Steering column wiring
Old 09-17-2016, 10:00 PM
LDR
LDR's Avatar
Car: 2012 Impala ltz 1988 Gta project
Ok hopefully my last wiring hiccup. I am working on what is said to be an 88 gta. car is pieced together. Working on steering column I have one plug finished. But there are 4 small wires and another plug i don't have. Is this the radio controls or something else.
Old 09-18-2016, 10:23 AM
Re: Steering column wiring
I can't recall but I would lean towards cruise control or wipers. I'm fooling around with column stuff now on my build and I'm thinking that's what it is. Were both cars of the same transmission?
Old 09-18-2016, 10:28 AM
WNYTransAm's Avatar
The wires coming out of the radio controller/horn pad are yellow, orange, grey and black. So I'm not sure. Maybe, but then what would the blue one do?
Is that your turn signal switch?
Old 09-18-2016, 11:36 AM
LDR
LDR's Avatar
That's the part that's confusing cruise is a small black two pin wire. That's the parts after my turn signal switch wires. Those wires are 22 gauge so they can't carry much voltage. Did they have a light warning system on some cars?
Old 09-18-2016, 12:00 PM
The detailed wiring schematics that I have available are all for 90-92 cars. So it's possible that GM changed the colors. That being said the turn signals should be four wires (Duh, right?) a light blue, dark blue, yellow and dark green.
The wiper controls are also four wires: Pink, Purple, dark Green and Grey.
The horn is a black wire only.
The VATS is a yellow, Pink
An airbag would be White and Dark Green.
Red, Pink and Yellow would be associated with the starter relay
I'm striking out.
Old 09-18-2016, 01:44 PM
LDR
LDR's Avatar
I appreciate the help attempt. I'm trying to find a factory wiring manual. Using a painless harness we have most wired now it's just curiosity wtf these are supposed to do since they don't match any diagrams I have.
That's a wider shot showing turn signal and wipers I already ran.
Old 09-20-2016, 11:25 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Those (5 wires) are for the steering wheel control connector. Got the same ones on my 88 GTA.
Old 10-06-2016, 10:03 PM
LDR
LDR's Avatar
Thanks really appreciate that help. Was scratching my head. With this car i cant assume anything is year specific so colors may be off.
Out-Cast
09-15-2016 04:09 PM
83-Z28-Maniac
09-07-2016 06:32 PM
gt4373
09-01-2016 11:06 PM
gt4373
08-24-2016 11:04 PM
WNYTransAm
Interior Parts Wanted
08-20-2016 10:03 AM
Quick Reply: Steering column wiring
