Members post your RPO codes!
#209
Car: 1991 camaro z28
Engine: 305 tpi
Axle/Gears: G80 G92 3.42
Re: Members post your RPO codes!
Yes sir just painted last week . Putting her back together .
#210
1987 IROC-Z Convertible
Some very unusual stuff on mine for being a convertible. I have not found a lot of Convertibles with G92. I also saw some discussion about 1HV possibly being on 87 only and mine has it. The really weird one on my car is B3E. The best I can come up with is NOISE CONTROL? Anybody have more info on b3E?
It's taken me 5years to restore this car. In all those years looking for parts and restoration info I have seen only one other black convertible with grey leather interior with 5.0TPI/5spd. I saw 2 red ones as well and that is it. Seems a lot of the convertibles came with either TBI/carb or auto trans or both.
RPO Code Description
AC3 ADJUSTER, FRT ST, POWER, 6 WAY, BKT, DRIVER
AG9 ADJUSTER, SEAT, POWER, 6 WAY
AM9 SEAT, RR, SPLIT, BACK, FLDG
AR9 SEAT, FRT BKT, EUROPEAN STYLE, PASS A DRIVER RECL
AU3 LOCK CONTROL, SIDE DR, ELEC
A01 WINDOW, TINTED, ALL SHADED, W/S
A31 WINDOW, POWER OPERATED, ALL DOORS
A90 LOCK CONTROL, RR COMPT LID, REM CONT ELEC RELEASE
B18 ORNAMENTATION, INTR, DELUX
B3E 80db noise pass-by jurisdiction
B34 COVERING, FRONT, FLOOR MATS, CARPETED INSERT
B35 COVERING, REAR, FLOOR MATS, CARPETED INSERT
B4Z IROC PACKAGE
B84 ORNAMENTATION, EXTR MLDG, BODY SIDE
B94 FENDER EMBLEM, Z28
B97 ORNAMENTATION, EXTR MLDG, LOWER ACCENT
CC1 ROOF HATCH, REMOVABLE PANELS, GLASS
CD4 WIPER SYSTEM WINDSHIELD, PULSE
C60 HVAC SYSTEM, AIR CONDITIONER FRT MAN CONTROLS
DD8 MIRROR I/S, R/V, LT SENSITIVE
DG7 MIRROR O/S, LH & RH, REM CONT, ELEC, PAINTED
D08 PAINT, HIGH GLOSS FINISH
D27 COVER, RR COMPT, TRUNK STOW
D34 MIRROR, VISOR VANITY
D7J GEAR, SPEEDO DRIVEN
D88 DECAL, STRIPE, SPORT
E5Z SPEEDOMETER ADAPTER (DELETE)
E7Z VEHICLE SPEED SENSOR DELETE
E9Z SPEEDOMETER KEY (DELETE)
FE2 SUSPENSION SYSTEM, RIDE HANDLING
GM3 AXLE REAR, 3.45 RATIO
G80 AXLE POSITRACTION, LIMITED SLIP
G92 AXLE REAR RATIO, PERFORMANCE
J65 BRAKE SYSTEM, PWR, FRT & RR DISC
KC4 COOLING SYSTEM, HEAVY DUTY ENGINE OIL
K34 CRUISE CONTROL, AUT0MATIC, ELECTRONIC
K68 GENERATOR,105 AMP
LB9 ENGINE, GAS, 8 CYL, 5.0L, TPI, HO
MM5 MERCHANDISED TRANS, MAN 5 SPD PROVISIONS
M39 TRANSMISSION, MAN 5 SPD B0RG WARNER, 77MM, 2.95
NB2 EMISSION SYSTEM , CALIFORNIA , TIER O
NOD NORWOOD ASSEMBLY PLANT
NP5 LEATHER WRAPPED, STEERING WHEEL AND SHIFT ****
N33 STEERING COLUMN, TILT TYPE
N65 WHEEL & TIRE,SPARE, SPACE SAVER, STEEL
N96 WHEEL, 16 X 8, CAST ALUMINUM
PB4 LOCK CONTROL, WHEEL
P20 HUBCAPS, WHEEL, STYLED
QDZ TIRE ALL, P245/50VR16/N BL R/PE ST TL HW4
TR9 LAMP, GROUP
TT4 HEADLAMPS, HALOGEN, 4
T93 TAIL & STOP LAMP, SMOKED
T96 FOG LAMPS - FRONT
UQ1 RADIO PROVISIONS, FOR STEREO
UX1 RADIO, AM/FM STEREO, CASSETTE, EQUALIZER
U21 CLUSTER, INST, OIL, COOL TEMP, VOLTS, TACH
U25 LAMP, INTR, RR COMPT, COURTESY
U26 LAMP, INTR, ENG COMPT, COURTESY
U29 LAMP, INTR I/P, COURTESY
U75 ANTENNA, RADIO ----DELETE
VAN ASSEMBLY PLANT, VAN NUYS, CA
VG8 VEHICLE, BUYER NOTICE LABEL
VK3 LICENSE PLATE, FRT MOUNTING PKG
V73 VEHICLE STATEMENT, USA/CANADA
YA7 TEST, EMMISSION, CALIFORNIA ASSEMBLY LINE
YF5 CERTIFICATION, EMISSION, CALIFORNIA
YR1 SEAT,FRT CUSTOM
YS1 SEAT,RR CUST
YT1 BUILD UP DR & QTR
YT9 OPTION PACKAGE, FISHER FURNISHED PARTS
Z28 MERCHANDISED PKG, SPECIAL PERFORMANCE
1AA SALES INCENTIVE-RETAILAMENITIES-DELETE
1AY STOCK ORDERS PROCESSING OPTION (DEALER ORDERED CAR
1AZ CUSTOMER ORDERS PROCESSING OPTION?
1HV components or IROC-Z performance package
1SC OPTION PACKAGE 03
15P WHEEL COLOR SILVER METALLIC (91)
19Q MOLDING COLOR (BLACK)
19T BACK CONVERTIBLE TOP?
