Rear disc rotors, front wilwood calipers, BBK throttle body
Car: 2011 Camaro 2SSRS w/ Procharger
Engine: 6.2 LS3
Transmission: M6 TR6060
Axle/Gears: 3.45
Hey everyone. I have a few parts up for grabs. Decided to go different routes for all of this stuff, so it needs to go to pay for the new stuff.
First off rear drilled and slotted powerstop rotors, never installed. New, in original box. See pictures for part #. $100 shipped
Wilwood front brake calipers, according to previous owner they had less than 1000 miles on them. They come with brand new seals and pistons. So if they ever lock up or leak, you can just rebuild them. The brake line fitting on these is 3an. So keep that in mind. $150 shipped.
Lastly, a bbk 52mm throttle body. Has all new gaskets installed, has been totally cleaned out. Comes with brand new ac Delco TPS sensor. You will need to use your own iacv. $200 shipped.
For another $50, I can include a ported to match upper plenum that has been sanded, polished, ported and polished. Don't have finished pictures but I can get some if you're really interested. Otherwise I will sell this plenum separately for $100.
Re: Rear disc rotors, front wilwood calipers, BBK throttle body
Sell the tps sensor by itself?
Ok, I'll think about it.
Engine: 6.2 LS3
Axle/Gears: 3.45
Everything is still available.
Engine: 6.2 LS3
Axle/Gears: 3.45
ACDELCO TPS sensor is sold.
calipers are on ebay for sale, auction is almost over. 162333087447. Listing number.
so is throttle body, going pretty cheap listing # is 162337293786
Talltim I responded to your pm with a counter offer.
Do you still have the Wilwood Calipers??
Engine: 6.2 LS3
Axle/Gears: 3.45
sorry fellas, this stuff is all long gone.
