Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Custom/Improved Air Dam?
Old 07-02-2016, 11:58 AM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
Has anyone ever fabricated an improved type of air dam? I'm thinking to use something like galvanized sheet metal and give it a bit of a bend to accomplish not only a more of a "ram air" effect into the radiator, but also so I can gain more surface area while still maintaining the same ground clearance.
Stock air dam just points straight down at the ground. I actually had trouble sleeping last night tossing the idea and design around in my head.
Anyone ever done something like this and if so, what results did you notice?
Old 07-02-2016, 12:56 PM
IROCZman15's Avatar
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
Re: Custom/Improved Air Dam?
I've thought about it over the years.
themain worry of mine would be that the stock plastic air dam has some give/flex to it.. so when (not if.. when) you hit a speed bump or dip in the road.. I imagine it flexing as it scrapes. A sheetmetal one would probably break, especially if slanted forward to catch more air underneath. Sure, I could be wrong.. and would love to see if someone has made a good one, but I never decided to build one myself despite thinking of it.
Old 07-02-2016, 01:31 PM
nhgator's Avatar
Car: 1985 T/A
I made a u-shaped one from a piece of conveyer belting................
https://scontent-lga3-1.xx.fbcdn.net...0e&oe=58325BC8
Old 07-02-2016, 04:20 PM
It shouldn't be much trouble to make. If you're short on tools you could just buy a piece of the 90* galvanized steel with all of the holes and slots in it from a hardware store. Set it on its ends with the angle pointed up. Put a 2x4 on top and hammer the 2x4 to open the angle up. Bolt that to the lower core support. Buy a piece of Plexi glass and cut it to the desired length and width and paint it and bolt it to the other end of the angle. Use Plexi glass or ABS plastic, not metal or aluminum or fiberglass. You want the Plexi glass to be the weak link so it doesn't break or bent the lower core support.
There are other things you can to to improve airflow. Remove the air filter ducting if your car has it. Remove the stock grill. Use a tubular front bumper instead of the big stamped steel piece. Cut out the area of the front bumper that the plate bolted to. Box off the sides and top of the space between the radiator and bumper. Use a dual core aluminum radiator. Have the fans turn on earlier. List goes on.
Old 07-02-2016, 04:24 PM
gt4373's Avatar
Transmission: 5-Speed Manual
Old 07-03-2016, 04:03 PM
Received 1,721 Likes on 1,311 Posts
Easiest thing I know of to make one out of, is truck (18-wheeler) stone guard material.
They're pretty expensive though... some people around here might have trouble affording such a thing, and of course you don't get very much... only about enough for a parking lot full of these cars. http://www.ryderfleetproducts.com/mud-flaps-c-8342 for example.
A piece of aluminum angle bolted to the car, then bolt a strip of the flap to that... the angle would be the weak point.
Old 07-05-2016, 03:04 PM
83 Crossfire TA's Avatar
I've done something like this before. I started with the redesigned version that GM used to sell (3 piece, bigger and stiffer than an original firebird one), added some aluminum reinforcement and then "fins" coming forward matching the opening in the bottom of the nose in a Trans Am.
I used button head screws and rivets to hold it together making it look really racecar (looked a lot like racecar tinwork), it worked well (unless the car was just sitting not moving I didn't need the fans even on a 95* day) but got torn up really quickly on the street, even though I never ran it into a parking lot stop or curb.
That's actually a really good source for something like that, I've tried to find something on and off and the stuff really is expensive from an industrial supply.
Old 07-06-2016, 04:40 AM
fokeyman's Avatar
Car: 89 IROC
Engine: l98 350 TPI
Axle/Gears: 373s
You could go to a truck stop and find some free of charge I bet.
Old 07-08-2016, 07:15 AM
Prolly so; I guess if that $6 for new ones is an insurmountable obstacle... and of course if you can avoid getting shot while ... ummmm ... "harvesting" them
Old 07-16-2016, 08:22 PM
chad pickens's Avatar
Old 08-01-2016, 10:45 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
I came up with cheap 90* zinc steel from home depot with plexi a few years ago so if it contacted the plexi would break and it worked a few times. Problem was replacing the plexi or when it broke it would crack all the way though and you might loose a chunk. This eventually lead to trimming back all overhanging plexi so it wouldn't touch anything thus reducing the air dam height and airflow. Saturday I was at home depot and thought wat could i use to increase the air dam height (lower to the ground but soft enough that it would flex and come back without breaking anything or itself.
Boom figured it out! $13 Door sill gap filler. Basically 36" of aluminum with a large rubber flap on the bottom thats stiff but still flexible and soft. They are even nice enough to drill holes for you and provide screws if you need them lol. Anyway I cut mine to length and mounted it to my air dam so the rubber overhung only past the point of where my original air dam ended. I basically gained 1 3/8" of air dam via the soft rubber which will deform and flex anytime I scrape it. IT should work well but haven't been able to test due to all the rain in NJ!
Enjoy the pic!
Old 08-01-2016, 11:08 PM
Car: 1985 Z28
^^^ Very interesting. I might have to steal this idea.