41U PRIMARY COLOR, EXTERIOR, BLACK
6ZX SPRING, COMPUTER SELECTED, FRONT, LEFT HAND
7ZX SPRING, COMPUTER SELECTED, FRONT, RIGHT HAND
8NL SPRING, COMPUTER SELECTED, REAR, RIGHT HAND
82I INTERIOR TRIM, MED DK GRAY (91)
822 TRIM COMBINATION, LEATHER, MED DK GRAY (2) (91)
829 SEAT BELT COLOR, MED DK GRAY (91)
86A STRIPE COLOR, ACCENT, TWO TONE RED/GUNMETAL (91)
9NL SPRING, COMPUTER SELECTED, REAR, RIGHT HAND
B4Z IROC PACKAGE
TR9 LAMP, GROUP
YR1 SEAT,FRT CUSTOM
YS1 SEAT,RR CUST
#212
Transmission: 5-Speed Manual
How Can This Have Both Dealer Ordered And Customer Ordered RPO's.
![](https://cimg7.ibsrv.net/gimg/www.thirdgen.org-vbulletin/660x389/untitled_12a3be39743ad41670b7d2246e2682728456bc96.jpg)
#213
An internet search for "80db noise pass-by jurisdiction" returns a lot of different noise testing topics related to transportation.
Example: http://www.eng-tips.com/viewthread.cfm?qid=162080
#216
Are you certain? I am 99.9% sure I have seen TPI/700R combo on the 87 IROC convertible. I don't think TPI was only available with T5. I do believe that all the 5 speeds were G92 tho and the TPI/700R was not.
#219
AC3 6-WayPower Seat
AG9 PowerDriver’s Seat
AM9 Split-Backrear seat
AR9 Recliningseat
AV3 CargoHook (T-top bag hooks)
A01 TintedGlass
A31 Powerwindows
A90 Hatchpower pull-down
B18 Deluxeinterior
B2C 5.7liter Performance Package
B3W Advancedprice sheet processing option
B35 Carpetedfloor mats
B84 Bodyside moulding
B91 Dooredge guard
CC1 T-tops
CD4 Pulsewipers
C49 Rearwindow defogger
C60 Airconditioning
C95 Interiorreading lamps
DG7 Powermirrors
D34 Visorvanity mirror
D42 Day/nightrearview mirror
D6E Speedometer,gear driven
D80 Rearspoiler
D88 Sportstripe
E5Z Speedometeradapter delete
E7Z Unknown
FE2 Ridehandling suspension
GH3 2.77gear ratio differential
G80 Positraction,limited slip
JG1 Aluminumdriveshaft
J65 4-wheeldisc brakes
KC4 Engineoil cooler
K34 Cruisecontrol
K68 105amp alternator
L98 5.7liter TPI engine
MD8 700-R4automatic transmission
MX0 Automatictransmission provisions
NA5 Federalemissions
NP5 Leatherwrapped steering wheel and shifter
N33 Tiltwheel
N64 Spacesaver spare, aluminum
N96 Castaluminum wheels
PB4 Wheellocks
QDZ 245/50/VR16“Gatorback” tires
TR9 Lampgroup
TT4 Halogenheadlamps
T93 Specialbrake lamps
T96 Foglamps
UQ1 Stereoprovisions
UX1 AM/FM/Cassettewith 3-band equalizer
U25 Rearcargo interior courtesy lamp
U26 Underhood light
U29 Interiorcourtesy lamp
U75 Powerantenna
U79 Instrumentcluster, kilometers/miles
VAN VanNuys, California assembly
V73 Vehiclestatement, US/Canada
WW4 Appearancegroup, Aero #4
W62 Ornamentation,aero package
YR1 Customfront seat
YS1 Customrear seat
YT1 Buildup driver and quarter
Z28 Z28Performance package
1AZ Customerordered
1SC Optionpackage #3
15P Silverwheels
19Q Mouldingcolor black
41U Bodycolor black
6ZW Computerselected suspension spring, left front
7ZW Computerselected suspension spring, right front
8NL Computerselected suspension spring, left rear
81A Two-tonestripe, red/black
82C Clothseats, medium gray
82I Interiormedium dark gray
829 Seatbelt, medium dark gray
9NL Computerselected suspension spring, right rear
I had no idea that the 1SC was a top of the line IROC. The only option mine lacks is the D42 locking cargo cover.
AR9 Recliningseat
A01 TintedGlass
A31 Powerwindows
B18 Deluxeinterior
B91 Dooredge guard
CC1 T-tops
CD4 Pulsewipers
C60 Airconditioning
DG7 Powermirrors
D80 Rearspoiler
D88 Sportstripe
E7Z Unknown
K34 Cruisecontrol
N33 Tiltwheel
PB4 Wheellocks
TR9 Lampgroup
T96 Foglamps
U26 Underhood light
U75 Powerantenna
YS1 Customrear seat
1AZ Customerordered
15P Silverwheels
41U Bodycolor black
#220
Of all of the documented '87 factory convertibles I have, only one is listed as an LB9/Auto. All of the autos I have documented are LG4s. I will flag that one and see if I can find any more info on it, but I believe they should all be LB9/5 speeds.
#221
Interesting. I though I'd read pretty much everything out there on the 87 convertibles. I'm not disputing what you're saying but may I ask, where'd you get his info? What's the source? I'm always down for getting more knowledge on these cars. Thanks
#222
The 1987 Order Guide requires the manual trans with the LB9 engine. When selecting the LG4, you automatically got the 700R4 trans and it wan't available with a manual. Again, this is straight from the order guide.
#223
How odd that I never really noticed what you're saying. I am certain that some time ago I saw an LB9/Auto on CL (I think in Michigan) so I never took the time to study the order guide very carefully on this subject. But now that you point this out I spent a little time hunting down the 87 Conv cars that I know of and I'll be darned if you're not spot on correct. I cannot presently find an LB9/Auto. But I know there are at least a couple of them out there.
So now my BIG question is... are there any numbers on how many of the 744 were LB9/T5 and how many were LG4/Auto. Or at least any best guesses? As noted, I own one and I've got my eye on another one right this moment.
