Fixing my 1988 Firebird Formula....again
#152
Car: 1987 TA GTA, 1987 IROC 1988 Formula
Engine: 350 tpi/305 tpi/350 tbi
Transmission: All have 700r4's
Axle/Gears: 10 bolt with 3:73's
Re: Fixing my 1988 Firebird Formula....again
Front suspension and cross member are out! Been painting some suspension pieces also. The rest of my parts should be here this week, my favorite part of building cars is when the new parts arrive
#153
New parts are fun!
As for that last photo...you're taunting us, aren't you...
#155
Not quite sure how he gets anything done with the "distraction" hehehe
#156
Car: Firebird
Engine: 5737cc
Guess I need to start posting more pictures of myself on here I guess
I've been painting my suspension parts as they come in. I forgot to get some pictures of them . But I primed my rearend, seat brace is drilled off, windshield is removed, and I cleaned up some spots in my engine bay with a wire wheel. It seems like the spot welds tend to corrode a little. Depending on my turbo setup I just went ahead and cleaned my battery tray up and sprayed it with some rust converter after wiring wheeling it. Next step is to sand it and get some paint on it!
#158
The engine bay is almost done! I used about 2.5 cans of single stage, needs a coat of clear though. My dad went in and seam sealed a few places, definitely takes some patience
#160
Thanks! I'm pretty happy with it
Scored some 2007 Grand Prix GXP brakes yesterday. 12.7" rotors with PBR calipers. Looks very similar to a base model C6 Corvette? The spindle from the GXP seems like it'd almost work if we could figure out what to use for struts. Surprisingly the stock 3rd gen strut is scary close but wont quite work. I think a 3rd gen spindle modified for standard C6 Corvette brakes would work also. But if I can figure a strut out it'd be neat to try the aluminum spindles
#162
Interesting. What bolt pattern is on the hub?
What is the measurement from center of the hub to the center of the tie rod hole?
What doesn't fit with the stock strut? thickness of the spindle where strut mounts or bolt hole distance/size issue?
#163
I'll just keep my cowl for the visible vin. Is there a hidden one stamped in the frame or something of that nature?
The bolt pattern is around 4.53 if I'm remembering correctly. But a 07 Corvette hub is 4.75 and a 3 bolt like the gxp. Thinking that may possibly work out. Sorry if my measurements aren't perfect
#164
There are VINs on pass front structure by core support (under the fender) and also 1-2 under the hvac box.
#165
Car: 92 Camaro RS
Engine: 5.0L
Transmission: AUTO, 56k orig
Cant blame the city. These cars dont belong on salted winter roads.....one the salt tears em right up and two they dont handle the conditions well. Mine hibernates november til may. Good luck with everything. The turbo 5.3 looks saweeeet! The girlfriend is a keeper too for sure! Lol
#166
#167
This past month has been busy so I haven't had a chance to update. I got some parts painted up and the rear end coated with POR 15. I need to order a diff cover with bearing supports next. Been coating some other pieces with POR 15 also just to ensure they won't rust again. Other than that the car should be ready to be clipped soon! I also got another Formula hood in better shape, forgot a picture though
#168
Taking the damaged front off piece by piece! Getting close!!
#169
No turning back!
#173
Engine: 350, 350, 305, 396
Measure twice cut once... I hope you at least put sub-frame connectors and lap weld the A pillars upon reassembly.
#174
Sorry if I scared you guys Everything is measured and we started making the cuts that really count. Drilled the A pillar skins and rocker skins off, that way we have 3 welds in those areas. You can see we cut tabs in each half of the cars to have a little added strength, plus once its welded up and the seat brace is back on you will never know. Doing it all like this wouldn't even need sub frame connectors but yes I have a S&W subframe kit for it. Pretty much ready to weld the to cars halves together and then its all down hill from there! Also 4 years ago today I got the car, little bit of a transformation I think
#175
I don't want to upset you here but I believe most law enforcement will view this as you attaching a donor back half to the new cowl rather than your adding a new cowl to your original back half. The VIN is tied to the car the cowl came from and not your original black car.
#176
I'm using my old cowl in the new firewall. They can view it however they want, I'm using my rear half, rear floor, roof, pillars, and cowl. Just adding a new front section of floor, firewall, frame, etc.
We made a milestone today lol. Got it in the clamps and tacked together. Me and my girlfriend (who had a wild hair apparently) got it up there by ourselves.
