New solid cam installed
#101
Car: 1989 Camaro RS
Axle/Gears: 9 inch, 35 spline drag spool,4.56
Re: New solid cam installed
It says 7.5 min recommended...but they also say 9.5 max and I ran a 10....lol
#102
Engine: sbc
Transmission: stick
Axle/Gears: GM
#105
Car: 1989 Camaro RS
Those that are running a DS loop..what kind do you run and do you have a picture? Summit has some universal ones but I don't know if they'll work all that great.
#106
Car: 1989 Camaro RS
Just checked clearance of my wheels on a friend's 3rd gen...just like you guys said. Thanks for the help...now I don't have to buy new wheels. I owe yas a beer..🍺
#107
Car: 1989 Camaro RS
check this link.. the gray inner sheet..can be done away with..its trash thin not worth keeping. just cut it out as one piece.. only cut upward from bottom about 4 to 4 1/2" keep the top of the spring and shock coverd. you will see I put a strap back in.. its up to you.i did it to keep the spring in it's seat/safty stop is all...
https://www.thirdgen.org/forums/whee...-6-5-back.html
#108
Car: 1989 Camaro RS
Ok..so momma let me spend some money. I am ditching my 4th gen rearend for a 9 inch at third gen width. My question is now that I'm narrowing my axle back to stick width my current wheels won't work at 6.5 BS. I plan on keeping my 275 DRs so what BS am I going to need now? I don't want them to stick out at all. Thanks for any input.
Custom built QP 9" housing & axle package for 3rd gen F body (setup for 4th gen brakes)
- 35 spline axles
-Compatible with stock style suspension
-Chevy wheel bolt pattern (5x4-3/4)
-1/2"-20 studs 3" long
All new pro N center section
-Yukon nodular iron case w/ 5/8" cap bolts
-Timken USA bearings
-Solid pinion spacer
-Aluminum Daytona pinion support
-Motive Performance ring & pinion gear set (4.56)
-1350 Billet steel yoke
35 spline HD drag spool
#109
Car: 1989 Camaro RS
Ok..got the first 2 of 4 packages in today for the new rearend. I'm pretty stoked. Will be assembling center section this weekend. Description listed below...
- 35 spline axles
- 35 spline axles
#113
Car: 1989 Camaro RS
#114
stock thirdgen width rear axle, 15x10 with 6.5" backspacing works great and tucks really well. must bfh inner fender and cut the bumpstops out. this has been covered exhaustively here so you should be able to find pictures of what i'm talking about.
#115
Car: 1989 Camaro RS
Yeah I've already done that. I did a quick reply on my original post so all that popped up as well. Thanks though.. I'm pretty stoked to install it this weekend.
#119
What about a piece of 4" or 5" tubing (2" long or so) welded to the torque arm directly? I believe there's more than one manufacturer that has that as an integral part part of the torque arm.
Then there's Spohn's crossmember incorporated piece as well.
#120
Engine: sbc
Transmission: stick
Axle/Gears: GM
I'd like an answer to this as well although I have the UMI torque arm. I don't much care for the Lakewood loop what with having to lift the carpet (and Hushmat) for the bolts. Plus in my application, it interferes with the header y-pipe.
#121
Car: 1989 Camaro RS
it is 3 inch axle tubes..id like to know what others have done that run a 9 inch with 3 inch axle tubes. thanks for any input.
#122
I bought mine from UMI.
Pretty sure just about any of the aftermarket suspension companies carry them. I'll post up a link when I'm back at my PC. (phone is limiting).
#126
Car: 1989 Camaro RS
thanks skinny..im probably going to get the 79 dollar one..spohn offers one too i think. i really appreciate the info.
#127
For what it's worth, what I have done in the past is to re-use the mounts that were installed on the original (9 bolt) axle (2 3/4" I think) and slot the holes. Then all it takes is a 3" muffler clamp to connect the mount to the axle tube. I boxed in the end of the clamp base for strength and a little detail. Worked just fine.
The picture below is my Dana 44 with 3" tubes.
You can see the muffler clamp (with the boxed in end) supporting the sway bar mount and urethane bushing. The clamp base is painted black.
#128
Car: 1989 Camaro RS
Used the exhaust clamps as mentioned
#130
Car: 1989 Camaro RS
Well...as of right now I think shes done for the year. About a week ago I put my car on a lift going over some things so I could load her up to get dyno tuned at a local shop. Well...while it was in the air I let the car run for a bit to get some run time on the brand new rear end. It was at this time I noticed I had severe wheel wobble at both wheels...I checked the obvious..loose wheels....rotors etc...what I ended up finding was that both of my brand new axles were out of round. That's right...brand new 35 spline axles out of round. So to back up My theory I brought them to a machine shop to be chucked up and checked by a pro...same result. I contacted QP and was advised to send them back so they can check them out...they paid for shipping and all.they received the axles and found same result. So they are in the works with moser now trying to get me new axles. They confirmed that nothing was installed incorrectly or done incorrectly...so I should be gtg as far as a warranty on concerned. So...while the car is down and waiting on new axles I have decided to start my next year, next big upgrade now which is all new front end..k member, coil overs, control arms etc...also switching to rack and pinion. Kinda sucks that I've spent all this money this year and only made 13 passes...but that's the life and I'm looking forward to getting her back together for next year.
#132
Car: 1989 Camaro RS
The axles are Moser, Matt. They are the ones that QP uses for there builds. Just need Moser to validate the warranty now. But I'm glad I caught it and didn't go beat the hell out of her like that.
#133
I know the feeling all too well. I've spent most of this season away from home and as such just recently reassembled the new top end. Today was supposed to be the last test and tune of the year and I planned to get in a few passes and report back on what I had hoped to be a success story. Unfortunately, the snow and cold has prompted the track to call it a day. Gotta wait till next year now.
#134
Car: 1989 Camaro RS
#135
hooker 2210 or the doug's headers. either way i'd still get the headers for the thirdgen chassis since the k-member is only about half of the space constraints of these cars, lol.
definitely give PA Racing a look for those k-member components. probably the lightest for the dollar on the market, and craftsmanship is 2nd to none.
#136
Car: 1989 Camaro RS
#137
Car: 1989 Camaro RS
Matt, does PA racing have a good number? The one on website just cuts off after I e ring every time.
#138
i highly recommend emailing jason directly, as he's a bit of a one man show, so phone calls don't always work well. if you need to talk with him directly, get him to call you per your email, lol. his email is
jason@paracing.com
jason@paracing.com
#140
Car: 1989 Camaro RS
Matt, I emailed him. Hoping to hear from him soon. Thank you for that. Also, I'm changing out the headers and am looking into Doug's....but I was wondering...could I buy a set of shortys or turbo style headers and just turn them around and run them out the fenders? I seen some headers for turbos with the band clamp style collector that looks like I could just run some piping right through the fenders. Any input will be greatly appreciated.
#143
Car: 1989 Camaro RS
i tried a set of hooker shorty headers super comps..all i did was turn them around and they clear quite nicely..i was surprised...and they are only 180 bucks....downfall is that they are 1 5/8. my LT were 1 5/8 as well..so i don't know if it will be that huge of a difference. i have read some articles and watched many videos and surprisingly going from a LT to a shorty at same tube size there wasn't really any significant difference from what i can tell. but anyways..as always..i appreciate your input. thanks again.
Jay
#144
my front exit headers are custom, equal length primary, tuned primary and collector diameter and length. it was a lot of work, but i believe there were gains there.
#145
Car: 1989 Camaro RS
Few updates. Got new axles in as well as started on installing new front end parts.
