TPI dual fan setup with custom cover
Old 09-10-2016, 11:57 AM
I have a complete TPI dual fan setup. Factory upper and lower mount and both fans with newer fan motors. I also have the upper fan mount/radiator cover that I made a few years ago that can be sold separate or together. Made of 1/8" aluminum that was spool gun welded. On the back side I cut out the Chevy Bowtie emblem. The mount bolts down exactly as a normal mount does. The fans bolt to the shroud with a 1" spacer.
$200 for the setup with mount that I made
$120 for the setup with only the stock mounts.
PayPal, I'm in Northern Arizona.
Old 09-10-2016, 01:28 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
Re: TPI dual fan setup with custom cover
need paypal info
cash is king..
Old 09-12-2016, 08:53 PM
still need a paypal address
Old 09-13-2016, 10:33 PM
Tried to take better pictures of the weld so people know not to expect a machine welded piece.
Old 09-14-2016, 08:19 PM
funds sent 5 min ago..$225
that's fine..i can run a ball end mill. down it to clean it up and redo it...its a start.so I don't have to take more time to make one from scratch...then who knows..
Z28Johnny
09-16-2016 05:26 PM
jtmiller92
09-11-2016 09:22 PM
Cody Willey
09-10-2016 05:38 PM
86FyrBrd
09-07-2016 08:22 PM
hotrodjames
Southern California Area
09-05-2016 12:46 PM
Quick Reply: TPI dual fan setup with custom cover
