Building a 400 hp Engine from a 5.7L Votec
Old 03-16-2017, 02:57 PM
AKA Greg's Avatar
Car: 1989 Chevy Camaro RS
Engine: 305 TBI (5.0L)
We have an '89 RS with a sweet little 305 (all stock). She runs good, but we want more HP. My uncle gave us a 350 engine from 1996 Chevy truck. It is all stock with original Vortec heads; no intake. It is a little rough, but we are totally rebuilding it. Our goal is 400 hp. We need some help on this task and we have a lot of questions. He also gave us some cast heads (3970126), port and polished 2.02 int.-1.95 ex. Are these heads worth putting money into to rebuild or should I keep and rebuild the votecs or buy new heads?
Old 03-16-2017, 03:20 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Re: Building a 400 hp Engine from a 5.7L Votec
Rebuild the stock vortecs but make sure they are not cracked. Machine shop will let you know
Ditch the 126 heads
Good intake manifold and a decent sized cam will get you 400 crank hp
Old 03-16-2017, 03:26 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
It is fairly easy to make 400Hp on Vortec heads with new springs. The 96-2000 vortec heads are the best iron head chevy ever made stock. Ditch the 126 heads they are not nearly as good, bring the others to a shop, have them checked for cracks and have screw in studs installed and good springs installed leave the valves the stock size.
Keep the cam roller maybe something like comps 12-432-8 and you will have a great machine.
Old 03-16-2017, 03:40 PM
AKA Greg's Avatar
We are doing a complete rebuild with new bearings, lifters, rebuild the heads, etc...I was going to install a 488 cam - then have the cylinders bored over .030.
Old 03-16-2017, 03:42 PM
AKA Greg's Avatar
And put in a new TBI ...thought about a Holley 4 barrel carb and regulator. What do you think?
Old 03-16-2017, 03:43 PM
midias's Avatar
Can you post a link to the cam. Either way it will make more power with vortec heads vs the 126 heads. Make sure you get proper pistons not crapper re builder pistons that sit too low.
Grab an RPM performer or Air gap or clone of either one if you are going carbed.
Old 03-16-2017, 03:50 PM
AKA Greg's Avatar
Ditch the 126 heads
Thanks Orr89...I have been hearing the same from others.
Old 03-16-2017, 03:54 PM
AKA Greg's Avatar
Thanks! We want to go 400-425 HP and I been hearing the same...dump the old 126 cast heads. Do you think .030 over bore is good or should we go .060?
We are not using anything from the 305. All new or rebuilt.
Old 03-16-2017, 04:04 PM
AKA Greg's Avatar
This is the cam we were looking at...but not into it far enough. I will get better informed from guys like you before I buy the kit.
http://www.jegs.com/i/JEGS-Performan...00106/10002/-1
Old 03-16-2017, 04:07 PM
AKA Greg's Avatar
Maybe more like this cam set...
http://www.jegs.com/i/COMP-Cams/249/08-535-8/10002/-1
Old 03-16-2017, 09:12 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Needs to be bigger to make 400 hp. Extreme energy series to start amd around the 276hr or 282hr
Old 03-16-2017, 09:18 PM
midias's Avatar
Originally Posted by AKA Greg
Not enough check the 282HR I posted earlier
Old 03-16-2017, 09:20 PM
midias's Avatar
Stay 30 it is safer. Besides the vortec heads will make way more difference than 5cuin
Think of it this way stock 170CC vorted heads flow better than some of the older large port bowtie "performance" heads. They can support 400hp with zero porting or valve changes.
Old 03-17-2017, 09:39 AM
AKA Greg's Avatar
Thanks again! I found a 282 on the Summit site. Looks like a winner.
https://www.summitracing.com/parts/c...nVvBoCWLHw_wcB
Old 03-17-2017, 09:43 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
No that is mechanical flat tappet
Use the hyd roller
https://m.summitracing.com/parts/cca-08-432-8
Old 03-17-2017, 09:46 AM
AKA Greg's Avatar
Thanks midias! We are going to get the Votec Heads reconditioned, add a 282hr CAM, bore it out .030 and get a good RPM Performer Intake.
~What kind of pistons and ring set should I look for?
