Harmonic Balancer...whats your choice?
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Harmonic Balancer...whats your choice?
All depends on your final combo and intended use. For most mild street applications a stock balancer is fine. For any serious heads and cam set-up it is strongly recommended that you go aftermarket to account for the more aggressive torsional loads you are putting on the crank. At that point the rubber portion of the stock unit will not match the new harmonics of the engine. ATI gets my vote but others speak highly of fluidyne, and powerbond.
Car: 92 Z28
Engine: ls3
Transmission: t56
Axle/Gears: 4.11
I went with one of the summit brand under drive pulleys when i did my engine rebuild last year and for the price its a good one. Ive put about 10000 miles on it so far with 0 issues. My main reason for getting one was for my heads and cam.
Looking at these two also.
http://www.ebay.com/itm/34260-Chevy-...53.m1438.l2649
http://www.ebay.com/itm/Professional...53.m1438.l2649
Stock truck balancer, 11psi supercharger, custom cam and ported heads on stock truck intake. 650-700hp at the crank with no issues. I dont spin above 6000-6500 tho.
I'm a big fan of innovators west, quality is amazing and they are rebuildable. I can't run anything but a stock balancer with my supercharger pulley setup so I'm limited. But if I had to go aftermarket I would do innovators west as they are like a work of art and loved the one on my 521 BBF.
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
I went with the SLP underdrive because it's still a balancer. I haven't had any issues. Some of the cheap underdrive pullies are just that and not a balancer.
