Foll Call: Saskatchewan Members inside.
#101
Car: 83 z28
Engine: 305 for now
Transmission: 5 speed
right now it's just a stock 76 van rebuild, but i have a set of ported heads and a comp cams 282 cam for it. I know the stock 5 speed won't hold up so i have a 4 speed sag that held the power of a big block for a year without wear. So that will go in untill i can afford a aftermarket 5 sped for it. Unless anyone knmows where i can get a wc 5 speed and how i can build it to handle about a max of 400 horse(eventually) Any one see a white 84 Z with royal purple ground effects runnin around saskatoon? that where my old Z went.
#104
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Originally posted by #32pontiac
Hi I have a 1988 GTA and I live in swift current
#105
hey I live in melville saskatchewan, and the only one with a unique 85 camaro, but two days ago it was stolen. ****. It was a great car. Big 295 fatty on the back, 3" cowl induction hood, frsh new black paint job, edelbrock parts etc. But gone now.
#106
Car: 1988 Trans Am GTA Notchback
I've an 88 GTA Notchback. I live in the very small town of Ponteix and I'm pretty sure that I've seen #32pontiac's GTA cruzing around in Swift before.
#107
Car: 1987 Trans Am GTA
Hey, here in Regina, got an 87 GTA L98. Not much for mods now, but just got new heads, intake, headers, trans, etc. I'm very busy this spring...
#108
Car: 86 Trans Am
Engine: 406
Transmission: TH350, 4200
Axle/Gears: Moser 9", 3.89
Also, check out www.thefbody.com/forum for the local crowd.
-Trevor
#109
Oh, well the tranny in there needed a rebuild, so it's coming out to get it and a rebuilt 700r4 going in with 2400 stall and transgo shift kit. I'm also putting on ported and polished corvette l98 heads, some hooker 2055 headers, and a holley stealth ram. I'm not sure about getting a cam yet, sure would like to but we'll see what kind of time i've got...After all this i'm gonna have to make some runs to SIR and see what i can do.
#111
Unfortunately no, i've never been so SIR yet with it, i had no time last year to do that, and i've been fixing little stuff with the car - had leakey valve guides, hence new heads. So that kinda sucks because i won't be able to see how much better it will be, but will still be fun. From these boards I have an idea what the stocker should run, so i'm not concerned.
#112
Car: 86 Trans Am
Engine: 406
I've had my brothers red 87 L98 GTA out at the track many times. The best it did stock (only a K&N and no cat) was 15.1@90mph.
#113
Car: 85' Trans Am
Hi, I live about 45 minutes away from Swift Current on a farm, and hopefully soon I will be the owner of a 86 Trans Am
#115
Car: 1977 camaro
Engine: 468 700 Hp 622 Tq - 1006 Hp 1000Tq
Transmission: Coan Power glide
Axle/Gears: moser 4.56
Hi everyone i am new to this website, I live in Regina, some of the members here know me for my 9 second 77 camaro street car. I am looking to buy an 87 Iroc this week, time to step over to the dark side as it were LMAO.
Sheldon.
Sheldon.
#117
Car: 85 Camaro IROC-Z
Engine: Dual Snorkel 350 Carb
Just recently purchased an 85 Camaro IROC-Z, to be my Project Car.
I am from Saskatoon. Enjoyed the Show N Shine @ Canadian Tire Saturday.
The car came with a 305 that is fried, not sure what else is wrong with it.
Slowly working on putting a 350 from a 81 3/4 ton in it.
From what I have seen, this car has burnt out its engine atleast twice. How are you guys keeping your 3rd Gen. cool?
#118
Originally Posted by 85z28iroc
Just recently purchased an 85 Camaro IROC-Z, to be my Project Car... How are you guys keeping your 3rd Gen. cool?
#119
A Camaro owner once more
I used to have a 1984 Camaro that had a custom airbrushed hood but it was totaled in a car accident in the winter of 2001.
I just recently traded a Fiero that I had a customed up for a 1986 Camaro Z28.
Just figured I would say "HI"
#121
Car: 85 Trans Am
Engine: LB9 305 TPI
#122
The air dam was in place, but not at the right angle because of cracks. I have fixed that, and added a steel curve to the bottom to invite more air up to the rad. The rad was new, but got so hot that the tank separated from the core. Got that all fixed, too, and had to put a new heater core in as well. The water pump was new and the seven blade thermostatic fan should draw enough air to cool.
Just dropped a 350 in this week, hope to get it running this weekend. Will see if heating is still a problem. This car has a huge A/C rad infront of the regular rad. That may be why this car has heating problems. Not enough air getting to the regular rad.
Will keep you informed.
#123
Car: 85 Trans Am
Engine: LB9 305 TPI
The A/C rad in front shouldn't hurt anything, the air still flows through. Have you put a good high flowing water pump on there? That could make a difference. And what thermostat is on there? Have you replaced that too?
If you need anything, give me a call, 249-3003 and I would be happy to help you out.