#178
Rebuilt my door hinges and put both doors on tonight to make sure everything fits alright before we start welding it. Put a fender on for fun too. Lastly I picked up a set of GTA Ultima seats for dirt cheap
#180
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Axle/Gears: MW 3.42 12 Bolt
The 34mm sway bar will be perfect if you up the spring rates.
While the k-member is out, that would be the perfect time to weld in plate for a swivel cup weight jack set-up: http://www.speedwaymotors.com/AFCO-2...bly,23487.htmlhttp://www.speedwaymotors.com/AFCO-2...bly,23487.html
Plate not shown, but you can find it. This will help eliminate guess work with spring ride height w/5.3, and a great performance enhancement. It's a lot of work with the k-member in the car. Once it's out - a piece of cake.
#183
Thanks everyone for the support. I haven't had time to post here so I figured it was time I updated this. The pillars are welded up, floor is welded completely, rockers are welded up also. Got some short strand fiberglass filler on the pillars and rockers for now. Front Wheel wells are painted/undercoated and the freshly powder coated k member is reinstalled along. Notched for a/c also. Haven't seen anyone do a turbo 5.3 with a/c so I may possibly be the first with a turbo ls 3rdgen with a/c? Got some new goodmark quarter panels since it could really use both to be done right. The passenger side had a Earl scheib patch job that makes me wonder what their reason for even patching it was, cause it's horrendous. Sent my spindles off to bigbrakeupgrade to have them modified for the C6 corvette brakes. We are cutting the floor to add some custom subframe connectors too. Shouldn't be too much longer till it's rolling!
#184
Sweet! I've been wondering what was up with this project. Glad to see you are still at it, and making good progress!
#185
Haven't had much time to work on it but I haven't gave up. Got some front suspension put in minus springs, and started cleaning wheel wells for por 15 and raptor liner. The GXP brake calipers I got fit perfect on the spindles I got modified for C6 Standard brakes, just need the corvette brake rotor since the GXP has a different offset rotor.
Reason I haven't got much done (4 inch Lift, now cylinder 8 has no compression)
#186
Keep chipping away. It's a big job, but you'll get there.
As for the distractions...
#187
Gitttteeer duuuuun
May be things would move a lil faster if you didn't have a sweet lil distraction in the shop all the time xxx ;-)
#188
OP is a bad-****.
#189
I appreciate the kind words
I got started painting the bottom side of my car tonight. Using some semi gloss black POR 15. 2 coats so far, may go over it again with one more but we will see. I just wanted to get a few major areas knocked out. It seems like the "e coat" or whatever didn't protect much. I had a few areas I hit with the wire wheel and it kept flaking off. Had a little bit of surface rust under it. Can't wait to see it after its raptor lined!
#190
Car: 1989 Pontiac Formula 350
This thread serves as motivation when I get overwhelmed by mechanical tasks.
#191
You never know what kind of gifts you're gonna get when removing undercoat! I got a couple nice ones on the drivers side
#192
Ooh...not nice surprises. But now's the time to find and fix 'em.
#193
Car: 1986 Trans Am WS6 w/ Recaros
This thread is crazy. You're doing a good job, keep up the good work! I'm subscribed for sure!
#194
Yeah I've had better surprises...but definitely the time to fix them!
Thanks for the kind words I appreciate it!
Seems like I've been busy the past 2 weeks but I'm back on track. I ordered quite a few brake parts and have been multi tasking between the front brakes and patching the wheel wells. I ordered POR 15 caliper paint, C6 Corvette slotted/drilled rotors, hoses, banjo bolts/washers, ceramic pads, and a steering gear box seal kit. I'll probably end up going with a astro van steering shaft. Not to far off from rolling again, I need to find a 4th gen F body LS1 gas tank, and figure out what fuel pump to run. Getting closer!
Got one patch almost done tonight, turned out pretty good for the first patch panel I've made. Only required a hammer, sandbag, and a 2x4! I think it turned out pretty nice
#195
You've been spending some money! Glad to see you're back on it.
Winter is coming. If you and the girlfriend aren't into snowmobiling, you should have lots of shop time.
#196
No snowmobiling for us, although I'd love to have one . Next step will be to get some sort of heater installed in the garage
#197
Keep plugging away!
#199
Car: Firebird
Engine: 5737cc
well this thread is one of those things you link to people when they ask "can this be fixed"
#200
Car: 88GTA
Engine: 5.7TPI
This has has been downright crazy good! It's like a good book you can't put down....and I don't read much!
Keep up the awesome job!
