Single turbo 352 iroc 1000hp or bust the grand finale
#1551
TGO Supporter/Moderator
Engine: LC9, LT1
Transmission: TKX, 4L60E
Axle/Gears: 3.42, 3.23
Re: Single turbo 352 iroc 1000hp or bust the grand finale
I'd probably use it if I had a stock LSx vehicle.
I almost bought a C5 but the electronics scare me. Too much crap breaks on those.
#1552
You can run the LSX style PCMs on different motors from what I've seen.
#1553
The OPs cam is not a good match for forced induction. Not even turbos. But if he has it, run it, just means he's leaving power and drivability on the table. With turbos you want no overlap, otherwise the exhaust (which is under pressure from the turbo) will revert back into the intake during overlap, thus displacing good fresh air that gets sucked back into the cylinder just to get reburned. I don't have the means to verify how much overlap but once you have overlap it negatively affects power on a forced induction setup. If you were running a blower you'd want more exhaust duration and a much higher love, positive displacement like even more exhaust duration and high lobe. Turbos don't need it as the turbo needs the pressure... but no overlap.
#1554
I run a 1mb 6243 ecu coil over plug true mpfi w/ my h/c/I turbo gen I sbc . You can run any gen 3/4 ecu with SBC gen1 or LT1/4 gen 2 not only the 0411.
HP tuners is great , you can still pass emissions with radical combos as long as your able to pass a sniff test.
Best thing is its not limited to just one vehicle. I use it on my jeep also.
#1555
#1556
Ya im sure you me and 1000s of other guys could do better with something other than off the shelf grinds. Its pretty hard to choose a cam that doesnt make power with a turbo. 95 out of 100x if its good na itll be great FI.
#1557
infact hotrod or one of those guys did back to back testing with turbo cams vs the (wrong cams) for turbo and the wrong cams worked just fine
a turbo cam made flatter power , while the wrong cams made more power but was much peakier
#1558
Engine: LC9, LT1
i was going to get a custom cam ground but i didnt have the time to wait , this cam is small and lil overlap compared to the cams i used to run int he v6 motors , it will make power just fine
I think this is the article you are referring to. An interesting read.
Turbos are strange things.
#1559
I new I was going to go with comp so I used there software punching what was as close as possible to my combo and came up with the 280xfi + 2 degrees advanced ontop of there 4.
They sure are,
Thanks for the link. It will give me something to read tonight tricker treating with the family
#1560
http://www.hotrod.com/articles/ctrp-...amshaft-guide/
thats not it but it gets to the point
#1561
the injectors fixed it , i have one reset when i let go of the starter button and thats it
starts up ,runs and doesnt stall oyut anymore randomly
thank you joe
thank you joe
#1563
i need to adress another issue first , gota get my hands on a leakdown tester though a compression tester should work as well .
rember when i bent those pushrods due to to long of intake bolts , well i have this backfire in the ex system, i think maybe i may have kissed a valve with a piston during that time .
the odd thing is it goes away as the motor warms up
anywich way i only need to check 2 cyls so it shouldnt take long to find out, it could also be another autolite plug going out as it doesnt do it constantly its completly random if it was a valve u would think it would pop every cycle
im actually going to take out for a spin friday then drop it off at the shop so i can work on the rear end swap
#1564
joe any idea on the dead time on those injectors or voltage offsets?
not really a ig deal but having that info would save me some tinkering lol
#1565
Engine: LC9, LT1
Remember, the MS uses a magical dead time calculation that is not based on reality. Other ECU's may do the same thing, I don't recall, but the MS only asks you about "dead time" not "open time" followed by "Close time", so I don't know how the *!#@ it calculates using just this magical dead time number, which seems to want to be smaller than the actual "open time" number provided by the injector manufacturer.
(I've seen the MS experts try to explain it on the forums, but they contradict themselves in doing so often)
Coil Resistance: 12.5 Ohms / High Impedance / High-Z (No ECM driver modifications required)
Static Flow Rate @ 43.5PSI ( 300kPa ) w/Gas: 60 lb/hr = 630 cc/min = 453 g/min
Static Flow Rate @ 87PSI ( 600kPa ) w/Gas: 85.7 lb/hr = 900 cc/min = 648 g/min
Gain: 0.11ms/mg
Offset: 0.055ms
Turn on time @ 14VDC: 1.14ms
Turn off time: 0.85ms @ 600KPa
#1566
Originally Posted by anesthes
Cool. Drive the car, enjoy it.
#1568
looks liek my missfire is a plug swaped the plugs in the motor side to side and the miss follwoed the plugs i think im just going to break down and pay the 6.50$ a piece for the ngk's this time , the autolight ar2923 have been a thorn in my side about as bad as the low-z injectors
#1571
thank you ,,
yup these things are fouling out so damn easy , 1-2 tests on the launch control or hit the 2 step and they are fouled
since my traction control functions something like a 2 step it fouls them out on that as well
#1573
need to take my buddy out for a ride in the car this weekend and try to convince him to build the virgin gm rocket block he has , hes big into diesel stuff but not gas stuff, hes got 2x cummin's builds going right now , ones a 4cyl into a chevy 2500 and the other is a 6cyl with compound turbos and all the goodies going into a gm crew cab/long bed 2500 iirc on the truck
#1574
its alive again and doing well thanks again joe i cant thank ya enough
#1575
home for lunch , started the car up , let her run for 45 mins just sitting outside idling , not one hiccup out of the ecm/motor , im actually excited about the damn car again
did manage to take it for a drive yesterday really fast and it seems like i just need to fine tune the ae , and the 3-8 psi psi range of the table a bit and i should be good to go
joe what was that adapter u used for the iac , im getting a lil stalling here and there with the trans in gear hopefully a lil more ignition timing will cure it but if not im going to have to install and iac on this
btw anyone want some precision turbo low-z injectors going to put them up for sale on here and yb , they ohm out fine they were just to much for the ms ecm
#1576
Engine: LC9, LT1
Your Ms2 should drive a 4 wire IAC as is. You need to verify the wiring though.