#124
I am just putting in a 350 from an 81 Chev 3/4 ton. The engine temp. was always normal when we ran the truck. If I have heating problems, I will call you about a high volume water pump. It has a 180 thermostat in it. What do you use?
#126
Got the 350 in. So far, so good, no heating problems.
Sure would be interested in a used 3.42 posi rear end.
Now the long road to upgrading.
#129
Car: 89 GTA
Re: Foll Call: Saskatchewan Members inside.
Hi from regina just bought a white 89 GTA 350 L98.Looking for people in regina to help tune and just general knowledge of these cars.
#130
Congrats on the purchase. Check out F Body Generation Forum, a Western Canada forum, with lots of guys with cars just like yours in the Regina area.
#131
Car: 89 GTA
I've tried registering twice to that forum but i haven't had my account authorized so not sure whats up with that site. But thanks anyways!
#132
Car: 1990 Trans Am GTA
Axle/Gears: 3.42's
Hey everyone...just joined the site today and I see alot of you are from Regina and some of you own a GTA...have yet to see any GTA's in Regina so if you have one I would love to see it sometime...Anyway just bought my 1990 Black GTA 2 months ago from Wynyard (2 hours north of Regina) and its been awesome...if your from Regina you'll see me driving in the North end most of the time as that's where I live...anyway too bad winters coming soon...oh well, check out my car using the link in my signature...later, Josh
#134
Car: 91 Z-28
Engine: T.P.I.
Transmission: 4L60
Hi I'm from Kindersley Sask. I got a Candy apple red with white stripes 91 Z-28. Right now shes a 305 tpi with no major motor work done. Got a custom built 4L60 auto trans built last year good for 500+hp with a custom manufactured 2400 stall torque converter. In the process of finishing some tpi siamesing, porting work and installing C5 Z06 18" motorsports rims with Nitto Invo tires. Maybe next year I can start building the 406 motor.
#135
Car: dark hunter red 84 camaro
Engine: 414 stroker
Transmission: th350
Axle/Gears: 3:70
hey i'm jason from estevan, have a 84 camaro lots of mods
#136
Engine: 414 stroker
Transmission: th350
Axle/Gears: 3:70
this is my camaro, any one from around estevan
#137
Im Dan from Melville/Yorkton,
I have a stock white 81 z28 with a 350/4spd. My uncle from Calgary gave me his 88 SC with a 2.8 /5spd. I havent gone to pick it up yet, and even if I do go get it, it probably wont pass the safety, lol.
#139
www.thefbody.com
The "local" board for us... primarily SK guys, but some ALTA and MB guys there too.
#140
Hey all,
I am from central Sask and own a 83 berlinetta. I have recently been inspired to get her fixed up, as she is sitting with no motor or tranny at the moment.
I have 3 kids and work as a Paramedic...
I look forward to getting some good info/inspiration from ya'll.
#141
Car: 85 Trans Am Iroc-Z
Engine: 305 H.O. 4bbl
Transmission: 5 Speed
Axle/Gears: 3:73 Posi-trac
Chris here, currently in Rosetown but moving to Nipawin on the 31st of August. Just bought an 85 T/A 2 weeks ago, currently working on getting the body all done up. Needs a new paint job and a few odds and ends.
Its the 305 H.O. 4bbl. Pretty much stock except I have put on an edelbrock 14" air cleaner, a edelbrock intake manifold, and I did the exhaust.
#142
Car: 1985 IROC-Z Camaro
Engine: 355c.i
Saskatoon! got an 87 IROC-Z. 350 swap, ported and polished plenum, runners and intake, MSD ignition, Modified MAF, cutout airbox, AFPR cat back 3" exhaust ect. Big plans for the summer time. Gunna be out all summer except when its down when I put a new intake into it. Gunna have her in the show n shine too!!
-Jon
-Jon
#143
Car: 82 Camaro Z28
Transmission: auto
Hi guy's, New to the forums here.
I have a '82 Camaro Z28 305 4bbl Auto.
#144
Car: 1982/1984 Firebird Prostreet
Engine: 6.0 lq4
Transmission: t56
Hey, i have a 1982 firebird 5 speed, in the process of rebuilding. near humboldt area.
#146
New member here, just purchaced my first 3rd gen! i've always loved these beauties. I'm in a small town called Tompkins, Sask. i bought myself a 1984 T/A with a 2.8, i'm a little embarresed about that but baby steps (i do plan to upgrade).
i'll upload a pic if i can figure out how to resize
#147
Car: 1968 Camaro 1969 Camaro 1974 Camaro
Engine: V/8
Transmission: turbo 400
just bought this 1989 Camaro Iroc z
low mileage car hope to show it lots this year.
from Regina Sask.
from Regina Sask.
#148
Car: 87 IROC
Engine: 5.7L LT1
Been around TGO for a while just never popped my head in here before. I'm south of Sasktoon with an 87 IROC.
Pac J
05-17-2020 10:44 AM
92rsvortec350
19
10-09-2015 09:39 AM
LT1Formula
10-08-2015 08:34 PM
