NOS sensors, 85-89 BBK throttle body,Edelbrock Intake manifold, misc tpi parts.
Car: 2011 Camaro 2SSRS w/ Procharger
Engine: 6.2 LS3
Transmission: M6 TR6060
Axle/Gears: 3.45
I have a bunch of stuff up for grabs. Prices are pretty firm, everything is a good value, and shipping is included in the lower 48. So please no low *****.
NOS 85-89 TPI 305 knock sensor- $30 this was $60 new
NOS 85-89 TPI TPS(throttle position sensor)- $50 this was $94 new
Refurbished 85-89 BBK 52mm throttle body. New gaskets all the way around. With no tps $120 firm if you would like it with the new TPS I'll make it $150 firm Saving you on the sensor.
Top end freshen up kit. (Only selling as a kit.) Fel Pro centerbolt valve cover gaskets, Fel Pro Viton seals, and comp cams valve Springs. Perfect to refresh your leaky valve seals. $100
Edelbrock performer eps manifold casting 2701. Comes as you see it. Fresh paint job, chrome water neck, chrome 3in pan filter, and carb studs. $75.
Engine: 6.2 LS3
Axle/Gears: 3.45
Re: NOS sensors, 85-89 BBK throttle body,Edelbrock Intake manifold, misc tpi parts.
Valve spring tolerances.
Valve seal and spring kit, with valve cover gaskets.
Bbk throttle body.
Throttle body butterflies
Engine: 6.2 LS3
Axle/Gears: 3.45
Knock sensor
TPS sensor
Engine: 6.2 LS3
Axle/Gears: 3.45
Bump
Engine: 6.2 LS3
Axle/Gears: 3.45
Bump
Engine: 6.2 LS3
Axle/Gears: 3.45
Bump, prices updated
Engine: 6.2 LS3
Axle/Gears: 3.45
Bump, make me an offer.
Engine: 6.2 LS3
Axle/Gears: 3.45
Prices lowered for the last time. Prices are very fair, and very firm. Will take trades for some stuff. If you have something I'd like we could make a deal.
TGO Supporter/Moderator
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
How is this one?
Engine: 6.2 LS3
Axle/Gears: 3.45
I bought this from a part out on a running car. So as far as I know, it's in good shape. I replaced all the gaskets, and cleaned everything up. Should run nice and smooth. As stated it is just the throttle body. No iacv, or TPS sensor. Unless you would like to pay the extra for the nos one I have
Engine: 6.2 LS3
Axle/Gears: 3.45
Bump
WIll36
09-11-2016 05:32 PM
Bald_eagle_machine
08-27-2016 10:24 PM
kg1922001
08-25-2016 09:06 AM
RunawayRadio
08-23-2016 07:26 PM