#224
#225
Car: IROC Z
Engine: 5.7 L
Transmission: 700R
AC3 - 6-WAY POWER DRIVERS SEAT
AG9 - 6 WAY POWER BUCKET
AM9 - SEAT, REAR, SPLIT, BACK, FOLDING
AR9 - SEAT, FRONT BUCKET, EUROPEAN STYLE, PASS DRIVER RECLINE
AU3 - LOCK CONTROL, SIDE DOOR, ELECTRIC
A01 - WINDOW, TINTED, ALL SHADED, W/S
A31 - WINDOW, POWER OPERATED, SIDE
A90 - LOCK CONTROL, REAR COMPARTMENT LID, REMOTE CONTROL
ELECTRIC RELEASE
B18 - ORNAMENTATION INTERIOR ( DELUXE )
B2L - PERFORMANCE PACKAGE & ENGINE PACKAGE V8 5.7L TPI
B34 - COVERING, FRONT FLOOR MATS CARPETED INSERT
B35 - COVERING, REAR, FLOOR MATS CARPETED INSERT
B4Z - IROC Z PERFORMANCE AND APPEARANCE PACKAGE
B48 - TRIM EQUIPMENT, LUGGAGE COMPARTMENT
B9K - ORNAMENTATIO SIDE MOULDINGS
B94 - ORNAMENTATION EXTERIOR BODY EMBLEM
B97 - ORNAMENTATION EXTERIOR LOWER MOLDING ACCENT
CD4 - WIPER SYSTEM WINDSHIELD, PULSE
C49 - DEFOGGER, REAR WINDOW, ELECTRIC
C60 - HVAC SYSTEM, AIR CONDITIONER FRONT MANUAL CONTROLS
DD8 - MIRROR I/S, R/V, LT SENSITIVE
DG7 - MIRROR O/S, LH & RH, REMOTE CONTROL, ELECTRIC, PAINTED
DK6 - CONSOLE ROOF, INTERIOR
D08 - PAINT HIGH GLOSS FINISH
D34 - MIRROR, VISOR VANITY
D42 - SHADE, REAR COMPARTMENT SECURITY
D6M -
D80 - EXTENSION REAR END PANEL ( SPOILER )
D88 - DECAL, STRIPE, SPORT
E5Z - SPEEDOMETER ADAPTER (DELETE)
E7Z - KEY, SPEEDOMETER (DELETE)
E9Z - KEY, SPEEDOMETER (DELETE)
FE2 - SUSPENSION SYSTEM, RIDE HANDLING
GW6 - AXLE, REAR 3.27 RATIO
G80 - AXLE, POSI-TRACTION, LIMITED SLIP
KC4 - COOLING SYSTEM, ENGINE OIL
K34 - CRUISE CONTROL, AUTOMATIC, ELECTRONIC
K68 - ALTERNATOR, 105 AMP
L98 - ENGINE, GAS, 8 CYL, 5.7L, TPI (1987-1992 ONLY)
MD8 - TRANSMISSION, AUTO 4 SPEED, 700R4
MXO - MERCHANDISED, TRANS, AUTO PROVISIONS, O/D
NA5 - EMISSION SYSTEM, FEDERAL, TIER 0
NOD - ASSEMBLY PLANT, NORWOOD, OHIO
NP5 - LEATHER WRAPPED, STEERING WHEEL AND SHIFT ****
N33 - STEERING COLUMN, TILT TYPE
N65 - WHEEL & TIRE, SPARE, SPACE SAVER, STEEL
N96 - WHEEL, 16X8, ALUMINUM
PB4 - LOCK CONTROL, WHEEL
P20 - WHEEL HUBCAP, BRIGHT ALUMINUM
QDZ - TIRE ALL, 245/50VR16
TR9 - LAMP, GROUP
TT4 - HEADLAMPS TUNGSTON QUARTS HALOGEN
T93 - TAIL & STOP LAMP, SMOKED
T96 - LAMP, FOG
UQ1 - RADIO PROVISIONS, FOR STEREO
UX1 - RADIO, AM/FM STEREO, CASSETTE, EQUALIZER
U21 - CLUSTER, INSTRUMENTS, OIL, COOL TEMP, VOLTS, TACHOMETER
U25 - LAMP, INTERIOR, RR COMP, COURTESY
U26 - LAMP INTERIR ENGINE COMPARTMENT COURTESY
U29 - LAMP, INTERIOR, I/P, COURTESY
U75 - ANTENNA, POWER, RADIO
U79 - SEAKER SYSTEM 4 DUAL FRONT COAXIAL DUAL EXTENDED RANGE
PACKAGE SHELF
VK3 - LICENSE PLATE, FRONT MOUNTING PACKAGE
V73 - VEHICLE STATEMENT, US/CANADA
X07 - 9.5 INCH DANA SPO
YR1 - SEAT, FRONT CUSTOM
YS1 - SEAT, REAR CUSTOM
YT1 - BUILD UP DOOR & QTR
YT9 - OPTION PACKAGE, FISHER FURNISHED PARTS
Z28 - PERFORMANCE PACKAGE ( SPECIAL )
Z31 - ADVANCED PRICE SHEET, CANADIAN MODELS
Z49 - EXPORT, CANADIAN MOD MANDATORY BASE EQUIPMENT
1AY - DEALER ORDERED VEHICLE
1HV -
15P - WHEEL COLOR, SILVER METALLIC
23U - PAINT COLOR BRIGHT BLUE
6ZX - SPRING, COMPUTER SELECTED, FRONT, LEFTHAND
7ZX - SPRING, COMPUTER SELECTED, FRONT, RIGHTHAND
8NL - SPRING, COMPUTER SELECTED, REAR, LEFTHAND
829 - SEAT BELT COLOR, MEDIUM DARK GRAY
82C - TRIM COMBINATION, CLOTH, MEDIUM DARK GRAY
82I - INTERIOR TRIM, MEDIUM DARK GRAY
86A - ACCENT STRIP TWO TONE LIGHT SILVER/BLACK
ELECTRIC RELEASE
D6M -
TR9 - LAMP, GROUP
T96 - LAMP, FOG
PACKAGE SHELF
1HV -
#226
Car: 1991 Firebird
Engine: 5.0 TBI
1991 FireBird.
AH3
AJ3
AN4
ARP
AU3
A31
A90
BC8
B84
CC1
C41
C49
DC4
DE4
DG7
D42
D5V
D8M
D80
E5Z
E9Z
FE1
GU4
IPC
J41
K05
K34
K60
L03
MM5
M39
NA5
N24
N36
QPH
R7G
T61
T96
UB3
UM6
UQ1
U19
U62
VAN
VK3
V73
W68
Z31
Z49
1SC
18P
24Q
6XT
7XT
8UY
82C
82I
829
9UY
98U
AH3
AJ3
AN4
ARP
AU3
A31
A90
BC8
B84
CC1
C41
C49
DC4
DE4
DG7
D42
D5V
D8M
D80
E5Z
E9Z
FE1
GU4
IPC
J41
K05
K34
K60
L03
MM5
M39
NA5
N24
N36
QPH
R7G
T61
T96
UB3
UM6
UQ1
U19
U62
VAN
VK3
V73
W68
Z31
Z49
1SC
18P
24Q
6XT
7XT
8UY
82C
82I
829
9UY
98U
#229
Car: 1986 Z28 Camaro
Transmission: 4 speed auto
Axle/Gears: 3.27-3.43, haven't pulled pumpkin
I'll add a picture of the car as it is now. Far from what it should be. I've decoded most of them But still missing these rpos meanins; ABL, B4K, D67, GAM, GC6, YK8, 1Q8, 53A, 628, 629, 68U.
