CarburetorsCarb discussion and questions. Upgrading your Third Gen's carburetor, swapping TBI to carburetor, or TPI to carburetor? Need LG4 or H.O. info? Post it here.
Third carb. This spread bore Holley had an AMAZING sound, ran great, but wouldn't cooperate with the 700R4, so it was replaced with a square bore Holley. Then the transmission died...
you guys and your rubber fuel line, especially stuff running in such close proximity to the exhaust components. that's a fire waiting to happen. run as much hardline as you possibly can guys, and use rubber only for the connections, or spend a few extra dollars on some braided stainless or quality pushlock hose (like the aeroquip socketless hose) and some AN type fuel filters. that little plastic fuel filter has been known to burst. just don't want to see anyone's pride and joy burn up because of an oversight.
Here's mine. SBC no.2....so far so good. Still got a ton as most do. Next up is to get the correct fittings, some steel braided line & fix that horrible mess @ the fpr
Holley 4bbl, Edelbrock Intake, non computer controlled 65k dizzy etc...
Ready for spring cruisin!
If this board had a modded car of the month, Id submit mine!...lol (just kidding...There are some good looking set-ups on this site for sure!) Good job yall!
DonW that is a Sinister lookin 82-84 car! Blacks a Tough color to do, esp on these cars that have been beat to hell & back before most of Us owned ours...Yours is just Clean! Love the 85-87 wheels too, they Work
Thanks, Rob. Your engine up there looks like a beast! Looks great!
My goal was old school and as simple as you can get! Anything not necessary to the function of this engine was removed from the engine compartment, which was a lot of wiring & hoses.
Reason: spelling
Mine before engine was removed for rebuild. Daytona 500 pace car w/ LG4 and T5 trans. Undergoing heads/cam, and mechanical to hydraulic clutch conversion! Its a mess now, but will be really pretty when it's done!
