post pictures of your head units!
#202
#203
Car: 1980 Pace Car, 1987 Trans Am
Engine: 4.9 Turbo, 5.0 TPI
Re: post pictures of your head units!
Here is mine. 1987 Trans Am. Aux input for Ipod,mp3 player or phone hidden in console compartment Just finished
#204
Car: 1992 Camaro RS Heritage Edition
Engine: stock LO3
Transmission: stock 700r4
Pioneer AVIC N4
#205
I actually just had to replace my touch screen as my original ebay cheapy mock up screen finally crapped out after 4yrs lol.
Just started putting it in and havent finished filling in the openings.But screen fits well,shave maybe 1/4inch off the bottom of the screen case..just enough that the bottom screen buttons were.Its a Liliput high brightness anti glare screen.
Not hard to do..measure 3 times and cut once as they say lol.
#206
Yep, that is correct. Think it came out of a 1999 Trans Am. Bought it on Ebay and did the mp3 Aux mod myself a couple of days ago.
#209
i...... have.... the... same... one... wow it came in my sport coupe how old are these? lol, i have a brand new sony for it tho, not a fan of it myself bc no aux or usb
#211
Few will know this H/U .. BUT you should
#214
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
What climate control?
#215
#218
Hi, it came with a harness/adapter to fit my 87. The small antenna jack was also included. Only issue, was my power antenna came to life when i turned on ignition, even if the cd player was off. Just had to swap 2 cords in the harness. Installing the cd player in my console, involved som grinding of the mickey mouse ears infront of the player with a dremmel because they are a little larger than the stock cassette player. Also had to remove/grind som of the plastic inside/at the back of my concole as the new player is a little deeper than the stock. No big deal with a dremmel..
#219
Great information. Thanks.
#222
Car: 1988 IROC Z
Just curious how that pioneer radio is doing and if you ever get HD stations with it. I just put a DEH 4400HD in mine but it never gets any HD stations that I can see?
#223
Car: 1992 25th Anni. camaro
Engine: 5.7 liter ZZ4 swap TPI
Transmission: T56 (manual 6 speed)
Axle/Gears: corp. disc GM 10 bolt, 3:42
Bose delco deck from a 93 camaro new cd mech & remote aux input jack in armrest/glovebox.
#225
Car: 1989 Pontiac Trans Am GTA
Engine: cammed LS1
Transmission: Monster SS 4L65E
Axle/Gears: 9 bolt posi w/ 3.70 gears
#226
Car: 89 GTA & 76 T/A
Engine: 5.7/455
Transmission: GTA Auto/76 T/A 4speed
Here you go... http://maptechenterprises.com/storef...4b6cf7832d6e72
#227
Engine: cammed LS1
YW As far as clearance goes in the radio pod, I think you are better off keeping the radio lower and the text above it. Seems like you would have to cut less of your radio pod out to make it fit. I went with the red illumination too. I can provide pics of how I had to cut my radio pod to get my radio installed with the HUmount if you need them.
#228
Car: 1992 W68 Firebird
Engine: 305 5.0L V8 TBI
Car: 87 Trans Am, 99 WS6, 16 Mustang GT
Engine: LB9, LS1
Transmission: 700R4, T56
Axle/Gears: 3.42 Posi, 4.10 Posi
When I had the same deck in mine, I had to cut the support behind the radio to get it to fit. Even then it was extremely tight, the thing had to be squeezed in by tightening the screws.
I did have an adaptor harness though, so there was a lot of extra wires back there. That was the main issue.
#230
My Pioneer FH-X700BT
#232
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
[QUOTE=razman340;4288998]
[/QUOTE
Im ordering mine!
[/QUOTE
Im ordering mine!
#234
WiFi GPS 4.4 Android Touch Screen Ebay Chinese Unit.. A bit wider than US units, had to notch inner vent tubes and flip over old inner mount.. to slide it in.. example link - http://www.ebay.com/itm/151854406539?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
#240
Car: 91 Z28
Engine: Enhanced 5.0L
Axle/Gears: 3:42 Posi
havent seen my setup too much around here..so I thought I'd post....
#242
Took a good bit to get this in. Was worth it.
Street Lethal
08-12-2015 11:33 AM