Also, what is the bccc for. I also have these numbers wa u8757 u8757 62B
#230
BCCC = Base Coat Clear Coat
WA U8757 = Dark Brown Metallic paint (Water based, Upper color)
62B - Saddle, standard cloth
#231
Where can I order paint from. I've had plenty of these cars, but really a novice on this site, and info pertaining to them. Trying to restore to factory for the most part. Is this a rare option car¿
#232
You can get paint from any automotive paint supply location. Not a rare optioned car at all. There aren't many options listed. In '86, all options were individual and not packaged like they were starting in '87. Looks like a typical Z28 with the 305 TPI and G92 performance axle set up.
#233
Alright then, thanks so much for the info. Will a parts store carry enough paint to paint the whole car?
#234
Are you planning to paint it with spray cans or with actual automotive paint through a paint gun? You need to do a lot of research on this if its your first try at painting. There is a ton of prep work before you ever start with the first coat of primer or paint. Poor prep work = horrible paint job!
#235
Right now I'm in the process of getting everything down to bare metal and fixing any dents, and filling with body filler for a smooth surface. I would like to use automotive paint and a gun to do this myself( and 2 younger son's) back to factory color. Will be starting a build thread here soon. After I've collected info
#236
I would highly recommend an automotive/bodywork class at a local Community College, if you want a good result. Base coat, clear coat is pretty forgiving and errors can be fixed or touched up, but some training before you start will be a big help. You will have a lot of time and money in this, so you want to have as much knowledge as possible before you start.
#237
I did that in high school. But I've also helped friends out over the years do body prep work, so I'm no stranger to that stuff, but I've never laid down primer or paint. I'll see if I have any classes in my area to brush up a bit first.
#242
Car: '88 GTA
My new (to me of course) 1988 Gunmetal Grey GTA. In for a repaint atm but I sure do miss it already LOL
![](https://cimg6.ibsrv.net/gimg/www.thirdgen.org-vbulletin/2000x1504/img_0406_8677b8b4d05c1188a127368105693d7a1a14b443.jpg)
![](https://cimg6.ibsrv.net/gimg/www.thirdgen.org-vbulletin/960x720/39453950_10156323812975259_6241698808170807296_n_copy_c97933876a276d17d3bd35a126c99ccff99762b3.jpg)
#243
Great color choice!
Of the five GTA colors available in 1988, your 87U color was by far the rarest. Per Pontiac, only 1036 units built. All were matched with the WW3 Gray colored W62 Aero Kit. No other GTA color got the WW3.
N10 Dual Cat Exhaust was not available yet, but you do have GW6, the 9-bolt rear end (3.27 ratio). The 1990-92 GTAs had 10-bolts.
Nice ride!
Nice ride!
#245
Car: 1987 Z28 Vert.
Engine: LG4: ENGINE, GAS, 8 CYL, 5.0L, 4BBL
Transmission: MD8: 4 SPEED AUTO THM700R4
Axle/Gears: GU2: AXLE, REAR 2.73 RATIO
AC3: 6 WAY POWER DRIVER SEAT
1987 Camaro Z28 Vert 6th digit "3" 8th digit "H"
AG9: POWER DRIVER SEAT
AR9: FRONT DELUXE BUCKET SEAT
AU3: POWER DOOR LOCKS
A01: TINTED GLASS
A31: POWER WINDOWS
A90: POWER HATCH RELEASE
B18: ORNAMENTATION DELUXE
B34: COLOR KEYED FLOOR MATS FRONT
B35: COLOR KEYED FLOOR MATS REAR
B84: BODY SIDE MOULDING
B94: EXTERIOR EMBLEM BODY VAR1
B97: EXTERIOR MOULDING LOWER ACCENT
CC1: REMOVABLE GLASS ROOF PANELS (STARTED AS TTOP CONVERTED TO CONVERTIBLE)
CD4: INTERMITTMENT WINDSHIELD WIPERS
C60: AIR CONDITIONING
DG7: TWIN ELECTRIC SPORT MIRRORS
DD8: MIRROR INTERIOR REARVIEW AUTO
D34: VANITY MIRROR
D60: SPEEDOMETER DRIVEN GEAR, TRIM INCOMPATABILITY OVERRIDE
D88: DECAL SPORT STRIPE
E5Z: SPEEDOMETER ADAPTER DELETE
E7Z: KEY SPEEDOMETER DELETE
E9Z: KEY SPEEDOMETER DELETE
F41: FIRM RIDE HANDLING SUSPENSION FRONT REAR
J42: POWER BRAKE FRONT, REAR ALUMINUM DRUM
J50: POWER BRAKE SYSTEM
K34: CRUISE CONTROL WITH RESUME
K60: 100 AMP ALTERNATOR
MXO: AUTO WITH OVERDRIVE
NA5: STANDARD EMISSION SYSTEM
NOD: ASSEMPLY PLANT NORWOOD, OHIO
NP5: LEATHER WRAP STEERING WHEEL AND SHIFTER **** (CHANGED TO AFTER MARKET)
N33: COMFORT TILT STEERING WHEEL
N65: SPACE SAVER STEEL SPARE
N90: 15X7 ALUMINUM WHEELS
PB4: LOCK CONTROL WHEELS
P20: WHEEL HUBCAPS ( CHANGED TO Z28 BLACK INSERTS)
QYZ: TIRES P215/65R 15
TR9: AUXILLARY LIGHTING
TT4: HEAD LAMPS HIGH LOW HALOGEN (CHANGED TO AFTER MARKET HID)
T93: SMOKED TAIL/STOP LAMPS
T96: FOG LAMPS HALOGEN (CHANGED TO AFTER MARKET HID)
UA1: HEAVY DUTY BATTERY
UQ1: RADIO PROVISION STEREO
UX1: CUSTOM RADIO UPGRADE (CHANGED TO AFTER MARKET)
U21: GAGE PACKAGE WITH TACHOMETER
U25: INTERIOR COURTSEY LAMP
U26: INTERIOR ENGINE COMPARTMENT LAMP
U29: INTERIOR I/P COURTSEY LAMP
U75: POWER RADIO ANTENNA
U79: DUAL FRONT/REAR COAXIAL SPEAKERS
V73: VEHICAL STATEMENT US/CANADA
YR1: FRONT CUSTOM SEATS
YS1: REAR CUSTOM SEAT
YT1: BUILD UP DOOR AND QTR
YT9: OPTION PACKAGE PARTS FURNISHED BY FISHER
Z08: CONVERTIBLE
Z28: SPORT
1AA: SALES INCENTIVE
1AZ: CUSTOMER ORDERED VEHICLE
1PV: SPECIAL PERFORMANCE VEHICLE
1SC: Z28 CONVERTIBLE PACKAGE 3 WITH UX1 W/O D42
19Q: MOULDING BLACK
41U: ORIGINAL BLACK (REPAINTED TO GM#81 DURING CONVERSION TO CONVERTIBLE)
