B&M megashifter mounted to firebird console?
Old 10-16-2016, 02:19 PM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
Axle/Gears: 9 Bolt 3.45
Hey guys, this is the last little P.I.T.A I have to deal with involving my floor pan repair and interior swap, I decided to replace the Camaro center console that the P.O put in my car with the correct Trans Am center console. One thing I forgot was that the B&M megashifter plate was not meant to be mounted to these center plates. has anyone done this? is there any alternatives instead of using the plate B&M provides? I do a lot of metal work for my job so I'm sure I could fab something up but I barely have enough time to work on this car as it is. thanks
the plate comes very close to either blocking the ashtray switch or covering the power mirror cutout. I'd like to retain both if possible.
Old 10-17-2016, 05:52 PM
TylerSteez's Avatar
Engine: 383 stroker
Re: B&M megashifter mounted to firebird console?
Well I figured it out on my own, I figure these pics will help someone else later on, luckily the firebird center console plate has a grid design that makes it easy to follow the cuts that I made
Old 10-18-2016, 08:13 AM
Always wondered how I might approach this myself. Thanks for the photos.
Old 10-18-2016, 07:58 PM
TylerSteez's Avatar
Engine: 383 stroker
got it all buttoned up today, the two back screws that hold the b&m plate to the center console plate need to be cut short in order for the center plate to clip into the center console
Old 10-19-2016, 09:50 PM
instro84's Avatar
Car: 89 tta
Engine: turbo v6
Transmission: 200r4
nice got any pics with the boot on?
Old 10-19-2016, 10:36 PM
TylerSteez's Avatar
Engine: 383 stroker
Yep, here you go
Before being cleaned
After cleaned
Old 11-01-2016, 08:39 AM
RenegadeGTA's Avatar
Car: 1987 Pontiac Trans Am GTA
Engine: 388 Stroker
Axle/Gears: 3:73
That looks pretty damn slick mam. Nice work
TylerSteez
Interior Parts Wanted
01-15-2017 01:34 PM
beths91camaro
08-17-2016 11:23 AM
nzwcpn
08-07-2016 01:39 PM
bennyjay
08-06-2016 04:59 PM
Fast-Tony
08-04-2016 03:02 PM
Quick Reply: B&M megashifter mounted to firebird console?