#1577
ms1 currently so yeah thats why i wa sinterested in the pwm to stepper adapter
#1578
Engine: LC9, LT1
TTR Ignition Systems
www.ttrignition.com
Email him. I suspect it will work with MS1 if it's got a fidle.
#1579
Don MacPhail :
www.ttrignition.com
www.ttrignition.com
thanks yeah it has a fidle, if i can find were i put my ms2 cpu maybe ill put it back in , but i honestly dont want to mess with it since its running good now
#1580
Engine: LC9, LT1
Tuning cold start sucks because once the motor is warm you are done for the day.
#1581
its not to bad when the motors cold i just have to hold the idle up around 1500 for 10-15 seconds and then the car will idle on its own , then i just let the motor warm up for a few more mins and i can drive it .
im never in that much of a rush were i need to hop in hit the key and go
first thing on my list is fixing the fuel level sending unit , or my pump setup i ran out of gas yesterday pulling into the driveway damn gauege still says i have a 1/4 tank , so either my fuel pumps arent low enough in the tank or i bent the float rod when i put the pumps in
#1582
Engine: LC9, LT1
I started mine the other day. It caught and died. Caught and died. Then caught and idled. I couldn't move it for a minute or two. Even little throttle movements caused it to stumble.
#1583
im around 32-35* at idle
when i started it yesterday it fired and died the very first time , but the second time it was fine
if its stumbling cold u may need to increase or decrease ur cold ae multplier , more then likley u need to increase it
#1584
were supposed to hae some mid 60 to low 70* days today and for the next few days going to try to get the car out inbetween work and everything else .
would be nice to go out on a cruise once before i bring the car back to the shop for a repaint and rear swap over the winter, i think the only other thing i actually need to do the car this winter is take the trans out and go threw it .
its actually nice to have such a short list of things to do to the car
#1585
Car: 86' IROC
Engine: Supercharged 350
Axle/Gears: 3.45
You guys run **** ton of advance at idle. Im at 9* over here. +1 on the AE cold multiplier. I had to double my AE when i put the blower on, and add roughly 20% to the cold number.
#1586
i tried to get idle ignition timming way down but the motor just wouldnt run right , now that i have swapped injectors things may be different , so ill give it another shot
but the motor runs great with that much timing at idle so who knows
#1587
Engine: LC9, LT1
My Corvette stock runs a ton of advance at idle:
I've verrified it with the scanner, it idles around 30-32 degrees.
#1588
joe did u throw away all those modified pistons for ur th350?
#1590
Engine: LC9, LT1
Rescaling AE for different injectors
Did you have your AE dialed in until you changed your injectors? With MS3, you just need to recalculate Required Fuel and that should take care of rescaling your AE as well. On MS1 and MS2 you still need to recalculate req_fuel and that is 90% of the battle, but if the injectors are much larger than stock you’re going to have to tweak the Acceleration Enrichments as well. On these variations, the AE settings are tuned in static pulsewidths, and they’ll still be commanding the same PW as the smaller injectors were, which with the bigger injectors will dump in a LOT more fuel.
Explains why my AE is totally pooched after going to smaller injectors.
#1591
damn i wanted to see if u could take some measurements for me .
though it may not be needed i was able to find the spare presure plates i had laying around today , one might be thick enough to make up for the slightly excessive clearance in the low rev pack
need to figure out how im going to plumb in the nitrous nozzles in the intake no room on the sides , so that means either a spacer plate under the plenum , or plumbing it in under the intake.
might be enough room to do it in the center for the center 4 runners , 2 in the front by the thermostat housing for the front 2 runners , and if theres enough room by the distributor i could put those back there but i bet the lines would be a nightmare to bend up for that
#1592
Engine: LC9, LT1
#1597
needed money at the time ,,,,
we got our first snow storm over night so its time to take the car and park it in the shop for the winter , probably be mid/late feb before it starts getting nice enough to play with it again , so that gives me a decent bit of time to do some of the things i need to do on the car
#1598
Engine: LC9, LT1
You guys got weird weather.
Feb is the worst for snow here. Usually snows until early April.
#1599
i live in the high cold desert , the weather is always ****ed up
it was 70* out 2 days ago , will be 10* tom morning ith a high in the 30's, and next week we will be back into th 60's
#1600
picking up a relay board and cable form joe on tuesday , should clean up the engine wiring alot , will be my first time using one of the relay boards for an ms
it was 65* out yesterday so i decided not to take the car into the shop for the winter just yet not sure ill get to do much with it this week hopefulyl the weather will stay inthe 60's for 2 weeks though as id like to get the car out for one nice long drive before i take it in for winter