49A: 2 TONE STRIPE ACCENT
6ZX: SPRING COMPUTER SELECTED FRONT LEFT
62C: TRIM DARK GRAY (CHANGED TO SADDLE TAN DURING CONVERSION)62C = S-cc
62I: INTERIOR TRIM
67T: #94 SADDLE COLOR
7ZX: SPRING COMPUTER SELECTED FRONT RIGHT
8NM: SPRING COMPUTER SELECTED LEFT REAR
9NM: SPRING COMPUTER SELECTED RIGHT REAR
92P: NA
1FP87: CUSTOM CLOTH BUCKET
A01: TINTED GLASS
A31: POWER WINDOWS
D34: VANITY MIRROR
Z08: CONVERTIBLE
Z28: SPORT
19Q: MOULDING BLACK
62I: INTERIOR TRIM
92P: NA
#246
1991 Base 3.1v6 Firebird - imported new to Switzerland, now in United Kingdom... one mystery code R6U - anyone?
AAA Standard Equipment
AJ3 DRIVER SIDE INFL RESTRAINT SYSTEM
AR9 SEAT,FRONT BUCKET,DRIVER,PASSENGER,MANUAL RECLINING(EUROPEAN STYLE)
AU3 LOCK,SIDE DOOR,ELECTRIC
A31 WINDOW,ELECTRIC OPERATED,SIDE
BC8 ORNAMENTATION,INTERIOR,FRONT DOOR MAP POCKET RH AND LH
B84 ORNAMENTATION,EXTERIOR,BODY SIDE MOLDING
CC1 ROOF,HATCH,REMOVABLE PANELS,GLASS
C49 DEFOGGER,REAR WINDOW,ELECTRIC
C60 AIR CONDITIONER,FRONT,MANUAL CONTROLS
DC4 MIRROR,INSIDE,REARVIEW TILT,DUAL READING LAMP
DD9 MIRROR,OUTSIDE,RH AND LH REMOTE CONTROL ELECTRIC,BREAKAWAY(PAINTED)
DE4 SUNSHADE,REMOVABLE HATCH ROOF
LH0 ENGINE,3.1L(3.1T),V6,MFI LH0 ENGINE,3.1L(3.1T),V6(EXPORT
MAE MARKETING AREA EUROPE(EXPORT)
MD8 TRANSMISSION,AUTOMATIC 4-SPEED(THM700R4/4L60)
MX0 TRANSMISSION,AUTOMATIC,OVERDRIVE(MERCHANDISING OPTION)
NA5 EMISSION SYSTEM,FEDERAL REQUIREMENTS
N24 WHEEL,15X7(CAST ALUMINUM)
N36 STEERING WHEEL,SPORT-4 SPOKES
QNS TIRE,P215/65R15/N
R6U <----What is this one????
UB3 CLUSTER,INSTRUMENT(OIL,COOLANT TEMPERATURE,VOLTMETER,TACHOMETER,TRIP ODOMETER)
UL2 RADIO FREQUENCY(EUROPEAN)
UQ1 RADIO,PROVISIONS FOR STEREO
UX1 RADIO,AM/FM STEREO,WEATHER,CASSETTE,EQUALIZER,ETR,INCLUDES CLOCK
U19 SPEEDOMETER,INSTRUMENT,KILOMETERS PER HOUR
U62 SPEAKER SYSTEM,4,DUAL COAX FRONT,DUAL COAX PACKAGE SHELF
U75 ANTENNA,POWER(CHROME)
VAN PLANT CODE VAN NUYS, CA, CPC
VC5 LABEL - SHIPPING, EXCEPT US, US POSSESSIONS, OR JAPAN LABEL
VK3 LICENSE PLATE,FRONT MOUNTING PACKAGE
V78 VEHICLE STATEMENT(DELETE)(EXPORT)
Y81 FIREBIRD PACKAGE(MERCHANDISING OPTION)
1SB PACKAGE-OPTION 02
18P WHEEL COLOR,CHARCOAL METALLIC
45Q MOLDING COLOR,MEDIUM GREEN METALLIC
45U EXTERIOR COLOR-MEDIUM GREEN METALLIC
6XR COMPONENT FRT LH COMPUTER SEL SUP (6XR)
66C TRIM COMBINATION,CLOTH,BEECHWOOD
66I INTERIOR TRIM,MEDIUM BEECHWOOD
669 SEAT BELT COLOR,MEDIUM BEECHWOOD
7XR COMPONENT FRT RH COMPUTER SEL SUP (7XR)
8UY SPRING-COMPTR SELECT RR LH
9UY SPRING-COMPTR SELECT RR RH
#247
Here are mine - 1992 Firbird Formula 305 TBI.
