Best material to repair Dash Pad?
Old 06-18-2017, 02:18 PM
OddJack's Avatar
I did a search and came up with some old threads on this. Any new improved material that's best to repair the cracks?
Old 06-18-2017, 05:01 PM
Re: Best material to repair Dash Pad?
US currency... As in buy a new one. I can't say I've ever seen one repaired that wasn't obviously repaired. I'm sure it's possibly to make one look better, but for the work involved, it's easier to buy one thats not cracked.
Old 06-18-2017, 07:53 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Old 06-18-2017, 09:41 PM
OddJack's Avatar
wow I didnt even bother to search for a new one, Didnt think it would be available!
Old 06-18-2017, 10:22 PM
One can usually find a used one that is uncracked for $200 but the new ones are twice that. Although it's possible to fiberglass the whole thing (I did mine) I wouldn't recommend it since it is a huge project getting it totally flat.
Old 06-19-2017, 02:15 PM
86IROC112's Avatar
Car: 1986 IROC Z
I fiberglassed mine too. Painted it black then sprayed it with truck bedliner from Harbor Freight. Turned out really nice. It was a big job, but fun too..
Old 06-22-2017, 02:32 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Oh, they are...for $600. Which is more than I paid for my '91 T/A. Which has a near perfect dash, as well as a spare near perfect dash. Unfortunately I can't say the same for my '91 RS since apparently they never hold up in Camaros.
Old 06-24-2017, 10:47 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Its (almost) always easier to buy something new than repair what you have, but its definately not too much work & worth doing in the end.Just take your time.I redid mine in leather & put t/a grills inplace of the built in camaro grills.
Old 06-24-2017, 11:11 AM
OddJack's Avatar
the new is too expensive, not worth it to me. Mine actually is in pretty good shape, just a little crack at one corner. I have ordered this:
Amazon Amazon
Old 06-24-2017, 02:08 PM
mantaguy's Avatar
Engine: 5.0 EFI
And 84 1le's is one of the best recovering I've ever seen
https://www.thirdgen.org/forums/inte...light=dash+pad
Old 06-24-2017, 03:27 PM
Jbuchanan's Avatar
Car: 1987 GTA
Engine: 5.0
Until I can afford a new dash for my GTA, I bought a dash cap. It don't look far off from the stock dash except for the speaker covers. Definitely looks alot better than the busted up rotted dash under it. It's abs plastic and snapped right in. Most people can't even tell it's a cap. I found it online for around$115 shipped.
I will post a better pic if needed.
Old 06-24-2017, 07:29 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Old 06-24-2017, 09:20 PM
LsxMatt's Avatar
Car: 86 Sport Coupe
Engine: 5.3 LM7
Axle/Gears: 4th gen 3.42 posi
Yea those caps are great. I got mine off ebay for i think around 160.00. Never had any one question it, the texture looks almost OEM, and its molded very well to the shape of the dash. Like you mentioned, the only thing thats really different are the speaker grills.
Old 06-24-2017, 09:27 PM
Jbuchanan's Avatar
Car: 1987 GTA
Engine: 5.0
I have toyed with the idea of cutting the speaker holes out and fitting my original grills in there. The texture is almost spot on and it would be hard to tell if I could get the grills in there properly.
Old 06-24-2017, 10:20 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Thats what i ended up using, trimmed down a bit though.
Old 06-25-2017, 05:09 PM
DSMachine's Avatar
I see good quality dashboards at the auto yard quite often. I finally got around to doing mine this weekend (as you can see, it really needed it...)
Cost me only $15 and the only downfall was it was missing one air vent cover, which I was able to pop off the original dash.
Old 06-25-2017, 05:11 PM
Jbuchanan's Avatar
Car: 1987 GTA
Engine: 5.0
Put some armor all on that thing and it's mint! You did good, I can't find any that cheap around here.
Old 06-25-2017, 05:42 PM
Jack_88's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 5.7 TPI
My dash was perfect until I thumped the corner of it with my knee getting out of the car on a steep driveway. A couple pieces of the covering flaked off. I am also interested in the viability of a repair, it's such a small spot but it drives me nuts. If not, what about applying adhesive and recovering over the dash without peeling it?
That recovering is a beauty, by the way, 84.
Old 06-25-2017, 08:49 PM
86IROC112's Avatar
Car: 1986 IROC Z
Here's my finished fiberglass job..
Old 06-25-2017, 08:53 PM
86IROC112's Avatar
Car: 1986 IROC Z
Old 06-25-2017, 09:31 PM
Originally Posted by 86IROC112
That is the HF truck bedliner? Perfect texture. Now I know what I will use for my center console. Thanks.
Old 06-25-2017, 09:33 PM
Jbuchanan's Avatar
Car: 1987 GTA
Engine: 5.0
That turned out really nice.
Old 06-25-2017, 09:45 PM
86IROC112's Avatar
Car: 1986 IROC Z
Yes, the HF stuff. I tried some Duplicolor bedliner since the nearest HF is 2 hours away. Hated it. WAY too glossy and didn't like the texture. Held out till I was in town near a HF. Worth the wait. it turned out great..
Old 07-21-2017, 07:49 PM
neilcase's Avatar
Car: 1987 IROC-Z convertible
Engine: 5.0
Transmission: 700R
Axle/Gears: 2:77
FireBirds and TA's get to park in the garage. Camaros get to sit outside. I've also found that if I'm in a junkyard looking for front seat belt receivers I look for firebirds. Its that exact same receiver but the firebirds are usually not cracked and broken and the camaros are almost always no good. What gives?
