Post your best rear picture!
#1255
Car: RS Camaro
Engine: 97 L31 350:Eventually a stroker
Transmission: WC T-5
Axle/Gears: Zexel Torsen 3.73s
Re: Post your best rear picture!
This is before i got the 2000 WS6 Limited slip put in, and also before I got the Y2k's and Coop tires. It's a okay pic but wish it didn't have some of the glare that it has.. Still a good pic though!!
#1256
Car: '97 TA WS6 vert & '88 Formula 350
Engine: LT1 & 383 HSR
Transmission: T-56 & T-56
Axle/Gears: 3.42 & 3.27
My '88 Formula 350
Swapped in two piece tail lights.
#1258
Car: RS Camaro
That's too good of a picture my good sir.
#1259
Car: RS Camaro
Dude what are you makin for hp/tq with your 335? That sounds like a legit build!!
#1260
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
Kinda lost interest once the LS motors starting becoming easier & cheaper to modify (see my signature, lol)
#1261
Car: RS Camaro
I can see that. Haha. well that is defintely a gorgeous car! I'd like to see a litte more upgrades on the 335 though. That would be sick! Again sweet ride!
#1263
Car: RS Camaro
Do you have any videos of your car doin burnouts, and drive bys? I tried to look at a couple that were on your threads but they all said page is discontinued.. ;/
#1264
No idea what it would put down on the dyno, it's got stock heads/intake/injectors so its choked up. Car runs mid-high 13's on street tires at 100-101 with the 5 speed and 17s.
#1265
Car: 87 Z/28
Engine: 5.0L
Axle/Gears: 9 Bolt posi
nice looking ride.. but all the emblems are in the wrong location! u sure she is a real GTA?? check the label in the center glove box.. should have code Y84 if it is real GTA if it is a 89 5 speed original only 366 GTAs were made with 5-speeds in 89 see: http://www.gtasourcepage.com/89RPOFigures.html
if true welcome to the ultra rare club! if not well you have a nice TA that was modded to look like a GTA!
I never realized it was that rare...
#1276
Car: 92 & 91 Z28 1LEs, 87 IROC-Z, 90 ZR1
Engine: L98, LT5
Transmission: 700R4, 6-speed
Axle/Gears: 3.45, 3.42, 3.73, 3.27
Here is a pic of the rear of my 1LE lol... still bare metal
Here is a pic of the rear of my 1LE though
#1280
#1281
CKone (02-23-2020)
#1286
Car: 1991 Bright Red Formula WS6
Engine: LB9 305 TPI
Axle/Gears: 2:73 posi
Here is mine. If someone could super size my pic I'd appreciate it.
CKone (02-23-2020)