AH3 - ADJUSTER, 4-WAY MANUAL, DRIVERS SEAT
AJ3 - RESTRAINT SYSTEM, FRONT SEAT, INFLATABLE, DRIVER
AN4 - RESTRAINT PROVISION, CHILD (CANADIAN)
A90 - LOCK CONTROL, REAR COMPARTMENT LID, REMOTE CONTROL ELECTRIC RELEASE
BC8 - ORNAMENTATION, INTERIOR, DOOR MAP POCKETS
B84 - ORNAMENTATION, EXTERIOR MOLDING, BODY SIDE
CC1 - ROOF HATCH, REMOVABLE PANELS, GLASS/LEXAN
DC4 - MIRROR I/S, R/V, TILT, DUAL READING LAMPS
DE4 - SUNSHADE, REMOVABLE HATCH ROOF
D7C - SPEEDOMETER DRIVEN GEAR
D8N - SENSOR, VEHICLE SPEED
D81 - SPOILER, REAR, AERO WING
GU2 - AXLE, REAR 2.73 RATIO
IPC - TRIM, INTERIOR DESIGN
J41 - BRAKE SYSTEM, POWER, FRONT DISK, REAR DRUM, CAST IRON
K05 - ENGINE HEATER, BLOCK
L03 - ENGINE, GAS, 8 CYL, 5.0L, TBI
N36 - STEERING WHEEL, 4 SPOKES, SPORT
PW7 - WHEEL, 16X8, ALUMINUM, DIAMOND SPOKE
QLC - TIRE ALL, 245/50ZR16
T61 - DAYTIME RUNNING LAMPS (CANADIAN)
UB3 - CLUSTER, INSTRUMENTS, OIL, COOL TEMP, VOLTS, TRIP ODOMETER, TACHOMETER
U19 - SPEEDOMETER, INSTRUMENT PANEL (CANADIAN)
U62 - SPEAKER SYSTEM, DUAL COAXIAL
VAN - ASSEMBLY PLANT, VAN NUYS, CALIFORNIA
WS6 - PERFORMANCE PACKAGE, SPECIAL
W66 - MERCHANDISED PACKAGE, FORMULA
1SC - PACKAGE, OPTION 03
1SZ - PACKAGE, OPTION ??
10Q - MOLDING COLOR, ARCTIC WHITE
10U - PRIMARY COLOR, ARCTIC WHITE
41P - WHEEL COVER, BLACK
6ZW - SPRING, COMPUTER SELECTED, FRONT, LEFTHAND
64C - TRIM COMBINATION, CLOTH, LIGHT BEIGE
64I - INTERIOR TRIM, LIGHT BEIGE
649 - SEAT BELT COLOR, LIGHT BEIGE
7ZW - SPRING, COMPUTER SELECTED, FRONT, RIGHTHAND
9NL - SPRING, COMPUTER SELECTED, REAR, RIGHTHAND
I have a couple of questions about that :
- what means "SPRING, COMPUTER SELECTED" (whatever rear, front, left or right)
- what could be those options 1SC - PACKAGE, OPTION 03 and 1SZ - PACKAGE, OPTION ??
#249
AAA = Standard Equipment
AH3 = Seat Adjuster, Manual 4-way Driver
AK1 = Seat Belts, Custom Front & Rear
AR9 = Seat, Front Bucket, Passenger / Driver, Recline, Outside
AU3 = Door Locks, Power
A01 = Windows, Tinted, All Shaded, W/S
A31 = Windows, Power
A90 = Lock Control, Rear Compartment Lid, Remote Control Electric Release
BV3 = Ornamentation, Interior, Instrument Panel, Black
BY4 = Ornamentation, Instrument Panel Name Plate
B34 = Covering, Front Floor Mats, Carpeted Insert
B35 = Floor Mats, Front & Rear
B67 = Container, Radio Cassette Tape
B84 = Moldings, Vinyl Bodyside
CC1 = Roof Panels, Hatch (Removable)
CD4 = Wiper System, W/S, Pulse
C49 = Defroster, Rear Window, Electric
C60 = Air Conditioning, Custom
DE4 = Sunshade, Hatch Roof, Removable
DG7 = Mirror, Outside Left-hand & Right-hand
D14 = Arm Rest, Front Door, Left-hand & Right-hand
D34 = Mirror, Inside, Sunshade
D42 = Cargo Screen, Rear
D7C = Gear, Speedo Driven
D81 = Spoiler, Rear Aero Wing
D9A = Sensor, Vehicle Speed
E5Z = Adapter, Speedometer (Delete)
E9Z = Key, Speedometer (Delete)
FE2 = Suspension System, Ride & Handling
GU2 = Axle, Rear, 2.73 Ratio
J50 = Brake System, Power
K34 = Cruise Control, Electronic
K60 = Generator, 100 amp
L03 = TBI 305, 170 HP @ 4000 RPM, 255 TQ @ 2400 RPM
MD8 = Transmission, Automatic Overdrive
MX0 = Transmission, Automatic Overdrive Provisions
NA5 = Emissions, Federal Requirements
NP5 = Leather Wrapped Steering Wheel & Shift ****
N33 = Steering Wheel, Tilt
N65 = Spare Wheel & Tire, Stowaway
PB4 = Lock Kit, Aluminum Wheel
PW7 = Wheels, 16” Aluminum Diamond-spoke
QDZ = Tires, 245/50-VR16 Radial
TR9 = Lamp Group, Courtesy
T93 = Lamps, Tail & Stop, Smoked Lens
T96 = Lamps, Front Fog
UF6 = Lamp, Interior Console, Courtesy
UM6 = Radio, AM/FM Stereo, Seek/Scan, Auto-reverse Cassette
UQ1 = Radio, Stereo Installation Provisions
UQ7 = Speaker System, Subwoofer
UT1 = Buzzer, Tone Generator Warning
U25 = Cluster, Instrument, Oil, Coolant Temperature, Tachometer, Trip Odometer
U29 = Lamp, Interior, Instrument Panel Courtesy
U75 = Antenna, Power Automatic
VAN =Van Nuys, CA Assembly Plant
V73 = Vehicle Statement, USA/Canada
WS1 = Per Mantaguy, “The WS1 is a Pontiac Option Pac for savings. You had to order Hatch Roof, Tilt Wheel and Cruise Control to qualify for the savings.”
WS4 = Merchandising Option Package, Trans Am
WS6 = Suspension, Special Performance
WW8 = Appearance Package, (Bright Red), Aero #8
W62 = Ornamentation, Aero Package
1SB = Option Package 02
6ZX = Spring, Computer Selected, Left Front
7ZX = Spring, Computer Selected, Right Front
8NL = Spring, Computer Selected, Left Rear
81P = Wheel Color, Bright Red (91)
81Q = Molding Color, Bright Red (91)
81U = Primary Color, Exterior, Bright Red (91)
82B = Trim Combination, Cloth, Medium Dark Grey (91)
82i = Interior Trim, Medium Dark Grey (91)
829 = Seat Belt Color, Medium Dark Grey (91)
9NL = Spring, Computer Selected, Right Rear
BCCC WA- L8774 U8774 82B
#250
Car: 1986 trans am
Engine: 305/350
Transmission: 5 speed
Vehicle: FIREBIRD TRANS AM 2 DR
Year: 1986
Build Date: Unk.
