I have a complete TPI dual fan setup. Factory upper and lower mount and both fans with newer fan motors. I also have the upper fan mount/radiator cover that I made a few years ago that can be sold separate or together. Made of 1/8" aluminum that was spool gun welded. On the back side I cut out the Chevy Bowtie emblem. The mount bolts down exactly as a normal mount does. The fans bolt to the shroud with a 1" spacer.
$200 for the setup with mount that I made
$120 for the setup with only the stock mounts.
PayPal, I'm in Northern Arizona.
funds sent 5 min ago..$225
that's fine..i can run a ball end mill. down it to clean it up and redo it...its a start.so I don't have to take more time to make one from scratch...then who knows..