Old 08-02-2016, 08:54 AM
Car: 87 TA clone
Steal away lol thats why I posted it here!
Old 08-02-2016, 09:31 AM
That's great info, thanks for sharing. If I end up needing to use an air dam I'll follow your lead with this.
Old 08-02-2016, 02:14 PM
gsmarcano's Avatar
Car: Camaro
Engine: 350-Vortec-carbed
Transmission: 700-r4
Axle/Gears: stockola, right now anyhow
Enjoy the pic!
Great Idea! I'm gonna do just that too.
Old 08-02-2016, 05:29 PM
That'll last about one parking lot curb...
Old 08-04-2016, 12:17 PM
Car: 87 TA clone
You shouldn't be hitting parking lot curbs lol.
Side not I took the car out for street driving 2 days and took it to work and then a car show. My driveway is a hill that meets the road at an angle (place to scrape most times) then I have speed bumps to get into work parking lot. The results are in! It survived very well actually. U can see scrapes on the rubber tip from hitting things/scraping on everything lol. The scrapes are the whole length of the rubber and it hasn't deformed.
Another thing to note is that my cooling has improved... But can't say for sure as the weather was abnormally cool yesterday. 77*F vs 90s.
Here's a pic of the marks and scrapes for visual proof!
Old 08-08-2016, 02:14 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
lawn edging also works very well for aero stuff..
Old 08-08-2016, 03:16 PM
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
Great idea. Can you post some pics further away showing your entire setup? I am building an f1 blow thru setup and want ideas. Thanks!
Old 08-08-2016, 08:58 PM
Car: 87 TA clone
Further away? As in like the air dam? Or the engine bay lol.
Put like 40 miles on the setup and so far is working out well. A lot more scrapes on the rubber but it's doing what it's suppose to do and hasn't deformed, just more marks like in the first pic. The air dam is like 5-6" in front of the OEM location and my dad is lowered like 1.5" over stock and pushed forward. The air dam is pushed forward so it scoops air into the FMIC as well as the tranny cooler and rad. The rad basically gets sloppy 3rds after being heated by the IC and very large trans cooler before getting to the rad and I'm still getting 170-180*F engine temps most of the time.
Here's a distance shot of underneath and engine bay shot. I just removed my coil covers and going from the 4.5" cowl to stock hood I had to remove my custom engine cover but the stock look is growing on me.
Old 08-09-2016, 08:03 AM
86CamaroDan's Avatar
Car: 86' IROC
Engine: Supercharged 350
Axle/Gears: 3.45
Intercooler is nicely tucked in there! Some good stuff in this thread! Its been something thats been bugging me for a while, mines all bent up and i feel its almost not even doing anything
Old 08-15-2016, 06:10 AM
Being "tilted" doesn't matter. The air dam doesn't "scoop". That's simply not how it works, even though it might "seem" like that.
What it ACTUALLY does, is separate the area in front of itself (which is at high pressure) from the area behind it (MUCH lower pressure). The main concern being, air (or anything else) flows FROM an area of HIGH pressure, THROUGH whatever is in the way (rad, AC, etc.), TO an area of LOW pressure. The goal of the air dam therefore, is to MAXIMIZE the pressure DIFFERENCE between the area in front of the rad and the area behind it.
Which is why you want something as "tall" as possible; i.e. that comes as close as possible to scraping the ground. Which in turn means, you want to make it out of something that will bend out of the way and not get damaged when it DOES scrape, which is UNAVOIDABLE on a street-driven car.
It's all well and good to talk about "don't hit parking-lot curbs". Yeah right. Wish that in one hand and have a body function in the other and tell me which hand fills up faster. It's ALOT LOT LOT LOT better to design your car so that the INEVITABLE things that happen to it IN THE REAL WORLD as opposed to FANTASY WORLD like not hallucinating you're not going to hit parking lot curbs, damage it as little as possible.
Which is why a rubber truck mud flap is THE PERFECT material to use... it's stiff enough to hold its shape in the breeze, soft enough to bend out of the way without tearing up, it doesn't "scratch", and if it DOES get ruined somehow, it's CHEEEEEEEEEEP and EEEEEEEEEEEEEEEZY to replace.
Old 08-23-2016, 12:48 AM
oil pan 4's Avatar
2 words...
Lawn edging.
But the door sweep one is pretty nice too.
Old 08-24-2016, 08:22 PM
cjh1505's Avatar
Car: 1986 iroc z28
Engine: 5.0 f.i.
Does anyone know what size the screws are that mount the airdam to the body. I had a minor accident and ripped the airdam off. The screw where god only knows where. Thanks in advance.
Old 08-27-2016, 09:21 PM
scooter's Avatar
I think they are M6x1.25
Abubaca
05-29-2016 07:10 PM
Motown
05-02-2016 08:39 PM
PurelyPMD
04-28-2016 09:28 PM
BOTTLEDZ28
Fabrication
04-25-2016 03:00 PM
BOTTLEDZ28
04-14-2016 02:58 PM
Quick Reply: Custom/Improved Air Dam?
