Wiper plastic stops
Wiper plastic stops
Does anyone know what those wiper stops under the windshield are called? They also serve to support the windshield during instalation I think.
Any ideas where to buy them from?
Re: Wiper plastic stops
The windshield is actually supported during install by small rubber blocks about 1/4" thick that sit on top of two stamped wedges below the windshield. To date I've never seen a glass repair guy reuse them, but they're there from the factory.
Ebay, or junkyard.
Ebay, or junkyard.
I am assuming you are referring to these? These are what I need as I have one missing.
That would be the wiper arm parking stop, but the rubber install blocks are gone in that photo. The rubber shrinks a bit with age and the blocks fall out easily enough. The support for them is obvious if you know what you're looking at...
The wiper stop just keeps the wiper from sliding off the bottom of the windshield in park.
Do you know where I can find the wiper stops? I guess there should be two of them no?
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
The P/N is 3080661,go to a GM dealer and see if they are still available,it's a start.
Ahh so there should be only 1... Then I don't have anything missing. The cowl screen is not installed and I couldn't figure out why there was only one.
Thanks guys
Thanks guys
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
In Malta you prob don't need it, but the screen is important if the car is parked anywhere with trees. Leaves and needles get in there, trap water then the firewall rust from inside out. Kills a lot of f bodies.
Thanks I actually meant not installed for the timebeing.... Sorry my bad. Screen will surely be reinstalled