RPO Description Matches
11Q MOLDING COLOR,WHITE (11Q) 447
19B TRIM COMBINATION,CLOTH,BLACK (19B) 36
19I INTERIOR TRIM COLOR (19I) 413
199 SEAT BELTS COLOR BLACK (19) (199) 500
40U EXTERIOR COLOR,PRIMARY,WHITE (40U) 622
80A STRIPE - ACCENT,TWO-TONE,RED/DK SAPPHIRE (80A) 1,831
84P WHEEL COLOR,GUNMETAL GRAY (84P) 2,743
AAA Unknown 3,412
AR9 SEAT,FRONT BUCKET,DRIVER,PASSENGER,MANUAL RECLINING(EUROPEAN STYLE) MAN RECL FRT BKT ST,DELUXE(AR9) 3,240
A01 WINDOW,TINTED GLASS(ALL WINDOWS) TINTED GLS(A01) 3,359
BS1 INSULATION,ACOUSTICAL INSULATION PKG(BS1) 2,222
BV3 ORNAMENTATION,INTERIOR,INSTRUMENT PANEL(BLACK) I/P ORNAMENTATION(BV3) 3,412
BX5 ORNAMENTATION,EXTERIOR,ROOF DRIP MOLDING(PAINTED) PAINTED DRIP MLDG(BX5) 325
B84 ORNAMENTATION,EXTERIOR,BODY SIDE MOLDING BODY SI MLDG(B84) 2,523
B87 EMBLEM,FENDER(DELETE) B87) 3,412
B97 ORNAMENTATION,EXTERIOR,LOWER MOLDING ACCENT LWR ACNT MLDG(B97) 3,412
C49 DEFOGGER,REAR WINDOW,ELECTRIC ELEC RR WDO DEFG(C49) 3,412
C60 AIR CONDITIONER,FRONT,MANUAL CONTROLS A/C MAN CONT(C60) 2,088
D14 ARM REST,FRONT DOOR,RH AND LH FRT DR A/RST(D14) 3,412
D35 MIRROR,O/S LH REM RH DIRECT CTL,PAINTED PAINTED O/S MIR(D35) 2,506
D42 COVER,REAR COMPARTMENT SECURITY(SHADE) R/CMPT SECURITY SHADE(D42) 2,209
D5R Unknown 323
D60 COLOR OVERRIDE - TRIM & PAINT COMPATIBILITY 3,412
D81 SPOILER,REAR,AERO WING RR AERO WING SPLR(D81) 3,261
D88 STRIPE,SPORT SPORT STRPE(D88) 3,347
D9E Unknown 666
E5Z ADAPTER - SPEEDO - DELETE 3,412
E9Z KEY - SPEEDO - DELETE 3,412
GU5 AXLE,REAR,3.23 RATIO 3.23R(GU5) 1,363
J50 BRAKE SYSTEM,VACUUM POWER VAC PWR BRK(J50) 1,368
K22 GENERATOR,94 AMPERE 94 A(K22) 1,287
LG4 ENGINE,305 C.I.D. 305H,V8-PASS. CAR ONLY 305H(LG4) 2,413
MM5 TRANSMISSION,MANUAL 5-SPEED PROVISIONS(MERCHANDISING OPTION) 5-SPD M/TRANS PROVISIONS(MM5) 666
M39 TRANSMISSION,MANUAL 5-SPEED(BORG-WARNER) 5-SPD M/TRANS(M39) 666
NK3 STEERING WHEEL,SPORT,SOFT RIM,SIMULATED LEATHER SIMULATED LEATHER STRG WHL(NK3) 819
NM5 EMISSION SYSTEM,NON-CLOSED LOOP(CANADA) EMISSION SYSTEM CANADA(NM5) 2,413
NOD Unknown 2,819
N24 WHEEL,15X7(CAST ALUMINUM) AL WHL(N24) 1,505
N33 STEERING COLUMN,TILT TYPE TILT STRG COL(N33) 3,174
QYZ TIRE ALL TIRE(QYZ) 359
T93 LAMP,TAIL AND STOP(SPECIAL) SPECIAL TAIL & S/LP(T93) 3,412
T96 LAMP,FRONT FOG FRT FOG LP(T96) 3,412
UP7 RADIO,PROVISIONS FOR MONAURAL INSTRUMENTATION RDO PROVISIONS(UP7) 172
U21 CLUSTER,INSTRUMENT(OIL,COOLANT TEMPERATURE,TACHOMETER,VOLTMETER) GA CSTR(U21) 3,412
U63 RADIO,AM,PUSHBUTTON(MONO) AM MONO RDO(U63) 172
VK3 LICENSE PLATE,FRONT MOUNTING PACKAGE FRT LIC PLT MTG PKG(VK3) 3,412
V73 Unknown 3,412
WS4 TRANS AM OPTION TRANS AM(WS4) 3,412
WW1 Unknown 622
W62 AERO PACKAGE AERO PKG(W62) 3,412
YT9 FLEET PROGRAM - EXPOSURE INITIATIVE I: C/F/G/H/J/K/M/N/S/U/V/W/Z- TRK CKGMPST 3,412
Z31 IDENTIFICATION - PRICE SHEET ADVANCE 2,989
Z49 MANDATORY CANADIAN BASE EQUIPMENT MODIFICATIONS(CANADIAN) CANADIAN(Z49) 3,412[/QUOTE]
Vehicle: FIREBIRD GTA TRANS AM 2 DR (currently being dismantled for parts,sadly too far gone with central canadian rot)
Year: 1988
Build Date:
Unk.RPO Description
40U EXTERIOR COLOR,PRIMARY (40U)
52P WHEEL COLOR,GOLD METALLIC (52P)
82D TRIM COMBINATION,CLOTH,MEDIUM DARK GRAY CLOTH TRIM(82D)
82I INTERIOR TRIM,MEDIUM DARK GRAY (82I)
829 SEAT BELT COLOR - MED DK GRAY (829)
AK1 RESTRAINT SYSTEM,FRONT,CENTER,REAR SEAT,FRONT SHOULDER(DELUXE) DELUXE BELTS(AK1)
AM9 SEAT,REAR,FOLDING SPLIT BACK FLDG SPLIT BK R/SEAT(AM9)
AQ9 SEAT,FRONT BUCKET,DRIVER,PASSENGER,RECLINING RECL FRT BKT ST,LUXURY(AQ9)
AU3 LOCK,SIDE DOOR,ELECTRIC ELEC S/D LK(AU3)
A31 WINDOW,ELECTRIC OPERATED,SIDE ELEC SI WDO(A31)
A90 LOCK,REAR COMPARTMENT LID,REMOTE CONTROL,ELECTRIC RELEASE ELEC REL LID LK(A90)
BC8 ORNAMENTATION,INTERIOR,FRONT DOOR MAP POCKET RH AND LH DR MAP PKT(BC8)
BY4 ORNAMENTATION,INSTRUMENT PANEL MONOGRAM I/P ORNAMENTATION(BY4)
B2L 350 TPI ENGINE PROVISIONS .