Old 03-17-2017, 09:54 AM
AKA Greg's Avatar
Use the hyd roller
Great! I need the set (with lifters). Wow, you guys are helping me a lot. We will have an awesome machine when we're done. My 20 yr old son and I are building this engine together.
Old 03-17-2017, 10:25 AM
midias's Avatar
You want a set of pistons with a 1.56 compression height not a 1.54 Shoot for a 9.5:1 compression and it should help you stay away from other issues.
Here is a calculator.
https://www.summitracing.com/popup/c...ion-calculator
I am using these but they are discontinued
https://www.summitracing.com/parts/stl-h345ncp
You can get lifter kits from comp but you may be able to reuse yours. Give comp a call I am sure they have a kit. Make sure to tell them it is not a retrofit
Looks like these are the lifters the recommend
http://www.compperformancegroupstore...ct_Code=850-16
http://www.compcams.com/Company/CC/c...?csid=189&sb=2
Old 03-17-2017, 10:36 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Gm ls lifters
12499225
Old 03-17-2017, 11:11 AM
irocman7's Avatar
Car: 89' Sunset Metallic Orange Iroc-Z
Engine: Forged 383
Transmission: TR6060
Axle/Gears: 4.11 9 inch
Make sure those are actually vortec heads. Vortecs didn't come until 1996, so they would have to had swapped them over if that block is a 92.
I made about 420 hp with my vortec setup. Vortec heads, with beehives and a comp 280xfi/hr, on a low compression l98 factory block.
86mph in the 1/8 with a 3524lb car.
Old 03-17-2017, 11:19 AM
irocman7's Avatar
Engine: Forged 383
The will have one of these two casting numbers.
10239906 (#906) or 12558062 (#062)
A lot of them can be identified by the saw tooth pattern on the front.
http://www.onedirt.com/tech-stories/...k-chevy-heads/
Old 03-17-2017, 11:20 AM
AKA Greg's Avatar
I was told it was a 92 engine...I am checking the block number tonight. The engine might be a mid to late 90's. You're right about the Vortec heads though...1996 and up. Thanks for your input. We are just getting started and I am not made of $ so, this will take a year or so to complete. Thanks irocman7!
Old 03-17-2017, 11:29 AM
irocman7's Avatar
Engine: Forged 383
No problem, love helping and seeing how other people do with similar setups. There are quite a few vortec guys on here. Nothin better than cheap power.
The block casting number should be 10243880. Also known as the 880's.
I am now running an 880 4 bolt main 383. Good motors.
Old 03-17-2017, 11:40 AM
AKA Greg's Avatar
We are starting to pull the heads this weekend (hopefully). I will see what needs replaced and what can be used from this engine. The original owner of the engine replaced it due to a tick inside somewhere. We won't know until we start taring into it. It is still cold here in Ohio, but when it warms up my son and I are jumping into it.
Old 03-17-2017, 12:43 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Totally missed the 92 vortec engine thing. Definately get a head casting number. If its not a vortec head then you will need to reconsider this approach lol. Stock tbi heads likely will not support 400 hp
Mortorq (07-02-2019)
Old 03-17-2017, 01:36 PM
AKA Greg's Avatar
Yep, checking the numbers on the heads and block tonight. Thanks guys.
Old 03-17-2017, 06:52 PM
AKA Greg's Avatar
We pulled the heads tonight and they are vortec heads 10239906. I checked the numbers on Chevy's website.
Old 03-17-2017, 06:57 PM
AKA Greg's Avatar
Old 03-18-2017, 03:49 PM
AKA Greg's Avatar
We removed the heads today. Some forums say the heads I have shown here (10239906) are good and others say they should be replaced with new aluminum vortec heads to reach the 400 to 425 horsepower we are looking for.
http://www.superchevy.com/how-to/97458/
Old 03-19-2017, 03:22 AM
irocman7's Avatar
Engine: Forged 383
That article was denunked a few years back, surprised its still floating around.. I'm running the 906s myself. Same flow numbers between all of them
Plan on upgrading the valve train, I went with beehive valve springs comp retainers, and arp screw in studs. It was less than 300 with the machine work.
All the ones I have seen cracked, were cracked right in the middle between the two water jackets. When you pop those off clean that area with a wire brush and check.
