My new vert
Old 09-04-2017, 10:52 AM
Claudioa's Avatar
My new vert
Hello everyone
My search is over. I now own a 91 Trans Am convertible
Red with tan interior and tan top
Needs a little work...... but it's a trans am....!
Need new top.....
Has some rust in trunk and wheel wells
One headlight motor not working
Can anyone give me info on what's involved in changing out the top....??
Thank you
Old 09-04-2017, 11:11 AM
Claudioa's Avatar
Re: My new vert
In addition to the minor repairs I plan on
Installing power seat (also plan on swapping in GTA seats)....complete digital dash.....steering wheel controls....
My doner car is a digital dash 88 GTA .....{was TPI but PO removed it and put a carb on}
I'm in the process of stripping it now...dash...entire harness...steering column.....a/c harness......
My question is about the a/c controls and a/c box....?
Do I have to replace entire box or just harness and vac lines....?
Thank you
Old 09-15-2017, 05:56 PM
Claudioa's Avatar
Re: My new vert
Old 09-15-2017, 07:30 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Re: My new vert
Just curious on why you are wanting the digital dash so badly?
Old 09-16-2017, 03:44 PM
Claudioa's Avatar
Re: My new vert
I like digital gauges.......
Favorite TV show was Knight Rider...
KITT..... computerized digital dash.....
I've built two KITT Trans Ams.....
So now I'm looking for a Pontiac version of KITT
GTA digital dash fits the bill but I also want it in my vert....
Need a cluster ( that works )
TPI engine harness from a digital dash car ( 1988 )
Or can I use 1991 engine harness with the digital dash
Old 09-16-2017, 08:25 PM
Steve86TA's Avatar
Car: To many to list
Re: My new vert
Does the digital dash function 100%? Reason I ask is the entire wiring harness is different and has different sensors front to back from the analog gauge cars. Honestly I would think long and hard about that decision before you start pulling that vert apart to do that conversion.
Old 09-17-2017, 06:51 PM
Claudioa's Avatar
Re: My new vert
Yes but a few things are out but I'm getting another digital cluster
I'm also going to be very careful with my vert....
Old 11-01-2017, 05:18 PM
mooses8801's Avatar
Car: 92 Z28 Convertible 25th Anniversary
Engine: 5.0 LB9
Transmission: 5 speed
Re: Here's my new vert
New to TGO here is my 1992 Z28 Convert 305 TPI, 5 speed. Fully loaded with the exception of power seats. Beautiful gray leather interior.
Old 11-04-2017, 06:41 PM
FART_NUGGETS's Avatar
Car: 1989 Iroc-Z Convertible
Axle/Gears: 2.73:1
Re: My new vert
Beautiful.
Old 11-09-2017, 05:50 AM
Ed1LE's Avatar
Car: 91 Firebird 'vert, 91 Formula
Engine: 5.7, 5.0
Transmission: T56, T5
Axle/Gears: Auburn w/ 3.73's, 3.42
Re: My new vert
Originally Posted by Claudioa
Hello everyone
Nice! Enjoy it!
No advice on the top as I haven't done mine but if you search on here, I'm sure you'll find plenty of info.
Old 12-05-2017, 08:35 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Re: My new vert
The Digital Dash conversion may be more than you anticipate. There are sensors on the doors, on the hatch and the sending units for the sensors might be different. I was going to swap a Digital Dash in my 83 Riviera (yes it was an option) until I looked into it, the job was almost impossible without a ton of work.
Cool idea, but keep in mind it is not a weekend swap. If you do it, replace all of the wire looms and check all of your wires while you are going through it.