B20 ORNAMENTATION,INTERIOR(LUXURY) LUXURY INTR(B20)
B34 COVERING,FLOOR MATS,FRONT,CARPETED INSERT(COLOR COORDINATED) FRT CPT INS FLR MATS(B34)
B35 COVERING,FLOOR MATS,REAR,CARPETED INSERT(COLOR COORDINATED) RR CPT INS FLR MATS(B35)
B84 BLACK BODY SIDE MOLDING BODY SI MLDG(B84)
CD2 INDICATOR,WINDSHIELD WASHER FLUID LOW FLUID IND(CD2)
CD4 WIPER SYSTEM,WINDSHIELD,PULSE PULSE WPR(CD4)
C67 AIR CONDITIONER,FRONT,ELECTRONIC CONTROLS A/C FRT ELEC CONT(C67)
C95 LAMP,INTERIOR,ROOF COURTESY AND DUAL READING DM & READING LP(C95)
DG7 MIRROR,OUTSIDE,RH & LH REMOTE CONTROL,ELECTRIC(PAINTED) O/S ELEC R/CON PAINTED MIR(DG7)
D3Y Unk.
D34 MIRROR,INSIDE,SUNSHADE S/S MIR WITHOUT ILLUMINATION(D34)
D9B SENSOR (D9B)
FE2 SUSPENSION SYSTEM,RIDE AND HANDLING RIDE & HANDLING SUSP(FE2)
GW6 AXLE,REAR,3.27 RATIO 3.27R(GW6)
G80 AXLE,REAR,POSITRACTION,LIMITED SLIP POSITRACTION L/SLIP R/AXL(G80)
JG1 SHAFT,PROPELLER(ALUMINUM) AL PROP SHF(JG1)
J65 BRAKE SYSTEM,POWER,FRONT AND REAR DISC 4-WHL DISC BRK(J65)
KC4 COOLING SYSTEM,ENGINE OIL ENG OIL CLG(KC4)
K05 HEATER,ENGINE BLOCK ENG BLK HTR(K05)
K34 CRUISE CONTROL,AUTOMATIC,ELECTRONIC CRCONT(K34)
K68 GENERATOR,105 AMPERE 105 AMP(K68)
L98 ENGINE, 5.7L, (5.7-8) 350 CID, V8, TPI 5.7-8(L98)
MD8 TRANSMISSION,AUTOMATIC 4-SPEED(THM700R4/4L60) 4-SPD A/TRANS(MD8)
MX0 TRANSMISSION,AUTOMATIC,OVERDRIVE(MERCHANDISING OPTION) A/TRANS PROVISIONS(MX0)
NA5 EMISSION SYSTEM,FEDERAL REQUIREMENTS FEDERAL EMIS(NA5)
NK4 STEERING WHEEL,SPORT,LEATHER SPORT WHL(NK4)
N64 WHEEL AND TIRE,SPACE SAVER SPARE(ALUMINUM) AL SPACE SAVER SPA(N64)
PB4 LOCK KIT,ALUMINUM WHEEL AL WHL LOCK KIT(PB4)
PW7 WHEEL,16X8,STYLED DIAMOND HONEYCOMB SPOKE,WITH TRANS AM INSIGNIA IN CENTER CAP(BLACK)(ALUMINUM) STYLED AL WHL(PW7)
QDZ TIRE,ALL P245/50VR16/N BL R/PE ST TL HW4 TIRE(QDZ)
TR9 LAMP GROUP,COURTESY LP GRP(TR9)
UA6 THEFT DETERRENT SYSTEM ANTI-THEFT(UA6)
UF6 LAMP,INTERIOR,CONSOLE & COURTESY INTR CNSL & CTSY LP(UF6)
UK3 ELECTRONIC SYSTEM,ACCESSORY CONTROL ELEK ACSRY CONT SYS(UK3)
UQ1 RADIO,PROVISIONS FOR STEREO STEREO RDO PR0VISIONS(UQ1)
UT1 BUZZER,TONE GENERATOR WARNING TONE GEN WRNG BUZZER(UT1)
UT4 RADIO,AM&FM STEREO,CASSETTE,EQUALIZER,INCLUDES CLOCK STEREO CASSETTE/EQLZR(UT4)
UW1 DIAGNOSTIC SYSTEM DIAGN SYS(UW1)
U25 LAMP,INTERIOR,REAR COMPARTMENT COURTESY RR COMPT CTSY LP(U25)
U29 LAMP,INTERIOR,INSTRUMENT PANEL,COURTESY I/P CTSY LP(U29)
U52 CLUSTER,INSTRUMENT(ELECTRONIC) ELEK GA CSTR(U52)
U66 SPEAKER SYSTEM,4,DUAL FRONT DASH MOUNTED,DUAL EXTENDED RANGE PACKAGE SHELF/QUARTER 4 SPKR SYS(U66)
U75 ANTENNA,POWER(CHROME) PWR ANT(U75)
VAN VAN NUYS ASSY PLANT.
V73 Unk.
WS6 PERFORMANCE PACKAGE,SPECIAL(MERCHANDISING OPTION) SPECIAL PERFORMANCE PKG(WS6)
WW1 AERO PACKAGE(WHITE) AERO PKG(WW1)
X05 Unk.
YS1 SEAT,REAR(CUSTOM) CUSTOM RR ST(YS1)
YT1 FLEET PROGRAM - FALL/WINTER/SPRING REPURCHASE
Y84 TRANS AM GTA OPTION(MERCHANDISING OPTION) TRANS AM GTA(Y84)
ZF9 Unk.
Year: 1986
Build Date: Unk.
AAA Unknown 3,412
D5R Unknown 323
D9E Unknown 666
NOD Unknown 2,819
V73 Unknown 3,412
WW1 Unknown 622
Year: 1988
Build Date:
Unk.RPO Description
D3Y Unk.
D9B SENSOR (D9B)
V73 Unk.
X05 Unk.
ZF9 Unk.
