10-11-2017, 12:10 PM
soloc4's Avatar
Once the frame rails are complete, the hard part will be over. After that, it's just fitting parts (and making them fit). Keep up the great work, I've been following the videos and your thread. Talk to you later.
Old 10-11-2017, 10:01 PM
83RDRACR's Avatar
soloc4 your car and fabrication skills are amazing! It makes my "home brewed road racer" build look like a turd. I swapped in a 4th gen z28 front suspension, steering and brakes on my build but also moved front wheels 5" forward for better weight distribution.
Like others I wish you had posted a build thread. could you possibly post a few pictures of engine to rack clearance?
Fantastic work and please keep us updated on its performance.
Dave
Old 10-16-2017, 06:39 PM
soloc4's Avatar
Dave
Here’s a good clear shot from straight on.
There’s about a 1/4” gap from the oil pan.
Old 10-24-2017, 02:35 PM
Car: 1986 Trans am
Engine: 5.3 LM7
Steven, I'm wondering if when you have a few minutes, you could take a picture or two of inside the front wheel wells where the coilover passes by the frame rail. I'm going to have to notch mine, but I'm just not sure by how much. I should probably wait until I have the coilovers, but I'm almost 100% sure it's going to need about a 3/4" deep section removed, roughly 4" wide (allowing myself some wiggle room). The springs on the ride techs are 3.5" OD which I believe is on the larger side for coilovers.
To be honest, I'm not really "cash ready" yet to dish out the big bucks on the ride techs, but notching the frame for them is essentially my next step before I can move on. I considered even removing a full inch, because my 3x3" box steel I feel is way overkill anyways. Even that small notched section being 2x3" should be plenty strong, especially with the added bracing I'll be welding in.
Old 10-24-2017, 02:45 PM
scooter's Avatar
You consider AFCOs? I have single adjustables from my friend that sells them, he uses them on his second gen
Old 10-24-2017, 02:51 PM
Car: 1986 Trans am
Engine: 5.3 LM7
I did, but it seems AFCO has a very limited selection of sizing. The "perfect" size that will fit my setup is still a bit smaller than the smallest one they had.
Old 10-24-2017, 02:56 PM
scooter's Avatar
I don't know, but I think maybe you're just seeing the off the shelf stuff? Pretty sure they make all kinds of stuff. Might be worth the investigation, if it runs a lower price. The coil overs in my second gen are fairly short
Old 10-24-2017, 07:46 PM
soloc4's Avatar
RH side, notch is 1” recessed.
This is at full droop, the gap increases slightly at ride height.
W
Quick Reply: Corvette suspension continued