Old 03-19-2017, 07:42 AM
AKA Greg's Avatar
I am taking these 902 to be machined, valves and springs, replace the pressed studs with threaded, and the deck skim cut. Also having the cylinders bored .03 over. Thanks for clearing that up for me.
Old 03-19-2017, 12:56 PM
AKA Greg's Avatar
From what I have been reading as I research the vortec heads, the comp 12-432-8 will not work. It has too much lift. With new beehive springs on the 906 vortec I will only have .5 lift, so .47 intake (gives .030 clearance). I would need a different cam for this head...right?
Old 03-19-2017, 01:16 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Get the heads machined for the lift
Old 03-19-2017, 01:24 PM
AKA Greg's Avatar
What needs machined to add lift? I know the machinist will know what to do, but I would like to know for my own edification.
Old 03-19-2017, 02:02 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Guide boss gets cut down for different type of seals.
Old 03-19-2017, 02:06 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
http://www.superchevy.com/how-to/148...ds-valve-lift/
Old 03-19-2017, 02:49 PM
AKA Greg's Avatar
Good news. So I just tell the engine machinist what cam I want to use and he will provide me with the lift. Thanks!
Old 03-19-2017, 05:38 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Something like that lol
Old 03-23-2017, 04:18 PM
AKA Greg's Avatar
I found a good price on a 383 Stroker Kit. We are getting the short block overhauled to be a 383. But 1st the heads are off to the machine shop to be checked and machined.
Old 03-23-2017, 04:23 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Get a dished piston with that stroke
Old 03-24-2017, 09:48 PM
AKA Greg's Avatar
This is the 383 stroker kit we want to install. We have to modify the block to add clearance for the bigger stroke.
Old 03-24-2017, 10:03 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
A flat top may give you 10.5-11.0 compression which is gonna be too high for pump gas and iron vortecs
Old 03-24-2017, 10:24 PM
AKA Greg's Avatar
Yes, I want to stay around 9.5:1 to 10:1 compression.
Old 05-12-2017, 11:52 PM
startat2's Avatar
Just recently finished a 383, but have not gotten it into the car yet. 400 horse is doable, and there are plenty of proven combinations out there!
Old 05-13-2017, 07:07 AM
AKA Greg's Avatar
Awesome. I hope she runs and sounds great for you. We've hit a wall for now...summer is near and cruise ins and shows are the plan for a few months. We will get back into it later this year. Now it's time to drive.
Old 05-18-2017, 12:48 PM
355tpipickup's Avatar
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
Subbed for info
Old 05-18-2017, 03:44 PM
AKA Greg's Avatar
Old 05-18-2017, 04:31 PM
five7kid's Avatar
Car: 82 Berlinetta/57 Bel Air
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Axle/Gears: 12B-3.73/9"-3.89
What??? Not sure what you mean.
He subscribed to this thread so he is notified when someone posts to it (like we just did).
Old 05-18-2017, 05:01 PM
fasteddi's Avatar
Axle/Gears: Strange S60 4:10s
If you go with 383 stroker kit then your 400hp goal will be a bit easier. xe282h or even a xe272 cam, a 750cfm carb, performer rpm intake, and if you can work those heads a bit.
Personally I think a 272 cam would be fine for you if your are not all out drag racing the car. A 282 is pretty big and really moves your tq range arround and pushes that peak rpm up alot. I suppose it also goes into play what rear end gears you have and trans(tq converter stall)...exc. Now saying that, I wish the PO that had my engine before put a larger cam into it.... the xe268 is way too small for me personally when drag racing. If you do go with a xe282 then make sure to keep the compression ratio static at 10:1 or more. It will really help with a cam that size.
Personally i have a 385, 11.1:1 compression, eagle rotating assembly, 750 cfm carb, 1.6 roller t rockers, xe268 cam, Dart Iron heads 200/80 cc runners 23* and make 12.10 passes at 110mph so about 400hp or a touch more. I know you are trying to stay a bit lower compression wise. 10:1 would be about right for you if you plan to drive it around alot and retain iron vortec heads. Just run 93 octane if its available .
Old 05-18-2017, 05:33 PM
AKA Greg's Avatar
Thanks fasteddi. I will keep this in mind. I appreciate all of the info I am getting from all of the veteran motor heads. This is the biggest undertaking we have attempted, but will be worth it when we finish.
